[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh
Like Tree6Likes
Old   March 2, 2011, 12:27
Assistant Moderator
Bernhard Gschaider
Originally Posted by ivan_cozza View Post
Again correct, in my case tau is the tangential vector aligned with the flow velocity U, so (U dot tau) = mag(U-normal()*(normal() dot U)).
What I want to do is set the slip velocity at wall, so at the end a Dirichlet b.c. for U is possible. On the other end, for stability reasons I need to evaluate U_slip in an implicit way, so I can't just discretize the derivatives and solve.
For d(U dot n)/dtau, maybe it could be rewritten as grad(U dot n) dot tau
Any other ideas? I definitely hope that groovyBc would do the trick...
Thanks, Ivan
I'm afraid implicit won't work (unless you can reduce it to a mixed-BC).
Bernhard
Old   March 3, 2011, 02:47
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
Bernhard
What do you mean with reduce to a mixed b.c.?
My b.c. is essentially a mixed b.c., as apart from the constants it is in the form
a*f_wall + b*grad(f_wall) = c
what kind of modification it needs to be putted in a mixed b.c.?
Thanks,
Ivan
ivan_cozza is offline   Reply With Quote
Old   March 3, 2011, 09:15
Assistant Moderator
Bernhard Gschaider
Thanks,
Ivan
With mixed b.c. I mean the mixed boundary condition as described in the UserGuide 5.2.3
Old   May 12, 2011, 18:23
Dan Maciejewski
DanScranton is on a distinguished road
Hello Foamers,
I am having the same error as suraj in post #27. However, I have added
libs ( "libgroovyBC.so" );
to the controlDict, and OF1.6-ext has access it, as I have no error finding the library. The error:
--> FOAM FATAL ERROR:
gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type groovyBC)
on patch jet of field U in file "/home/dum153/OpenFOAM/dum153-1.6-ext/run/plateBlowing/airIntoWater/0/U"
You are probably trying to solve for a field with a generic boundary condition.
From function genericFvPatchField<Type>::gradientInternalCoeffs( ) const
in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 782.
I am trying to implement a time-varying (ramp) parabolic velocity in the y-direction, following the "pulsedPitzDaily" case, which works fine. The offending code:
jet // jet perpendicular to hole
// type timeVaryingUniformFixedValue;
// fileName "JetVelocity";
// outOfBounds clamp;
// type fixedValue;
type groovyBC;
variables (
"t0=0.5"; // time (s) when to begin injection
"t1=1.0"; // time (s) to level off velocity -> constant after this time
"C=0.2"; // slope: velocity / time -> [m/s^2]
"xp=pts().x";
"minX=min(xp)";
"maxX=max(xp)";
"para=-(maxX-pos().x)*(pos().x-minX)/(0.25*pow(maxX-minX,2))*normal()";
// valueExpression "(time()<t0) ? 0 : ( time()<t1 ? C*(time()-t0) : C*(t1-t0) )";
// valueExpression "(time()<t0) ? vector(0,0,0) : ( time()<t1 ? C*(time()-t0)*para : C*(t1-t0)*para )";
valueExpression " vector(0,0,0) ";
value uniform (0 0 0); // default value not used
Any ideas as to what is causing this error? The pulsedPitzDaily case ran fine. I tried modifying the code, to just produce no-slip at the jet. Case runs fine with
type fixedValue;
But not for the equivalent with groovyBC:
type groovyBC;
This indicates to me that just using groovyBC is the issue, although the lib can be found without a problem...
Any insight would be greatly appreciated
Thanks,
Daniel
DanScranton is offline   Reply With Quote
Old   May 14, 2011, 11:15
Santiago
gascortado is on a distinguished road
Hi all,
I'm trying to set up a random 3D velocity inlet similar to this:
variables "utau=.128;nu=1.51e-5;ux=utau*((1/.41)*(log(pos().y*(utau/nu))) ;uy=(1/2.5)*ux; uz=(1/2)*ux;";
valueExpression "vector (ux*rand() ,ux*rand(), uz*rand())";
I need these three components to be random and independent of each other. I realized however, that every time rand() is called in a specific time-step it generates the same random field so at the end ux, uy and uy are multiples of each other. That is not what I want.
Is it possible to generate three sets of random numbers for each time step using GroovyBC??
gascortado is offline   Reply With Quote
Old   May 16, 2011, 05:00
Assistant Moderator
Bernhard Gschaider
That all looks fine. Anyway. Set in your installation in etc/controlDict these flags:
disallowGenericFvPatchField 1;
disallowGenericPointPatchField 1;
disallowGenericPolyPatch 1;
instead of silently accepting the unknown BC it should give you a list of the boundary conditions that OF currently knows about (including stuff that was pulled in via libs)
BTW: which version of OF and which version of swak are you working with?
Originally Posted by DanScranton View Post
Hello Foamers,
// type fixedValue;
type groovyBC;
variables (
"xp=pts().x";
"minX=min(xp)";
"maxX=max(xp)";
type fixedValue;
type groovyBC;
Thanks,
Daniel
Old   May 16, 2011, 05:14
Assistant Moderator
Bernhard Gschaider
Originally Posted by gascortado View Post
Hi all,
I see what the problem is: the random-number generator always uses the same seed. This behaviour comes from old FSF (where this function was reused from) and was introduced then to make the fields generated by FSF reproduceable (this will also mean that the random-field will stay the same for all time-steps). Anyway. I have an idea how to fix this. If a bug-report turns up on the swak4foam-Mantis (sorry. I will only fix this for swak) then I will have a look at it. If no bug-report turns up I will fix it when I need this
Bernhard
Old   May 16, 2011, 06:52
Santiago
Thanks for your reply. Just FYI, the random numbers are changing at every timestep. Is swak4foam-Mantis another tool similar to GroovyBC? sorry, I'm not so familiar with what swak4foam-Mantis is. I dont know what FSF is either. Is there any way for me to get into the source code for this and fix it myself? I guess I will have to create my own BC and compile it right?
Old   May 16, 2011, 08:32
Assistant Moderator
Bernhard Gschaider
FSF is short for funkySetField
The Mantis is the bug-tracker software. This is a web-application so you only need a login. Link to the one for swak4Foam can be found on the swak-Wikipage
Sources: of course they are. Links on how to get them (either by SVN or with mercurial) can be found on the Wiki-pages for groovyBC and swak. If you manage to fix it by yourself then patches/commits will of course be appreciated
The elegant way to fix it would be to modify the driver-method makeRandomSomething to not alway use the same seed or to modify the grammer so that the user can specify a seed with the random-function (like this 'random(42)')
Old   May 16, 2011, 11:27
Default groovyBC working
  #230
Dan Maciejewski
Bernhard,
Thank you for your suggestion: indeed groovyBC was not available. I had included the library in controlDict, but had put it inside of functions(); and therefore was not seen by the application.
I am running OF 1.6-ext, and swak4Foam version is compatible with 1.7 or 1.6-ext.
Now it is running well; thanks for your contribution!
Cheers,
Daniel
Old   June 14, 2011, 03:54
Default swak4Foam vs. groovyBC on OF 1.6-ext
  #231
Arne Stahlmann
Arnoldinho is on a distinguished road
I figured out some problems using swak4Foam in combination with interFoam and OF 1.6-ext, showing strange results near the inlet (see below). The aim was to generate 2nd order Stokes waves.
1. I compiled OF 1.6-ext from scratch just a few days ago, and afterwards simpleFunctionObject 1.6 and swak4Foam 1.7. All compiles without an error. Using groovyBC at the inlet, I got strange results in the internal mesh near the inlet, see figures one and two.
2. I erased swak4Foam and simpleFunctionObjects and instead compiled groovyBC 1.6. Results were as expected, see figure three.
Using swak4Foam on the same machine with OF 1.7.x gave the same, expected results as in (2.).
Arne
Arnoldinho is offline   Reply With Quote
Old   June 14, 2011, 05:58
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
Hi Arne!
My remark is not regarding sawk4Foam:
do you complain that alpha field out of range [0..1]?
Is it just a post-processing or are those real alpha values?
I think it is due to convectional term discretization. I use modified interFoam solver
with alpha field limiting after it is calculated in alphaEqn.H.
Your comments?
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   June 14, 2011, 08:31
Arne Stahlmann
Good point Alexander. Never really thought about that... Yes, the values are calculated ones.
As I already use a modified interFoam solver and loop over my cells, I could integrate this as a limit as well. Although the speedup is only about three percent in my case...
But I'm not sure if this modification might have some disadvantages?
Arne
Old   June 14, 2011, 11:41
Assistant Moderator
Bernhard Gschaider
Arne
That's a strange one. May I summarize:
1. OF-1.6-ext + swak4Foam from SVN: doesn't work
2. OF-1.6-ext + old-school groovyBC: works
3. OF-1.7.x + swak4Foam from SVN: works
One question: are you sure that this is not due to the change of what the pressure is in interFoam or other implementation differences (although the combination 2+3 speaks against this)
Would it be possible for you to file a bug-report at the extend-mantis, if possible with the case (it is "only" blockMesh is it?) or at least share the boundary conditions you used with us?
Bernhard
Old   June 14, 2011, 11:54
Arne Stahlmann
Yep, thats correct.
I took exactly the same case, (and changed p_rgh to pd in 0 folder, fvscheme and fvsolution from 1.7.x to 1.6-ext).
I will put a bug report with a smaller test-case blockMesh in extend-mantis.
Arne
Old   June 15, 2011, 07:00
Arne Stahlmann
Hmm, that's indeed strange: I just got the latest swak4Foam version and recompiled it. No I got similar, wrong results using OF 1.7.x as well! Has anything been changed the last few weeks, as I had an "older" swak4Foam version installed on that machine as it was working?
Does it make a difference, if I compile simpleFunctionObjects 1.6 and afterwards swak4Foam alone or only swak4Foam without sFO (but tried both)?
Arne
Old   June 15, 2011, 08:22
Assistant Moderator
Bernhard Gschaider
I summarize again:
4. OF-1.7.x + swak4Foam new : doesn't work
Does "new" mean you're using the version from SVN or from Mercurial? Although I'm not aware of a difference between the two that might affect your problem?
No. sFO and groovy don't affect each other.
What could be the case is that you're in a version of "DLL-Hell": there is a mix of libraries you're actually using. Check:
a) have a look the $FOAM_LIBBIN, $FOAM_USER_LIBBIN and $FOAM_SITE_LIBBIN. Whether there are different instances of libgroovyBC.so and the other swak-libraries
b) check with ldd (ldd $FOAM_LIBBIN/libgroovyBC.so) which other libraries groovyBC actually is using
Old   June 15, 2011, 08:41
... you can also check your solver:
ldd `which interYourFoam`
just a comment)
Best regards,
Old   June 15, 2011, 09:45
Assistant Moderator
Bernhard Gschaider
just a comment)
I'm afraid that won't work, because usually groovyBC is dynamically loaded via the libs entry in the controlDict and ldd doesn't know about that. If groovyBC is linked into the solver (you can do that, but I don't recommend it) then this will work
Bernhard
Old   June 15, 2011, 15:04
Bernhard,
thank you for your clarification! I usually link my libs via "options" file in Make directory,
to check their presence at the link stage of compilation... So then it works)
Best regards,
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent Qingsong FLUENT 2 March 21, 2022 15:08
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[ICEM] Dynamic mesh setup with ICEM David121284 ANSYS Meshing & Geometry 0 April 11, 2014 04:19
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 22:09
dynamic mesh for drop interface IndrajitW FLUENT 0 March 30, 2013 08:03
