Home > Forums > OpenFOAM
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh
Like Tree1Likes
Old   April 25, 2012, 10:42
Assistant Moderator
Bernhard Gschaider
Originally Posted by RitaFC View Post
I thank you for your reply.
Perhaps Bison is not correctely installed.
1 - I download swak4Foam withot problems. In which directhory it should be placed ?
2 - Moving to the swak4Foam directory - Doing "./Allwmake" - Appears:
No 'swakConfiguration'. Python etc won't work
Checking swak4Foam- version and generating file
./Allwmake: 9: ... not found
./Allwmake: 17: ... not found
./Allwmake: 19: bison: not found
Bison is version
Can you give me a opinion what to do ?
Kind regards,
Rita
"Install bison and flex" is the best I can offer. Does
which bison
show an installed bison?
BTW: what do the "..." in your output mean. Or are the really there?
Old   April 26, 2012, 05:36
Rita Carvalho
RitaFC is on a distinguished road
which bison
Hi
I'm sorry to borrow you again but in a different computer with ubuntu 10.10,
I started all the instalations again: m4,bison with libiconv, flex from the root I had no errors and after:
1. svn checkout https://openfoam-extend.svn.sourceforge.net/svnroot/openfoam-extend/trunk/Breeder_1.7/libraries/swak4Foam/
I had a warning=> Fetching external item into 'swak4Foam/Libraries/simpleFunctionObjects'
svn: warning: 'swak4Foam/Libraries/simpleFunctionObjects' is already a working copy for a different URL
2. ./Allwmake
root@ubuntu:~/swak4Foam# ./Allwmake
Checking swak4Foam-version and generating file
./Allwmake: line 32: wmake: command not found
Requirements for Library not satisfied. I see no sense in going on
Would you be so kind to answer me again. Perhaps you have an idea what I am doing wrong !
Kind regards, Rita
RitaFC is offline   Reply With Quote
Old   April 26, 2012, 06:38
Rita Carvalho
which bison
Just to complement : when download swak4Foam from home in ubuntu 10.10 with openFoam 1.7 or ubuntu 11.10 with openFoam 2.1:
rita@ubuntu:~/swak4Foam$ ./Allwmake
./Allwmake: 9: [[: not found
./Allwmake: 17: [[: not found
Bison is version 2.4.1
./Allwmake: 33: cannot open 2.3: No such file
./Allwmake: 33: [[: not found
OpenFOAM-version: Major 2 Minor 1 Patch 0
./Allwmake: 67: [[: not found
No change to swak4FoamParsers/foamVersion4swak.H
SOURCE=FaceSetValueExpressionDriver.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -IMake/linuxGccDPOpt -I/opt/openfoam210/src/finiteVolume/lnInclude -I/opt/openfoam210/src/sampling/lnInclude -I/opt/openfoam210/src/triSurface/lnInclude -I/opt/openfoam210/src/lagrangian/basic/lnInclude -I/opt/openfoam210/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam210/src/OpenFOAM/lnInclude -I/opt/openfoam210/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/FaceSetValueExpressionDriver.o
In file included from lnInclude/SubsetValueExpressionParser_location.hh:44:0,
from SubsetValueExpressionParser.tab.hh:65,
from SubsetValueExpressionDriver.H:60,
from SetSubsetValueExpressionDriver.H:48,
from FaceSetValueExpressionDriver.H:52,
from FaceSetValueExpressionDriver.C:34:
position.hh: In function ‘bool parserSubset:perator==(const parserSubset:osition&, const parserSubset:osition&)’:
position.hh:136:69: warning: suggest parentheses around ‘&&’ within ‘||’ [-Wparentheses]
from CellSetValueExpressionDriver.H:52,
from CellSetValueExpressionDriver.C:34:
Old   April 26, 2012, 14:18
Assistant Moderator
Bernhard Gschaider
Hi
2. ./Allwmake
Kind regards, Rita
In that case the wmake utility is not found. Reason is probably a problem with your OF installation on that machine. Nothing swak-specific (you probably can't compile ANY utilities on that machine)
Old   April 26, 2012, 14:24
Assistant Moderator
Bernhard Gschaider
That is the output on the other machine (the 11.10, right?). My shell-scripting skills are not good enough to know what exactly happened here. Maybe /bin/sh is now a different shell on Ubuntu (don't have that either). Try replacing the first line of Libraries/Allwmake which reads
#! /bin/sh
with
#! /bin/bash
and see whether it happens again
Old   May 8, 2012, 06:06
Rita Carvalho
Sorry because I forget to report that the problem is solved.
I thank you for the answer.
In fact the file was already with "bash". But with a lot of patience and installations and verifing the text files in "swakconfiguration" and "the Files" the problem is solved and swak4Foam is working pretty well.
Thanks for that also.
Note: However the messages 9 not found and so on still appeared.
Old   July 5, 2012, 16:49
Default inlet wave modulation
  #267
ak
newOFuser is on a distinguished road
Hello all,
I am trying to study forced response of step combustor using a compressible solver with turbulence modeling.
Instead of imposing a fluctuating velocity at the inlet, I would like to use the inlet wave modulation technique (see attached figure from a paper).
Could some one please let me know if and how this could be implemented in OpenFOAM? Can groovyBC be used for this purpose? [I am sure there must be a way! ]
Thanks so much!
amit
newOFuser is offline   Reply With Quote
Old   July 6, 2012, 05:14
Assistant Moderator
Bernhard Gschaider
Originally Posted by newOFuser View Post
Hello all,
Thanks so much!
amit
Quick glance at the paper says: Yes. Have a look at the pulsedPitzDaily-case that does something similar (of course you'll only need the real component of the complex exponential function given in the paper, but that is "Math 101")
Old   July 13, 2012, 10:13
ak
Thanks for the reply! I am currently using the same formulations as implemented in pulsedPitzDaily to implement the IVM (velocity modulation) case. [Thanks for the groovyBC tool!]
However, I am not sure how to go about implementing IWM (wave modulation). The paper also says "To use IWM, however, codes must use boundary conditions based on characteristic methods". The determination of A's is also not very clear. Do you have any insights on this?
On another note, I also came across some work (F. Piscaglia, A. Montorfano) that mentioned that the waveTransmissive BC is not perfectly non-reflecting, and there has been some work in implementing NSCBC in openFoam, as well as acoustic sources. Is the work available in the public domain?
Thanks!
ak
Old   July 13, 2012, 18:38
Assistant Moderator
Bernhard Gschaider
Don't know. Guess you'd best open a new thread with that thread as I don't think that the people who know will find the question in this thread
Old   July 31, 2012, 11:30
Default directionMixed BC by groovyBC
  #271
Mieszko Młody
ziemowitzima is on a distinguished road
Hi
First of all , thanks for groovyBC !
I have a question. Is it possible to simulate directionMixed like BC using groovyBC ?
I am interesting in velocity BC.
I would like to have fixedValue (some time and space function) in the normal direction and some fixedGradient (again some time and space function) in the tangential direction.
Is groovyBCDirection suitable for this ? Unfortunately I could not find any example how to use it...
Is there any example how to use them ?
I tried sth like this:
sidesleft
type groovyBCDirection;
variables (
"yp=pts().y;"
"ep=1/0.0447213595499958;"
"para=-(1 + ep*pos().y*(2 - ep*pos().y))*normal();"
valueExpression "sin(time())*para";
gradientExpresion "
cos(time())*para";
valueFraction (1 0 0 0 0 0);
value uniform (0 0 0);
It does not give any run time error, but I am not sure if it does what I would like ...
Many Thanks
ziemowitzima is offline   Reply With Quote
Old   August 6, 2012, 18:11
Assistant Moderator
Bernhard Gschaider
Originally Posted by ziemowitzima View Post
Hi
sidesleft
variables (
"yp=pts().y;"
gradientExpresion "
cos(time())*para";
Many Thanks
I guess the problem is that your valueFraction gets overwritten by the fractionExpression which defaults to "symmTensor(1,0,0,1,0,1)" (the one-matrix).
Check the value of valueFraction at later timesteps
Old   August 9, 2012, 08:55
Illya Shevchuk
linch is on a distinguished road
Hi folks,
is it possible to use a dimensionedScalar or a vector in groovyBC, not a field?
Best regards,
Illya
linch is offline   Reply With Quote
Old   August 9, 2012, 09:04
akidess's Avatar
Anton Kidess
Illya, I think you need this: http://openfoamwiki.net/index.php/Contrib_IOReferencer
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
*Check out the scientific computing exchange http://scicomp.stackexchange.com
Old   August 9, 2012, 11:09
Mieszko Młody
Hi Illay,
I am not sure if I understood your question.
But in groovyBC (and any other BC) you have to specify vector or a scalar ...
Old   August 15, 2012, 13:34
akidess's Avatar
Anton Kidess
Any idea why
fractionExpression "sqr(normal());";
in groovyBCDirection leads to a syntax error, unexpected ')' ?
Old   August 20, 2012, 17:00
Assistant Moderator
Bernhard Gschaider
Originally Posted by akidess View Post
Any idea why
Well. normal() is a vector. sqr expects a scalar. The parser says "This can't be all". Something like "sqr(normal().x)" or "sqr(mag(normal()))" might work
Old   August 20, 2012, 17:03
Assistant Moderator
Bernhard Gschaider
Originally Posted by linch View Post
Hi folks,
Best regards,
Illya
A dimensionedScalar defined in the program? No. There are some ways around (the IOreferencer described below is one of them). But to say which is the best it would be helpful if you described the problem you want to solve
Old   August 21, 2012, 04:22
akidess's Avatar
Anton Kidess
Foam::sqr will return a tensor when called with a vector, which is very handy for the fractionExpression of groovyBCDirection. Ok to file a bugrep?
Old   August 21, 2012, 07:27
Assistant Moderator
Bernhard Gschaider
I wasn't aware of this. That's why it was not represented in the grammar.
That would be a simple fix to the grammar.
You don't have to ask to file a bug report. If I don't like them I will turn them down Yes. Please
Thread Tools
Trackbacks are On
Running funkySetFields sara OpenFOAM Running, Solving & CFD 10 October 3, 2012 10:08
FunkySetFields for OF 141 mer OpenFOAM Pre-Processing 68 May 5, 2011 04:25
FunkySetFields dictionary gschaider OpenFOAM Running, Solving & CFD 14 December 3, 2008 21:13
FunkySetFields for cyclic bc zakifoam OpenFOAM Pre-Processing 1 December 18, 2007 07:24
