Home > Forums > OpenFOAM
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh
Like Tree6Likes
Old   March 6, 2009, 05:59
Default Hi. Sorry myself, doesnt work
  #21
Marco Müller
marico is on a distinguished road
Hi. Sorry myself, doesnt work ;) :
wmakeLnInclude: linking include files to /home/mueller/OpenFOAM/mueller-1.5-dev/groovyBC/lnInclude
make: *** Keine Regel vorhanden, um das Target »mixedPointPatchFields.dep«,
benötigt von »Make/linuxGccDPOpt/dependencies«, zu erstellen. Schluss.
Marco
marico is offline   Reply With Quote
Old   March 9, 2009, 03:02
Default Hey Bernhard, I pulled 1.5-
  #22
egp
egp's Avatar
Eric Paterson
egp is on a distinguished road
Hey Bernhard,
I pulled 1.5-dev revision 1105, and groovyBC today and tried to compile on opensuse 11.1. I ran into the similar problems as Marco. Per your suggestion, I was able to compile groovy if I commented out groovyBCPointPatchFields.C in Make/files. The demo pulsedPitzDaily will still run without the PointPatchFields.
It seems that there is a case-sensitive issue with PointPatchField, e.g.,
"MixedPointPatchField.H" vs.
"mixedPointPatchField.H"
"PointPatchFieldMapper.H" vs.
"pointPatchFieldMapper.H"
If I rename these files, I still get the following error:
groovyBCPointPatchFields.H:47:37: error: macro "makePointPatchFieldTypedefs" requires 7 arguments, but only 1 given
groovyBCPointPatchFields.C:45:30: error: macro "makePointPatchFields" requires 3 arguments, but only 1 given
Checking the 1.5-dev repository, it seems the checkin at Rev. 1058 (Added support for point-Fields) may be the culprit?
Eric
egp is offline   Reply With Quote
Old   March 9, 2009, 12:06
Default Hi! It seems that there is
  #23
Assistant Moderator
Bernhard Gschaider
Hi!
It seems that there is a slight difference of the dev-version (I tested/developed groovyBC with the OpenCFD-version). Until I have sorted this out users of the dev-version should get the last "unpointed" version using this command:
svn -r1057 checkout https://openfoam-extend.svn.sourceforge.net/svnroot/openfoam-extend/trunk/Breede r_1.5/libraries/groovyBC
This compiles, but doesn't have the point-BCs
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 10, 2009, 02:56
Default Hi Bernhard, thanks for you
  #24
Marco Müller
Hi Bernhard,
thanks for your care. I'll compile the 1.5.x.git version to use groovyBC cause I need point-things! ;)
Marco
Old   March 12, 2009, 03:18
Default Hi again, works smoothly wi
  #25
Marco Müller
Hi again,
works smoothly with 1.5.x... ;)
Thanks!!
Old   March 12, 2009, 12:21
Default Hello all! I am trying to get
  #26
Suraj Deshpande
suraj is on a distinguished road
Hello all!
I am trying to get the pitzDaily case going with the groovyBC condition. When I ran the case, I got this error message. Can somebody tell where I am making a mistake?
The error is as follows -->
gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type groovyBC)
on patch inlet of field U in file "./pitzDaily/0/U"
You are probably trying to solve for a field with a generic boundary condition.
From function genericFvPatchField<type>::gradientInternalCoeffs( ) const
in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 692.
Thanks,
- Suraj
suraj is offline   Reply With Quote
Old   March 12, 2009, 12:24
  #27
Suraj Deshpande
Hello all!
Thanks,
- Suraj
Old   March 12, 2009, 13:18
Default This usually happens if OpenFO
  #28
Assistant Moderator
Bernhard Gschaider
This usually happens if OpenFOAM doesn't "know" the boundary condition
I assume that you're talking about the Demo-case (so it should be set up with the correct libs-entry in the controlDict and that you successfully compiled the library). Have a look at the start of the run whether there is anything about loading/not loading the libgroovyBC.so
Bernhard
Old   March 12, 2009, 14:54
Default Thanks Bernhard. Probably lib
  #29
Suraj Deshpande
Thanks Bernhard.
Probably libgroovyBC.so is not being loaded.
This is what it reads:
could not load libgroovyBC.so: cannot open shared object file: No such file or directory
I am doing this for the first time. Could somebody guide me to where I can find information getting it set?
Sorry for the trouble.
Thanks,
- Suraj
Old   March 12, 2009, 18:51
Default Thanks Bernhard. I got it to
  #30
Suraj Deshpande
Thanks Bernhard.
I got it to work.
Old   March 16, 2009, 08:21
Assistant Moderator
Bernhard Gschaider
Originally Posted by marico View Post
Hi again,
Thanks!!
And now the version on the SVN should also work with the dev-version. Please note that to recognize the dev-version it assumes that an environment-variable FOAM_DEV is defined (etc/bashrc was modified in the SVN to provide that variable)
Bernhard
Old   March 24, 2009, 06:21
Default epsilon inlet profile with groovyBC
  #32
Eugene Joubert
ecjoubert is on a distinguished road
Hi Bernhard
I am a fairly new OpenFoam user.
I have been able to download and implement groovyBC.
I use it to specify a inlet velocity profile U(y) = (u*/K)ln((y+yo)/yo) and it works great.
I would like to specify a profile for epsilon at the inlet as well.
How would I do this with groovyBC?
I apologize if this is a silly question.
Regards
Eugene Joubert
ecjoubert is offline   Reply With Quote
Old   March 24, 2009, 08:06
Assistant Moderator
Bernhard Gschaider
Hi!
I don't understand the problem. It seems like you already did the more complicated task (specify a vector value). Specifying epsilon (which is "only" a scalar) should be pretty straightforward: set the type of the BC to groovyBC at the inlet and specify an expression
Bernhard
Old   March 25, 2009, 04:46
Default epsilon profile for groovyBC
  #34
Eugene Joubert
Hi Bernhard
Thank you for the speedy reply.
Here is more detail:
I am attempting to implement a fully developed atmospheric boundary layer (ABL) for my simulation.
For the k-epsilon model a simplified ABL can be defined by three equations:
U(y) = (u*/K)ln((y + yo)/yo); velocity profile
k(y) = u*²/sqrt(Cmu); constant
epsilon(y) = u*³/K(y + yo); epsilon profile
So far I have implemented U(y) with groovyBC by modifying the pulsedPitzDaly inlet conditions for my simpleFoam case.
My inlet is defined as follows:
boundaryField
inlet
type groovyBC;
variables "zp=pts().z;zc=pos().z;minZ=toFace(min(zp));minZc= min(zc);Ustar=0.03;K=0.4;para=-(Ustar/K)*log((pos().z + minZc)/(minZc))*normal();";
valueExpression "para";
value uniform (0 0 0);
As I understand it, the "para" equation would be evaluated in groovyBC for the different vertices along the inlet boundary and then asssigned to that patch as a velocity inlet.
So my question is:
How could I change the inlet definition above to incorporate the epsilon equation as well?
Again I apologize if the answer is actually trivial.
Regards
Eugene
Old   March 31, 2009, 05:25
  #35
Eugene Joubert
Bernhard
Sorry for that. I obviously just have to define groovyBC with the equations in the epsilon and k initial field directories.
I notice that for my case both the velocity as well as epsilon profiles look fine all the way but have a noticeable increase for the upper most node. Do you have any idea why this may happen?
Thanks again for the great tool.
Eugene Joubert
Old   April 3, 2009, 00:36
Prapanch Nair
prapanj is on a distinguished road
Hi Suraj,
I was also trying to run the PitzDaily case with groovyBC and ran into the same problem as you. Could you tell me how to add the libgroovyBC.so to the run? Your help will be greatly appreciated.
Thank you
Prapanj
prapanj is offline   Reply With Quote
Old   April 3, 2009, 04:09
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Prapanj
You should add the following to your controlDict
libs ( "libgroovyBC.so" );
According to the wiki on groovy BC you might try with
libs ( "libOpenFOAM.so" "libgroovyBC.so" );
if you are experiencing problems with paraFoam.
Have a nice weekend,
Niels
ngj is offline   Reply With Quote
Old   May 21, 2009, 08:48
Luther Terblanche
luther is on a distinguished road
Hallo Bernard
My text in bold blue.
I have the same problem as Marco (I think). I am new to OpenFOAM, but this is what I did:
luther@luther-laptop:~/OpenFOAM/OpenFOAM-1.5/src$ svn checkout https://openfoam-extend.svn.sourcefo...aries/groovyBC
A groovyBC/PatchResult.C
A groovyBC/PatchValueExpressionLexer.ll
A groovyBC/groovyBCFvPatchFields.H
A groovyBC/PatchResult.H
A groovyBC/PatchValueExpressionDriverI.H
A groovyBC/PatchValueExpressionParser.yy
A groovyBC/groovyBCFvPatchField.C
A groovyBC/groovyBCPointPatchFields.C
A groovyBC/PatchResultI.H
A groovyBC/README
A groovyBC/groovyBCFvPatchField.H
A groovyBC/groovyBCPointPatchFields.H
A groovyBC/Demos
A groovyBC/Demos/circulatingSplash
A groovyBC/Demos/circulatingSplash/0
A groovyBC/Demos/circulatingSplash/0/gamma
A groovyBC/Demos/circulatingSplash/0/pd
A groovyBC/Demos/circulatingSplash/0/U
A groovyBC/Demos/circulatingSplash/system
A groovyBC/Demos/circulatingSplash/system/fvSchemes
A groovyBC/Demos/circulatingSplash/system/controlDict
A groovyBC/Demos/circulatingSplash/system/decomposeParDict
A groovyBC/Demos/circulatingSplash/system/fvSolution
A groovyBC/Demos/circulatingSplash/customRegexp
A groovyBC/Demos/circulatingSplash/constant
A groovyBC/Demos/circulatingSplash/constant/polyMesh
A groovyBC/Demos/circulatingSplash/constant/polyMesh/boundary
A groovyBC/Demos/circulatingSplash/constant/polyMesh/blockMeshDict
A groovyBC/Demos/circulatingSplash/constant/RASProperties
A groovyBC/Demos/circulatingSplash/constant/dynamicMeshDict
A groovyBC/Demos/circulatingSplash/constant/transportProperties
A groovyBC/Demos/circulatingSplash/constant/environmentalProperties
A groovyBC/Demos/movingConeDistorted
A groovyBC/Demos/movingConeDistorted/0
A groovyBC/Demos/movingConeDistorted/0/p
A groovyBC/Demos/movingConeDistorted/0/cellMotionUx
A groovyBC/Demos/movingConeDistorted/0/U
A groovyBC/Demos/movingConeDistorted/0/pointMotionUx
A groovyBC/Demos/movingConeDistorted/system
A groovyBC/Demos/movingConeDistorted/system/tetFemSolution
A groovyBC/Demos/movingConeDistorted/system/fvSchemes
A groovyBC/Demos/movingConeDistorted/system/controlDict
A groovyBC/Demos/movingConeDistorted/system/fvSolution
A groovyBC/Demos/movingConeDistorted/constant
A groovyBC/Demos/movingConeDistorted/constant/polyMesh
A groovyBC/Demos/movingConeDistorted/constant/polyMesh/boundary
A groovyBC/Demos/movingConeDistorted/constant/polyMesh/blockMeshDict
A groovyBC/Demos/movingConeDistorted/constant/dynamicMeshDict
A groovyBC/Demos/movingConeDistorted/constant/transportProperties
A groovyBC/Demos/pulsedPitzDaily
A groovyBC/Demos/pulsedPitzDaily/0
A groovyBC/Demos/pulsedPitzDaily/0/nuSgs
A groovyBC/Demos/pulsedPitzDaily/0/p
A groovyBC/Demos/pulsedPitzDaily/0/nuTilda
A groovyBC/Demos/pulsedPitzDaily/0/B
A groovyBC/Demos/pulsedPitzDaily/0/U
A groovyBC/Demos/pulsedPitzDaily/0/k
A groovyBC/Demos/pulsedPitzDaily/system
A groovyBC/Demos/pulsedPitzDaily/system/fvSchemes
A groovyBC/Demos/pulsedPitzDaily/system/controlDict
A groovyBC/Demos/pulsedPitzDaily/system/fvSolution
A groovyBC/Demos/pulsedPitzDaily/constant
A groovyBC/Demos/pulsedPitzDaily/constant/LESProperties
A groovyBC/Demos/pulsedPitzDaily/constant/polyMesh
A groovyBC/Demos/pulsedPitzDaily/constant/polyMesh/boundary
A groovyBC/Demos/pulsedPitzDaily/constant/polyMesh/blockMeshDict
A groovyBC/Demos/pulsedPitzDaily/constant/transportProperties
A groovyBC/Demos/runSplash.py
A groovyBC/Demos/wobbler
A groovyBC/Demos/wobbler/0
A groovyBC/Demos/wobbler/0/D
A groovyBC/Demos/wobbler/0/T
A groovyBC/Demos/wobbler/system
A groovyBC/Demos/wobbler/system/fvSchemes
A groovyBC/Demos/wobbler/system/controlDict
A groovyBC/Demos/wobbler/system/fvSolution
A groovyBC/Demos/wobbler/impulse.data
A groovyBC/Demos/wobbler/constant
A groovyBC/Demos/wobbler/constant/polyMesh
A groovyBC/Demos/wobbler/constant/polyMesh/boundary
A groovyBC/Demos/wobbler/constant/polyMesh/blockMeshDict
A groovyBC/Demos/wobbler/constant/mechanicalProperties
A groovyBC/Demos/wobbler/constant/thermalProperties
A groovyBC/PatchValueExpressionDriver.C
A groovyBC/groovyBCPointPatchField.C
A groovyBC/Make
A groovyBC/Make/mybison
A groovyBC/Make/files
A groovyBC/Make/myflex
A groovyBC/Make/options
A groovyBC/groovyBCFvPatchFields.C
A groovyBC/PatchValueExpressionDriver.H
A groovyBC/groovyBCPointPatchField.H
Checked out revision 1241.
luther@luther-laptop:~/OpenFOAM/OpenFOAM-1.5/src$ cd groovyBC
luther@luther-laptop:~/OpenFOAM/OpenFOAM-1.5/src/groovyBC$ wmake libso
wmakeLnInclude: linking include files to /home/luther/OpenFOAM/OpenFOAM-1.5/src/groovyBC/lnInclude
Making dependency list for source file PatchResult.C
Making dependency list for source file PatchValueExpressionParser.yy
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionParser.yy
Making dependency list for source file PatchValueExpressionLexer.ll
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionLexer.ll
Making dependency list for source file PatchValueExpressionDriver.C
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionDriver.C
Making dependency list for source file groovyBCFvPatchFields.C
could not open file PatchValueExpressionParser.tab.hh for source file groovyBCFvPatchFields.C
Making dependency list for source file groovyBCPointPatchFields.C
could not open file MixedPointPatchField.H for source file groovyBCPointPatchFields.C
could not open file PatchValueExpressionParser.tab.hh for source file groovyBCPointPatchFields.C
could not open file PointPatchFieldMapper.H for source file groovyBCPointPatchFields.C
SOURCE=PatchResult.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/luther/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/luther/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/luther/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/PatchResult.o
PatchResult.C: In member function ‘void Foam::PatchResult::uglyDelete()’:
PatchResult.C:97: warning: deleting ‘void*’ is undefined
SOURCE=PatchValueExpressionParser.yy ; rm -f Make/linuxGccDPOpt/PatchValueExpressionParser.C Make/linuxGccDPOpt/PatchValueExpressionParser.tab.hh; bison -ra -v -d $SOURCE ; mv *.tab.cc Make/linuxGccDPOpt/PatchValueExpressionParser.C ; mv *.tab.hh Make/linuxGccDPOpt/PatchValueExpressionParser.tab.hh ; mv *.hh Make/linuxGccDPOpt ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/luther/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/luther/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/luther/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c Make/linuxGccDPOpt/PatchValueExpressionParser.C -o Make/linuxGccDPOpt/PatchValueExpressionParser.o
bison: invalid option -- 'r'
Usage: bison [-dltvyVu] [-b file-prefix] [-p name-prefix]
[-o outfile] [-h headerfile]
[-S skeleton] [-H header-skeleton]
[--debug] [--defines] [--fixed-output-files] [--no-lines]
[--verbose] [--version] [--yacc] [--usage] [--help]
[--file-prefix=prefix] [--name-prefix=prefix]
[--skeleton=skeletonfile] [--headerskeleton=headerskeletonfile]
[--output=outfile] [--header-name=header] grammar-file
mv: cannot stat `*.tab.cc': No such file or directory
mv: cannot stat `*.tab.hh': No such file or directory
mv: cannot stat `*.hh': No such file or directory
g++: Make/linuxGccDPOpt/PatchValueExpressionParser.C: No such file or directory
g++: no input files
make: *** [Make/linuxGccDPOpt/PatchValueExpressionParser.o] Error 1
I have also remove the line "groovyBCPointPatchFields.C" from "Make/files" and ran "wmake libso" again but got pretty much the same thing. Shown below:
g++: no input files
Please can you see if you can help me?
Kind Regards
Luther
luther is offline   Reply With Quote
Old   May 21, 2009, 11:20
Assistant Moderator
Bernhard Gschaider
Hi Luther!
The problem lies in this part of the output:
g++: no input files
The utility bison complains about an option '-r' that it doesn't have. Probably because it is an old version. I've added a section http://openfoamwiki.net/index.php/Co...Pre-requisites that shows how to check for the version of bison.
There are two options:
  1. Install an up-to-date version of bison
  2. Go to Make/mybison and remove the option '-ra' from the call to bison there. It is not strictly necessary. This removes the symptom (and the generated report is only needed for debugging) but bison MAY fail for other reasons because it is ... old
Bernhard
Old   May 22, 2009, 04:41
Luther Terblanche
Originally Posted by gschaider View Post
Hi Luther!
Bernhard
Hallo Bernard,
Thank you for your response. I very much appreciate it. I have downloaded version 2.4.1 of bison on the page you recommended. I did a ./configure; make; make install;
However I still get the old version displayed when I type "bison -V". Don't know if it maybe have not installed correctly:
luther@luther-laptop:~/OpenFOAM/luther-1.5/run/groovyWaveTank$ bison -V
bison++ Version 1.21.9-1, adapted from GNU bison by coetmeur@icdc.fr
Maintained by Magnus Ekdahl <magnus@debian.org>
However, I then did a "wmake libso" again in the sources of groovyBC and some warnings came out, but at the end it said that groovyBC.so is up to date. I run a few of the Demos in the Demos directory and thay seemed to have worked whithout error.
But when I run interFoam on groovyWaveTank I got an error. Do you perhaps know how I can fix it? Sorry if the questions are trivial, but I am new to openFOAM and appreciate your help alot. Here is the error:
luther@luther-laptop:~/OpenFOAM/luther-1.5/run/groovyWaveTank$ interFoam
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
Exec : interFoam
Date : May 22 2009
Time : 10:18:57
Host : luther-laptop
PID : 19035
Case : /home/luther/OpenFOAM/luther-1.5/run/groovyWaveTank
nProcs : 1
Create time
Create mesh for time = 0
Reading environmentalProperties
Reading field pd
Reading field gamma
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Calculating field g.h
time step continuity errors : sum local = 0, global = 0, cumulative = 0
Attempt to return dictionary entry as a primitive
file: /home/luther/OpenFOAM/luther-1.5/run/groovyWaveTank/system/fvSolution:corr:reconditioner from line 23 to line 35.
From function ITstream& primitiveEntry::stream() const
in file db/dictionary/dictionaryEntry/dictionaryEntry.C at line 83.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/luther/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::IOerror::abort() in "/home/luther/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::dictionaryEntry::stream() const in "/home/luther/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#3 Foam::dictionary::lookup(Foam::word const&, bool) const in "/home/luther/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/luther/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#5 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/home/luther/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libfiniteVolume.so"
#6 main in "/home/luther/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/interFoam"
#7 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#8 Foam::regIOobject::readIfModified() in "/home/luther/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/interFoam"
Aborted
Kind Regards
Luther
Kind Regards
Luther
Thread Tools
Trackbacks are On
FunkySetFields for OF 141 mer OpenFOAM Pre-Processing 71 June 11, 2014 11:34
Running funkySetFields sara OpenFOAM Running, Solving & CFD 10 October 3, 2012 10:08
FunkySetFields dictionary gschaider OpenFOAM Running, Solving & CFD 14 December 3, 2008 22:13
FunkySetFields for cyclic bc zakifoam OpenFOAM Pre-Processing 1 December 18, 2007 08:24
