August 8, 2016, 13:28 |
case not running
Manm
Rep Power: 11 |
I am working on Openfoam 1.6-extend. I have a new solver (myTurbDyMFoam)。 It runs on one computer but when I transfer the files to another computer and execute the case it gives me the error : ~/OpenFOAM/dingwen-1.6-ext/run/2p2k6z14R03c$ myTurbDyMFoam new cannot satisfy memory request. This does not necessarily mean you have run out of virtual memory. It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library Aborted (core dumped) I ran checkMesh and it gave me the result: Create time --> FOAM Warning : From function dlLibraryTable:pen(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 86 could not load /home/dingwen/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc48DPOpt/libmySANoft2.so: undefined symbol: _ZN4Foam14incompressible8RASModel11printCoeffsEv --> FOAM Warning : From function dlLibraryTable:pen(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 86 could not load /home/dingwen/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc48DPOpt/liblinMultiBodyFvMesh.so: undefined symbol: _ZThn200_NK4Foam8polyMesh6pointsEv Create polyMesh for time = 0 Initializing the GGI interpolator between master/shadow patches: ggi1in/ggi1out Initializing the GGI interpolator between master/shadow patches: ggi4out/ggi4in Initializing the GGI interpolator between master/shadow patches: ggi2out/ggi2in Initializing the GGI interpolator between master/shadow patches: ggi3in/ggi3out Time = 0 Mesh stats all points: 280380 live points: 280380 all faces: 554811 live faces: 554811 internal faces: 274437 cells: 138208 boundary patches: 17 point zones: 0 face zones: 12 cell zones: 6 Overall number of cells of each type: hexahedra: 138208 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 5 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology inlet 264 530 ok (non-closed singly connected) ggi1in 264 530 ok (non-closed singly connected) bottom 491 992 ok (non-closed singly connected) top 491 992 ok (non-closed singly connected) frontAndBack 276416 280380 ok (non-closed singly connected) ggi4out 264 530 ok (non-closed singly connected) outlet 264 530 ok (non-closed singly connected) ggi2out 264 530 ok (non-closed singly connected) ggi3in 264 530 ok (non-closed singly connected) ggi1out 264 530 ok (non-closed singly connected) ggi2in 264 530 ok (non-closed singly connected) cylinder1 154 312 ok (non-closed singly connected) cylinder1ptc 14 32 ok (non-closed singly connected) ggi3out 264 530 ok (non-closed singly connected) ggi4in 264 530 ok (non-closed singly connected) cylinder2 154 312 ok (non-closed singly connected) cylinder2ptc 14 32 ok (non-closed singly connected) Checking geometry... This is a 2-D mesh Overall domain bounding box (-2.2225 -0.58674 0) (2.450973 0.58674 0.00895) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 0) Mesh (non-empty, non-wedge) dimensions 2 All edges aligned with or perpendicular to non-empty directions. Boundary openness (4.928279428e-20 -1.267495668e-17 -2.238157657e-14) Threshold = 1e-06 OK. Max cell openness = 2.8533366e-16 OK. Max aspect ratio = 35.03147262 OK. Minumum face area = 4.514138221e-07. Maximum face area = 0.0002265218419. Face area magnitudes OK. Min volume = 4.040153708e-09. Max volume = 1.006889587e-06. Total volume = 0.04897249045. Cell volumes OK. Mesh non-orthogonality Max: 43.35474764 average: 4.902691455 Threshold = 70 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.9779241214 OK. Mesh OK. End What could be going wrong? The code runs fine on one computer but not on a second one. Thanks. |
Large test case for running OpenFoam in parallel | fhy | OpenFOAM Running, Solving & CFD | 23 | April 6, 2019 09:55 |
Running parallel case after parallel meshing with snappyHexMesh? | Adam Persson | OpenFOAM Running, Solving & CFD | 0 | August 31, 2015 22:04 |
interFoam running blowing up | sandy13 | OpenFOAM Running, Solving & CFD | 2 | May 5, 2015 07:16 |
Running a solver from a case directory stored anywhere | mich_K | OpenFOAM Running, Solving & CFD | 3 | August 8, 2014 03:57 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
