Do different openfoam versions have different formats of the configuration files? |
May 30, 2016, 09:44 |
Suryansh D Kumar
Rep Power: 9 |
Hi
I am an absolute beginner to OpenFOAM. I tried running this snappyHexMesh tutorial which was run on version 2.3. I tried running it on version 3.0.1 http://calumdouglas.ch/openfoam-tuto...comment-169285 I tried running the same example, using the exact same instructions as given in the attached file using OpenFOAM 3.0.1 but got some errors. Do we need to follow any different instructions while using 3.0.1? This is the error I got ************************************************** ****************************** Unknown TurbulenceModel type RASModel************************************************** ****************************** I find it peculiar that it is searching for the C file in my home directory but OpenFOAM is installed in root. Is this the cause of error? On changing the constant/turbulenceProperties file to laminar, I still get an error ************************************************** ***************************** Selecting incompressible transport model Newtonian************************************************** **************************** Any help would be greatly appreciated. Thanks in advance. |
May 30, 2016, 11:47 |
Rep Power: 15 |
There were a few changes between OF2.3 and OF3 in the way things are done. This is perhaps best illustrated by comparing the same tutorial case between the two versions: v3: https://github.com/OpenFOAM/OpenFOAM...Foam/motorBike v2.3: https://github.com/OpenFOAM/OpenFOAM...Foam/motorBike In particular look at the turbulenceProperties file under constant folder and that should help with the first part of the error. Hope this helps. Cheers, Antimony |
openfoam 2.3, openfoam 3.0.1, snappy hex mesh |
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker | rt08 | OpenFOAM Installation | 1 | February 28, 2016 19:00 |
[CAD formats] Importing mesh files to OpenFOAM: is obj format viable? | sudo | OpenFOAM Meshing & Mesh Conversion | 3 | March 5, 2014 05:14 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 13:50 |
