Home > Forums > OpenFOAM
PyFoam
Like Tree4Likes
Old   August 19, 2013, 12:45
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Hi Izna,
You apparently have not yet installed swak4Foam: http://openfoamwiki.net/index.php/Contrib/swak4Foam
Best regards,
Bruno
Old   August 19, 2013, 12:57
izna O'connor
izna is on a distinguished road
Oh Brunos..
Again errors..
Plotting the following cases:
['../Bump2D_run_1.06_10.0_1500.0_200.0_200.0_0.5_2000']
Traceback (most recent call last):
File "./runBump2D.py", line 211, in <module>
plot2DBump.main(target,hSample)
File "/home/izna/Desktop/benmartinez/2DBumpTemplate/plot2DBump.py", line 38, in main
m = max(lastRun)
ValueError: max() arg is an empty sequence
izna is offline   Reply With Quote
Old   August 21, 2013, 10:48
Bruno Santos
Hi Izna,
That error does not seem to be PyFoam's nor swak4Foam's fault.
Please start a new thread about this particular topic and please describe where you got those cases/scripts and how you ran the case and/or scripts.
Best regards,
Bruno
Old   August 21, 2013, 10:52
zaynah K.
zaynah04 is on a distinguished road
I will post one thing for this..
I have checked Hanan case, and i think there is soem errors.. i will post mne.. and we can aall compare
zaynah04 is offline   Reply With Quote
Old   April 8, 2014, 11:27
Francois Beaubert
francois is on a distinguished road
Hi all,
I've an easy one: "How to tell pyFoam to use matplotlib instead of gnuplot by default ?"
I've an already converged case and want to plot for example the residuals with matplotlib. What's the best procedure to achieve this ?
Same kind of question for example for pyFoamSamplePlot.py.
I'm sorry if it looks too trivial but I've tried to find some help in the forum and the doc without success.
Thanks for your help.
Regards
François
francois is offline   Reply With Quote
Old   April 11, 2014, 09:02
Assistant Moderator
Bernhard Gschaider
Originally Posted by francois View Post
Hi all,
Regards
François
If you have the suspicion that something SHOULD work in pyFoam try something like "pyFoamPlotWatcher.py --help" and have a look. In this special case the section "Plot Behaviour" and especially the --implementation-option might be of interest. Also have a look at pyFoamRedoPlot.py (this uses Matplotlib by default)
pyFoamSamplePlot.py only supports Gnuplot but you can write out the data to a CSV-file and then visualize it with whatever you like
Also some utilities (but not SamplePlot) support reading the data and then dropping you to an interactive python-shell. See for instance http://openfoamwiki.net/staticPages/...tml#/sec-3-2-2
My current policy is "Support GNUplot by default because it is an order of magnitude faster than Matplotlib. Also is the API of matplotlib changing and what works on one version might stop working on another. Start offering the possibility to easily export data into the Numpy/Pandas/Matplotlib-stack and then everyone can visualize the way he likes"
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   April 11, 2014, 09:10
Francois Beaubert
Thanks Bernhard for your exhaustive and helpful answer
It's clearer for me now
Regards,
François
Old   June 5, 2014, 05:09
Default Extracting the values from the patchAverage utility through python script
  #288
DAPHNE
DAPHNE is on a distinguished road
Originally Posted by gschaider View Post
Hi Fabian!
The lines you want to change are:
pUtil.add("deltaP","Average of p over patch (.+) = (%f%)",idNr=1)
In order to get added as data the pattern has to be enclosed in (). The first one is used as the ID (as specified by the option). The %f% is replaced with the regular expression that matches a floating point number (just a shorthand in the PyFoam-classes that use regular expressions)
The second part took me longer (I thought my classes were broken, but in fact in your example the [2] was missing):
deltaPressure=pUtil.get("deltaP",ID="einlass:4[2]")[0]
Now deltaPressure has the string 0.557439 (which is what you wanted?)
Bernhard
Hi Bernhard and All,
I tried to extract the values from the patchAverage utility through python script.
I used patchAverage utility to find the pressure field of cavity case:
tutorials/incompressible/icoFoam/cavity$ patchAverage p movingWall
Create time
Create mesh for time = 0
Time = 0
Reading volScalarField p
Average of volScalarField over patch movingWall[0] = 0
Time = 0.1
Average of volScalarField over patch movingWall[0] = 0.0597376
Time = 0.2
Average of volScalarField over patch movingWall[0] = 0.0597292
Time = 0.3
Average of volScalarField over patch movingWall[0] = 0.0597295
Time = 0.4
Average of volScalarField over patch movingWall[0] = 0.0597294
Time = 0.5
End
The script I used is:
solver="icoFoam"
case="cavity"
pCmd="patchAverage"
patch="movingWall"
pUtil=UtilityRunner(argv=[pCmd,"p",patch],silent=True,logname="patchAverage1")
pUtil.add("deltaPp","Average of volScalarField over patch movingWall[0](.+) =(%f%)",idNr=1)
pUtil.start()
deltaP=pUtil.get("deltaP",ID="movingWall[0]") [0]
deltaPressure=pUtil.get("deltaP")[0]
print deltaPressure
Error
/ParameterVariation/cavity$ python utilityrunner.py
File "utilityrunner.py", line 22, in <module>
deltaP=pUtil.get("deltaP")[0]
TypeError: 'NoneType' object has no attribute '__getitem__'
So I tried the following:
from PyFoam.Execution.ConvergenceRunner import ConvergenceRunner
from PyFoam.Execution.UtilityRunner import UtilityRunner
from PyFoam.LogAnalysis.BoundingLogAnalyzer import BoundingLogAnalyzer
from PyFoam.LogAnalysis.UtilityAnalyzer import UtilityAnalyzer
solver="icoFoam"
case="cavity"
pCmd="patchAverage"
patch="movingWall"
pUtil.add("volScalarFieldp","Average of volScalarField over patch movingWall[0](.+) =(%f%)",idNr=1)
pUtil.start()
deltaP=pUtil.get("volScalarFieldp",ID="movingWall" )
print UtilityRunner.get(pUtil,"volScalarField p")
deltaPressure=pUtil.get("volScalarField")
print deltaPressure
Output:
None
None
Still the values are not extracted..
Thank you.
Regards,
Daphne
DAPHNE is offline   Reply With Quote
Old   June 5, 2014, 05:28
Assistant Moderator
Bernhard Gschaider
Create time
Time = 0
Time = 0.1
Time = 0.2
Time = 0.3
Time = 0.4
Time = 0.5
End
solver="icoFoam"
case="cavity"
pCmd="patchAverage"
patch="movingWall"
pUtil.start()
print deltaPressure
Error
solver="icoFoam"
case="cavity"
pCmd="patchAverage"
patch="movingWall"
pUtil.start()
print deltaPressure
Output:
None
None
Thank you.
Regards,
Daphne
There may be other problems, but I think it is the [] in the regular expression. That has a special meaning in regular expression. Replace it with "\[0\]"
For your first steps with regular expressions try something like http://regex101.com/#python (mind: it will NOT understand the %f%. That is PyFoam-specific)
Old   June 5, 2014, 05:31
Alexey Matveichev
alexeym will become famous soon enoughalexeym will become famous soon enough
solver="icoFoam"
case="cavity"
pCmd="patchAverage"
patch="movingWall"
pUtil.start()
print deltaPressure
Error
It's just common sense, maybe I'm missing something, but the error usually means that pUtil.get("deltaP") returned None. You've used deltaPp in pUtil.add and you've used deltaP in pUtil.get. It looks rather strange to me.
The same thing is in the second script.
alexeym is offline   Reply With Quote
Old   June 5, 2014, 05:48
DAPHNE
Dear Bernhard and Alexeym,
Firstly, thank you so much for your quick reply.
@Bernhard
The link you suggested to try Regular expressions is much useful. I tried that and made changes as you suggested. But still the same error persisits. Will keep trying and update.
@Alexeym
Sorry for the inconvenience.[made mistake while copy and paste]By mistake I posted as
But actually I used only the following:
pUtil.add("deltaP","Average of volScalarField over patch movingWall[0](.+) =(%f%)",idNr=1)
Old   June 5, 2014, 05:55
DAPHNE
Hi Alexeym,
Here is the corrected version of the code I used:
pUtil.add("deltaP","Average of volScalarField over patch movingWall \[0\] (.+) =(%f%)",idNr=1)
pUtil.start()
print UtilityRunner.get(pUtil,"deltaP")
deltaPressure=pUtil.get("deltaP",ID="movingWall \[0\]")
print deltaPressure
Regards,
Daphne
Old   June 12, 2014, 03:30
DAPHNE
Hi All,
I managed to correct the code to extract the values from the patch Average utility.
pUtil1=UtilityRunner(argv=[pCmd,"p",patch],silent=True,logname="patchAverage")
pUtil1.add("PressureDifference","Average of volScalarField over patch (.+)= (%f%)",idNr=1)
pUtil1.start()
a=UtilityRunner.get(pUtil1,"PressureDifference")
print a
Regards,
Daphne
Old   June 11, 2015, 20:53
Kojirion's Avatar
Albert Yiamakis
Kojirion is on a distinguished road
I am using pyFoam version 0.6.4 with python 3.4.3, which the wiki suggests is fine. It generally works, however I have encountered an error that I 'm almost certain is due to incompatibility between python versions. Line 291 of Benchmark.py reads
args=string.split("%s %s %s %s" % (pre,workDir,caseDir,post))
I believe that would work with python 2, but does not on 3 (" AttributeError: 'module' object has no attribute 'split'")
(Line 293 suffers from the same problem)
I have also encountered a couple more issues when parsing a dictionary with
ParsedParameterFile that I haven't dug in to find the cause of:
- the value "none" is incorrectly read as "no" and has to be manually fixed
- whitespace is not parsed correctly, for example "(air in water)" when reading the phaseProperties of twoPhaseEulerFoam bubbleColumn tutorial: it results in a list rather than a dictionary.
Kojirion is offline   Reply With Quote
Old   January 27, 2016, 08:33
Jens
jensi_t is on a distinguished road
I use fluent3DMeshToFoam and fluentDataToFoam to start my calculation from an initial solution (with nonuniform profiles on inlets). Then I apply a changeDictionaryDict to the case to set the right boundary conditions (probably also possible with pyFoam).
One inlet condition for U is for example:
        farfield_inlet
        type            temperatureDirectedInletOutletVelocity;
        phi             phi;
        T               T;
        T0              uniform 255;
        inletDirection  uniform (1 0 0);
        cylindricalCCS  no;
        omega           ( 0 0 0 );
        value           uniform (245 0 0);
My question is how I can copy the nonuniform Ttot Field of farfield_inlet into the U boundary condition. Is pyFoam my friend in such a case?
Thanks in advance.
Jens
jensi_t is offline   Reply With Quote
Thread Tools
Trackbacks are On
PyFoam library seb62 OpenFOAM Post-Processing 52 September 30, 2011 08:28
