Home > Forums > OpenFOAM
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh
Like Tree6Likes
Old   June 14, 2010, 15:05
Ovie Doro
ovie is on a distinguished road
Originally Posted by gschaider View Post
I think the scripts make pretty clear what should be done. If you don't understand them (which is OK, your job is CFD) go to your sysadmin. If your sysadmin has a problem with them: get a new sysadmin
Bernhard
Thanks Bernhard, I would try this later today.
Regards.
ovie is offline   Reply With Quote
Old   June 14, 2010, 18:05
Ovie Doro
Getting an object-file from a bison/flex-grammar is a two-step process:
1. bison/flex translates the grammar into a .c and .h file
2. the c-compiler compiles those files
Usually an out of date bison produces in step 1 a C-file that doesn't compile in step 2.
In groovyBC and funkySetFields both steps are done by one rule.
So the idea is to compile groovyBC on machine A with a working bison. Then copy the generated C/H-files to machine B. Modify Make/files there to skip bison/flex and directly compile the C-files.
For an example have a look at the sources of funkySetFields. The script getGenerated.sh is basically what should be done on machine A (filenames are slightly different). Script insertGenerated.sh is what should be done on machine B.
Bernhard
Thanks. It worked just fine!
Ovie.
Old   June 15, 2010, 07:36
Assistant Moderator
Bernhard Gschaider
Ovie.
Great. As you said in that other posting
Please could you be more specific on how this can be done? Some of us dont just have a clue
You were speaking in first person plural: could I ask you to add a small description of the procedure to the Wiki-page of groovyBC for the benefit of the others. Obviously my descriptions seem not to be clear to everyone and who would be qualified better to explain to others than one who just did the transition from mystification to enlightenment
Bernhard
Old   June 15, 2010, 14:16
Ovie Doro
Bernhard
Bernhard,
I just did!
I hope my very puny addition would provide some relief to many struggling "others" like myself. The "others" here represents the "us" in my previous comment.
In any case, many thanks to you for this truly important addition to OpenFOAM.
Regards
Old   June 16, 2010, 05:17
Assistant Moderator
Bernhard Gschaider
I just did!
Great. Involvment with OpenSource always starts with "puny additions"
Old   August 4, 2010, 10:30
Daniele
Daniele111 is on a distinguished road
Hi
Is possible use groovyBc to impose a log velocity bundary condition on a surface? I already used it I imposed a log profile along a linlet line in a 2D case. In a 3D case what is the correct syntax? I found that the error source is U inlet boundary condtion, I would impose a log profile on inlet patch:
inlet
type groovyBC;
variables "yc=pos().y;minYc= min(yc);Ustar=0.612;kappa=0.41;para=-(Ustar/kappa)*log((pos().y + 0.001)/(0.001))*normal();";
valueExpression "para";
//type fixedValue;
//value uniform (10 0 0);
Where is my error?
I have this error (initial condition aren't 0):
#0 Foam::errorrintStack(Foam::Ostream&) in "/home/acconcia/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/acconcia/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 log in "/lib/tls/i686/cmov/libm.so.6"
#4 Foam::log(Foam::Field<double>&, Foam::UList<double> const&) in "/home/acconcia/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so"
#5 Foam::log(Foam::UList<double> const&) in "/home/acconcia/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so"
#6 pve::PatchValueExpressionParserarse() at PatchValueExpressionParser.C:0
#7 Foam::PatchValueExpressionDriverarse(std::string const&) in "/home/acconcia/OpenFOAM/acconcia-1.6.x/lib/linuxGccDPOpt/libgroovyBC.so"
#8 Foam::PatchValueExpressionDriver::evaluateVariable (Foam::word const&, Foam::string const&) in "/home/acconcia/OpenFOAM/acconcia-1.6.x/lib/linuxGccDPOpt/libgroovyBC.so"
#9 Foam::PatchValueExpressionDriver::addVariables(Foa m::string const&, bool) in "/home/acconcia/OpenFOAM/acconcia-1.6.x/lib/linuxGccDPOpt/libgroovyBC.so"
#10 Foam::groovyBCFvPatchField<Foam::Vector<double> >::updateCoeffs() in "/home/acconcia/OpenFOAM/acconcia-1.6.x/lib/linuxGccDPOpt/libgroovyBC.so"
#11 Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensionSet const&) in "/home/acconcia/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libfiniteVolume.so"
#12 Foam::fv::gaussLaplacianScheme<Foam::Vector<double >, double>::fvmLaplacianUncorrected(Foam::GeometricFi eld<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) in "/home/acconcia/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libfiniteVolume.so"
#13 Foam::fv::gaussLaplacianScheme<Foam::Vector<double >, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) in "/home/acconcia/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libfiniteVolume.so"
#14 Foam::fv::laplacianScheme<Foam::Vector<double>, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) in "/home/acconcia/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libfiniteVolume.so"
#15 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) in "/home/acconcia/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libincompressibleRASModels.so"
#16 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) in "/home/acconcia/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libincompressibleRASModels.so"
#17 Foam::incompressible::RASModels::kEpsilon::divDevR eff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const in "/home/acconcia/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libincompressibleRASModels.so"
#18
in "/home/acconcia/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/simpleFoam"
#19 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#20
Thanks
Daniele111 is offline   Reply With Quote
Old   August 4, 2010, 13:55
Philippose Rajan
philippose will become famous soon enough
Hello Bernhard,
A good evening to you :-)!
A few quick questions....
1. Can GroovyBC be used in parallel simulations?
2. If yes, do I need to do something specific when using the new functionality of calculating values on a remote patch in cases where the mesh is split up into pieces in which the remote patch may be on another processor?
I was running a simulation yesterday, and it worked fine in the serial mode, but in the parallel mode, it kept throwing up warnings that the "min" and "max" functions where returning zeros, and that the average would be used (the warning regarding the average comes from the file: "PatchResultI.H", function "GetUniformInternal".
Though the simulation seems to be running, I dont know whether these warnings should be considered as important, and whether the simulation result would be compromised.
Just out of curiosity, I found the command "preservePatches" in the decomposeParDict file, but that did not help either.
Have a great day ahead!
Philippose
philippose is offline   Reply With Quote
Old   August 5, 2010, 04:53
Assistant Moderator
Bernhard Gschaider
Originally Posted by philippose View Post
Hello Bernhard,
Yep
Philippose
Which version of OF are you using. The behaviour that you describe comes from the Field-class. In some versions it tells us that it has a length zero. This can be the case if the patch in question has no faces on one processor. I thought I worked around that, but am not sure. If I find a Bug-report in Mantis I'll have a look
Bernhard
Old   August 5, 2010, 05:05
Philippose Rajan
Hello again Bernhard,
Thank you for your reply :-)!
Yes, I too noticed that the warning was coming from the field related classes, but since the warnings only popped up in combination with groovyBC I thought it would be something with the way groovyBC was implemented.
The warnings were issued when using the following OpenFOAM version:
OpenFOAM-1.5-dev SVN Ver. 1797 - Compiled on a Fedora 10 64-bit system
I shall post a Mantis Bug-report once I get back home this evening.
Do you think it might be useful to try it on another SVN Version? I looked through the SVN log, and I did not see any commit comments between 1797 and the current version which pointed towards this topic.
Have a nice day (though we have continuous drizzle and a grey sky here!)
Philippose
Old   August 5, 2010, 06:53
Daniele
No idea?
Old   August 6, 2010, 05:54
Assistant Moderator
Bernhard Gschaider
Originally Posted by Daniele111 View Post
No idea?
This is a busy thread. Please attach a reference to the original question.
Had a quick glance at your last question. Propable causes are:
- kappa is zero somewhere (division by zero)
- y is negative (log doesn't like this)
Old   August 6, 2010, 07:51
Assistant Moderator
Bernhard Gschaider
Philippose
Further communication concerning this problem has moved to http://sourceforge.net/apps/mantisbt...view.php?id=15 (for whoever is interested)
Old   September 7, 2010, 08:20
Antonio Liggieri
alfa_8C is an unknown quantity at this point
Hello Bernhard,
I'm trying to install/compile groovyBC - up to now unfortunately not very successful.
This is the error that I get if I type wmake libso in the groovyBC dir:
/bin/sh: bison: not found
mv: cannot stat '*.tab.cc': No such file or directory
mv: cannot stat '*.tab.hh': No such file or directory
mv: cannot stat '*..hh': No such file or directory
g++:Make/linuxGccDPopt/PatchValueExpressionParser.C: No such file or directory
g++: no input files
make: *** [Make/linuxGccDPopt/PatchValueExpressionParser.o] Error 1
Do you have any idea what the problem could be??
Thanx a lot in advance,
Tony
alfa_8C is offline   Reply With Quote
Old   September 7, 2010, 08:37
Assistant Moderator
Bernhard Gschaider
Originally Posted by alfa_8C View Post
Hello Bernhard,
g++: no input files
Tony
The problem is
You'll have to install bison (and flex while you're at it, but they usually come in pairs). Shouldn't be too hard to find in the package-manager of your distro
Bernhard
Old   September 7, 2010, 13:06
Antonio Liggieri
Hello Bernhard,
thanx a lot for your reply. I tried to install bison, but I still get an error message:
poyry@poyry:~$ sudo apt-get install bison
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package bison is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package bison has no installation candidate
poyry@poyry:~$
Even if this is not related to your contribution, you might have had the same problem in the past and know a solution,
Best Regards and a good evening,
Tony
By the way - I downloaded and installed/compiled pyFoam and up to now, I've just tried the pyFoamPlotWatcher so far, it works great!!!! Thanx!
Old   September 8, 2010, 04:17
Assistant Moderator
Bernhard Gschaider
Hello Bernhard,
poyry@poyry:~$
Sorry. That sounds like a Debian/Ubunu-problem and I'm from the other faction (RedHat). Anyway. Last time I did something on an Ubuntu-machine when I tried to execute an uninstalled command on the shell said something like "I do not know the bison you're talking about, but the command 'apt-blabla blub' might instll it for you" (maybe they're naming the package differently)
Old   September 8, 2010, 04:59
Antonio Liggieri
I could solve the problem now thank you - No offence :-)
If anybody has the same problem: just download the bison package maually and install it manually as well. You can download it dirctly from the ubuntu page. Once downloaded, follow the instructions on the "Install" and "README" file being within the downloaded package and that's it..
Enjoy!
Old   September 9, 2010, 09:26
Default groovyBC - Accessing fields from other patches
  #158
Antonio Liggieri
Hello again Bernhard & everybody,
In my sim. I need to set a function P=f(Q) as a pressure BC, where P is the pressure and Q is the volumetric flow rate at the same patch.
As far as I could make out it seems not to be possible to use for instance the massFlowFunctionObject as the "producer" of the Q that I need in my function right? groovyBC does not support this type of variable like:
Example:
outlet1
type groovyBC;
valueExpression "f(Q_outlet1)";
variables "Q_outlet@outlet1=vals(massFlowFunctionObject)"
value uniform 100010;
Assumed: NO IT'S NOT POSSIBLE
Approach:
1)Generate pressure values with massFlowFunctionObject, by implementing the function P=f(Q) into the massFlowFunctionObject, which will be then written into a text file (does it anyway).
2)Using a timeVaryingUniformFixedValueBC, which then accesses after each iteration to the new pressure value written into the text file.
Hurdle do you know any BC very similar to the timeVaryingUniformFixedValueBC, which accesses after every iteration to an updated text file instead of an "predefined" one?
If not, do you think it's a big deal to modify the
timeVaryingUniformFixedValueBC in order to fulfill this criterion?
Thanx in advance to everybody!
Tony
Old   September 10, 2010, 04:45
Antonio Liggieri
problem solved - sorry for the inconvenience!
Tony
Old   September 10, 2010, 05:59
Antonio Liggieri
...problem is solved... sorry for the inconvenience...
Tony
Thread Tools
Trackbacks are On
FunkySetFields for OF 141 mer OpenFOAM Pre-Processing 71 June 11, 2014 11:34
Running funkySetFields sara OpenFOAM Running, Solving & CFD 10 October 3, 2012 10:08
FunkySetFields dictionary gschaider OpenFOAM Running, Solving & CFD 14 December 3, 2008 22:13
FunkySetFields for cyclic bc zakifoam OpenFOAM Pre-Processing 1 December 18, 2007 08:24
