October 12, 2016, 00:23 |
SymmetryPlane issue
JIN WEIGUO
Rep Power: 9 |
Hi Friends,
I have a problem regarding "symmetryPlane'. I used the same setup to run simpleFoam yesterday and it was working. But I cannot run the same case today.. Could anyone check my error? Thanks a lot! markjin@markjin-VirtualBox:~/OpenFOAM/markjin-4.0/run/Building_NV2$ simpleFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.0-665f1db4c1f1 Exec : simpleFoam Date : Oct 12 2016 Time : 15:10:55 Host : "markjin-VirtualBox" PID : 9024 Case : /home/markjin/OpenFOAM/markjin-4.0/run/Building_NV2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.01 field U tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading field p --> FOAM FATAL ERROR: Attempt to cast type patch to type symmetryPlane From function To& Foam::refCast(From&) [with To = const Foam::symmetryPlaneFvPatch; From = const Foam::fvPatch] in file /home/openfoam/OpenFOAM/OpenFOAM-4.0/src/OpenFOAM/lnInclude/typeInfo.H at line 114. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::symmetryPlaneFvPatch const& Foam::refCast<Foam::symmetryPlaneFvPatch const, Foam::fvPatch const>(Foam::fvPatch const&) at ??:? #3 Foam::symmetryPlaneFvPatchField<double>::symmetryP laneFvPatchField(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #4 Foam::fvPatchField<double>::adddictionaryConstruct orToTable<Foam::symmetryPlaneFvPatchField<double> >::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #5 Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #6 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::readField(Foam:imensio nedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #7 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) at ??:? #8 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields() at ??:? #9 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) at ??:? #10 ? at ??:? #11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #12 ? at ??:? Aborted (core dumped) markjin@markjin-VirtualBox:~/OpenFOAM/markjin-4.0/run/Building_NV2$ |
October 13, 2016, 10:12 |
Paulo Vatavuk
Rep Power: 17 |
Hi Jin,
Some time ago I had a similar problem. In my case, I misspelled symmetryPlane in the blockMeshDict. Best Regards, Paulo |
October 17, 2016, 03:28 |
JIN WEIGUO
Rep Power: 9 |
April 20, 2020, 02:55 |
parth
Rep Power: 6 |
Any update on this?? I am also getting same error. |
February 14, 2023, 04:34 |
john
Just had the same error because I had updated files in folder 0 but not in folder polyMesh. You have to update files in folder 0 with the symmetryPlane condition, e.g.: sidewall { type symmetryPlane; } But also update your constant/polyMesh/boundary files, e.g: sidewall { type symmetryPlane; inGroups 1(symmetryPlane); nFaces 50; startFace 817; } |
simpleFoam convergence issue | Harnoor | OpenFOAM Running, Solving & CFD | 13 | November 16, 2016 08:23 |
Issue symmetryPlane 2.5d extruded airfoil simulation | 281419 | OpenFOAM Running, Solving & CFD | 5 | November 28, 2015 13:09 |
[Other] Override symmetryPlane Boundary condition | gwj_gavin | OpenFOAM Meshing & Mesh Conversion | 0 | December 1, 2014 16:46 |
Divergent temperature in chtMultiRegion(Simple)Foam | akrasemann | OpenFOAM Running, Solving & CFD | 13 | March 24, 2014 02:54 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
