OpenFOAM 15 and openSUSE 111 paraview works OK
Old   December 23, 2008, 12:34
Default Hello, I have just installe
Alberto Passalacqua
I have just installed the latest release of openSUSE 11.1 on my laptop, and I tried OpenFOAM on it to check if it works properly.
Well, good news! Of course the applications work OK, but also the third party paraview and the provided reader paraview work OK without any need to recompile with a personalized version of Qt, as you can see from the screenshot below, which shows the grid of the icoFoam/cavity case.
Merry Christmas and happy 2009!
Regards,
Alberto
Alberto Passalacqua
Old   December 26, 2008, 13:28
Default Alberto! This is a wonderful
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
Alberto!
This is a wonderful news, I'll update soon my Suse!!!
ivan_cozza is offline   Reply With Quote
Old   December 26, 2008, 19:42
Default Hi Ivan, I need to correct th
Alberto Passalacqua
Hi Ivan,
I need to correct the news, which stays good, but a bit more complicated.
All worked OK in my installation because I didn't format my /home directory, and I kept the previous version of OpenFOAM I had. In that installation, paraview and paraFoam were recompiled against QT 4.4, which is also used in openSUSE 11.1.
I upgraded my desktop system too, and there I had to format my /home. When I reinstalled OpenFOAM 1.5 from the git repository and added the third party package, I found out that paraview could not start, with an error about being unable to create objects. At this point I recompiled paraview against the Qt libraries provided with openSUSE 11.1, and...tada! It works!
So, to conclude, I'm sorry for the mistake in the information provided above, but well, I can provide a surely working solution, because I tried it on a fully clean 64-bit installation.
- Install OpenSUSE 11.1
- Install qt4-devel (it's in the OSS openSUSE repository)
- Download OpenFOAM 1.5 from git repository
- Download the third-party packages from OpenCFD site
- Source the bash configuration file for OpenFOAM, as usual.
- Edit ~/OpenFOAM/ThirdParty/ParaView3.3-cvsCMakeLists.txt and comment out the line:
MESSAGE(SEND_ERROR "Qt ${QTVERSION} not supported. Please use Qt 4.3 (you may need to clean your dirtied cache).")
- Compile paraview as explained in OpenFOAM 1.5 README file.
- Compile OpenFOAM 1.5 with ./Allwmake in its main directory.
If you have problems, please let me know.
Enjoy :-D
Alberto
Alberto Passalacqua
Old   December 27, 2008, 10:15
Default Ok Alberto, now I have my hom
Ivan Flaminio Cozza
Ok Alberto,
now I have my homeworks for these holydays!
I wish you a Happy New Year!
Ivan
Old   December 27, 2008, 12:09
Default Thanks. Happy 2009 to you too,
Alberto Passalacqua
Thanks. Happy 2009 to you too, and to everyone!
Alberto
Alberto Passalacqua
Old   February 22, 2009, 07:04
Default Hia, Im trying to make this in
Erik Arlemark
Erik is on a distinguished road
Hia, Im trying to make this installation on Suse 11.1 as well.
Does the above mean that I can use the gcc provided with suse 11.1, or do I still have to change to 4.3.1?
Thanks
Erik
Erik is offline   Reply With Quote
Old   February 22, 2009, 07:10
Erik Arlemark
Thanks
Erik
Old   February 22, 2009, 17:50
Default Hi Erik, yes, it also works w
Alberto Passalacqua
Hi Erik,
yes, it also works with the system compiler. That's right.
Just change name to the gcc compiler directory in the ThirdParty OF folder.
Alberto
Alberto Passalacqua
Old   February 24, 2009, 11:23
Default Hi Alberto, Thanks for your
Erik Arlemark
Hi Alberto,
Thanks for your advice.
Im having problems compiling the OpenFOAM reader, following these lines of the README:
" The PV3FoamReader module is an OpenFOAM utility that can be compiled in the
usual manner as follows:
+ cd $FOAM_UTILITIES/postProcessing/graphics/PV3FoamReader
+ ./Allwclean
+ ./Allwmake"
i get this pring out while compiling:
///begining pring-out
erik@linux-vcw2:~/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphics/PV3Foa mReader> ./Allwclean
+ rm -rf PV3FoamReader/Make
+ wclean libso vtkPV3Foam
wclean vtkPV3Foam
erik@linux-vcw2:~/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphics/PV3Foa mReader> ./Allwmake
+ '[' -d /home/erik/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc -a -r /home/erik/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc ']'
+ case "$ParaView_VERSION" in
+ wmake libso vtkPV3Foam
wmakeLnInclude: linking include files to /home/erik/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphic s/PV3FoamReader/vtkPV3Foam/lnInclude
/bin/sh: /home/erik/OpenFOAM/OpenFOAM-1.5.x/wmake/rules/linux64Gcc/wmkdep: No such file or directory
SOURCE=vtkPV3Foam.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/erik/OpenFOAM/OpenFOAM-1.5.x/src/finiteVolume/lnInclude -I/home/erik/OpenFOAM/OpenFOAM-1.5.x/src/lagrangian/basic/lnInclude -I/home/erik/OpenFOAM/OpenFOAM-1.5.x/src/meshTools/lnInclude -I/home/erik/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/VTK -I/home/erik/OpenFOAM/ThirdParty/ParaView3.3-cvs -I/home/erik/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK -I/home/erik/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common -I/home/erik/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering -I/home/erik/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering -I../PV3FoamReader -IlnInclude -I. -I/home/erik/OpenFOAM/OpenFOAM-1.5.x/src/OpenFOAM/lnInclude -I/home/erik/OpenFOAM/OpenFOAM-1.5.x/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/vtkPV3Foam.o
In file included from vtkPV3Foam.C:27:
vtkPV3Foam.H:61:23: error: className.H: No such file or directory
vtkPV3Foam.H:62:22: error: fileName.H: No such file or directory
vtkPV3Foam.H:63:35: error: volPointInterpolation.H: No such file or directory
vtkPV3Foam.H:64:24: error: stringList.H: No such file or directory
vtkPV3Foam.H:65:22: error: wordList.H: No such file or directory
vtkPV3Foam.H:66:28: error: primitivePatch.H: No such file or directory
vtkPV3Foam.C:30:18: error: Time.H: No such file or directory
vtkPV3Foam.C:31:20: error: fvMesh.H: No such file or directory
vtkPV3Foam.C:32:26: error: IOobjectList.H: No such file or directory
vtkPV3Foam.C:33:24: error: patchZones.H: No such file or directory
In file included from /home/erik/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64 -unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/backward/strstream:51,
from /home/erik/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIOStream.h:112,
from /home/erik/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkSystemIncludes.h:40 ,
from /home/erik/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkIndent.h:24,
from /home/erik/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObjectBase.h:43,
from /home/erik/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Common/vtkObject.h:41,
from /home/erik/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkAlgorithm.h:32,
from /home/erik/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Filtering/vtkMultiBlockDataSe tAlgorithm.h:25,
from ../PV3FoamReader/vtkPV3FoamReader.h:24,
from vtkPV3Foam.C:34:
/home/erik/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64 -unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/backward/backward_warning .h:32:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated.
vtkPV3Foam.C:35:22: error: IFstream.H: No such file or directory
In file included from vtkPV3Foam.C:56:
vtkPV3FoamAddToSelection.H:31:26: error: SortableList.H: No such file or directory
vtkPV3Foam.H:200: error: ISO C++ forbids declaration of 'autoPtr' with no type
vtkPV3Foam.H:200: error: expected ';' before '<' token
vtkPV3Foam.H:218: error: 'boolList' does not name a type
vtkPV3Foam.H:221: error: 'labelList' does not name a type
vtkPV3Foam.H:225: error: 'labelList' does not name a type
vtkPV3Foam.H:229: error: 'labelList' does not name a type
vtkPV3Foam.H:233: error: 'labelList' was not declared in this scope
vtkPV3Foam.H:233: error: template argument 1 is invalid
vtkPV3Foam.H:237: error: 'labelList' was not declared in this scope
vtkPV3Foam.H:237: error: template argument 1 is invalid
vtkPV3Foam.H:240: error: field 'patchTextActorsPtrs_' has incomplete type
vtkPV3Foam.H:251: error: 'word' does not name a type
vtkPV3Foam.H:271: error: expected ',' or '...' before 'datasetNo'
vtkPV3Foam.H:274: error: ISO C++ forbids declaration of 'label' with no type
vtkPV3Foam.H:282: error: expected ',' or '...' before 'datasetNo'
vtkPV3Foam.H:283: error: ISO C++ forbids declaration of 'label' with no type
vtkPV3Foam.H:287: error: 'label' does not name a type
vtkPV3Foam.H:314: error: 'wordList' does not name a type
vtkPV3Foam.H:321: error: expected constructor, destructor, or type conversion before 'addToSelection'
vtkPV3Foam.H:391: error: 'labelList' has not been declared
vtkPV3Foam.H:412: error: expected ',' or '...' before '&' token
vtkPV3Foam.H:414: error: ISO C++ forbids declaration of 'labelList' with no type
vtkPV3Foam.H:420: error: expected ',' or '...' before '&' token
vtkPV3Foam.H:422: error: ISO C++ forbids declaration of 'labelList' with no type
vtkPV3Foam.H:451: error: expected constructor, destructor, or type conversion before 'addObjectsToSelection'
vtkPV3Foam.H:466: error: expected ',' or '...' before '&' token
vtkPV3Foam.H:471: error: ISO C++ forbids declaration of 'volPointInterpolation' with no type
vtkPV3Foam.H:477: error: expected ',' or '...' before '<' token
vtkPV3Foam.H:482: error: ISO C++ forbids declaration of 'GeometricField' with no type
vtkPV3Foam.H:488: error: expected ',' or '...' before '&' token
vtkPV3Foam.H:493: error: ISO C++ forbids declaration of 'word' with no type
vtkPV3Foam.H:499: error: expected ',' or '...' before '<' token
vtkPV3Foam.H:505: error: ISO C++ forbids declaration of 'GeometricField' with no type
vtkPV3Foam.H:511: error: expected ',' or '...' before '<' token
vtkPV3Foam.H:517: error: ISO C++ forbids declaration of 'GeometricField' with no type
vtkPV3Foam.H:517: error: 'template<class> void Foam::vtkPV3Foam::convertFaceField(int)' cannot be overloaded
vtkPV3Foam.H:505: error: with 'template<class> void Foam::vtkPV3Foam::convertFaceField(int)'
vtkPV3Foam.H:536: error: expected ',' or '...' before 'datasetNo'
vtkPV3Foam.H:537: error: ISO C++ forbids declaration of 'label' with no type
vtkPV3Foam.H:553: error: expected ',' or '...' before '<' token
vtkPV3Foam.H:558: error: ISO C++ forbids declaration of 'GeometricField' with no type
vtkPV3Foam.H:564: error: expected ',' or '...' before '&' token
vtkPV3Foam.H:569: error: ISO C++ forbids declaration of 'word' with no type
vtkPV3Foam.H:575: error: 'word' does not name a type
vtkPV3Foam.H:578: error: 'stringList' does not name a type
vtkPV3Foam.H:585: error: 'stringList' does not name a type
vtkPV3Foam.H:596: error: expected ',' or '...' before '&' token
vtkPV3Foam.H:597: error: ISO C++ forbids declaration of 'stringList' with no type
vtkPV3Foam.H:611: error: expected identifier before string constant
vtkPV3Foam.H:611: error: expected ',' or '...' before string constant
vtkPV3Foam.H:611: error: ISO C++ forbids declaration of 'ClassName' with no type
vtkPV3Foam.H:654: error: 'ostream' has not been declared
In file included from vtkPV3Foam.H:668,
/////......cut out of print out.......
/home/erik/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphic s/PV3FoamReader/PV3FoamReader/../vtkPV3Foam/vtkPV3Foam.H:611: error: ISO C++ forbids declaration of 'ClassName' with no type
In file included from /home/erik/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphic s/PV3FoamReader/PV3FoamReader/../vtkPV3Foam/vtkPV3Foam.H:668,
from /home/erik/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphic s/PV3FoamReader/PV3FoamReader/vtkPV3FoamReader.cxx:34:
/home/erik/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphic s/PV3FoamReader/PV3FoamReader/../vtkPV3Foam/vtkPV3FoamI.H:31: error: 'word' in namespace 'Foam' does not name a type
/home/erik/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphic s/PV3FoamReader/PV3FoamReader/vtkPV3FoamReader.cxx: In member function 'virtual int vtkPV3FoamReader::RequestInformation(vtkInformatio n*, vtkInformationVector**, vtkInformationVector*)':
/home/erik/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphic s/PV3FoamReader/PV3FoamReader/vtkPV3FoamReader.cxx:141: error: 'debug' is not a member of 'Foam::vtkPV3Foam'
/home/erik/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphic s/PV3FoamReader/PV3FoamReader/vtkPV3FoamReader.cxx:162: error: 'debug' is not a member of 'Foam::vtkPV3Foam'
/home/erik/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphic s/PV3FoamReader/PV3FoamReader/vtkPV3FoamReader.cxx:191: error: 'debug' is not a member of 'Foam::vtkPV3Foam'
/home/erik/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphic s/PV3FoamReader/PV3FoamReader/vtkPV3FoamReader.cxx: In member function 'virtual int vtkPV3FoamReader::RequestData(vtkInformation*, vtkInformationVector**, vtkInformationVector*)':
/home/erik/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphic s/PV3FoamReader/PV3FoamReader/vtkPV3FoamReader.cxx:232: error: 'debug' is not a member of 'Foam::vtkPV3Foam'
/home/erik/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphic s/PV3FoamReader/PV3FoamReader/vtkPV3FoamReader.cxx:250: error: 'debug' is not a member of 'Foam::vtkPV3Foam'
/home/erik/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphic s/PV3FoamReader/PV3FoamReader/vtkPV3FoamReader.cxx:292: error: 'debug' is not a member of 'Foam::vtkPV3Foam'
make[2]: *** [CMakeFiles/PV3FoamReader_SM.dir/vtkPV3FoamReader.o] Error 1
make[1]: *** [CMakeFiles/PV3FoamReader_SM.dir/all] Error 2
make: *** [all] Error 2
//////////end
Is it possilbe from this to say where my proceedure is wrong? I see In the print out of the reader compilation that there are a lot of files missing.
Many thanks
Erik
Old   February 25, 2009, 05:49
Default And also, Im running on a 64-b
Erik Arlemark
And also, Im running on a 64-bit machine and I have the following message from the foamInstallationTest:
Executing /home/erik/OpenFOAM/OpenFOAM-1.5.x/bin/foamInstallationTest:
Checking basic setup...
Shell: bash
Host: linux-vcw2
OS: Linux version 2.6.27.7-9-default
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/erik/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/erik/OpenFOAM/erik-1.5.x yes no
$WM_THIRD_PARTY_DIR /home/erik/OpenFOAM/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/erik/OpenFOAM/OpenFOAM-1.5.x yes yes yes
$FOAM_APPBIN ...5.x/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_USER_APPBIN ...5.x/applications/bin/linux64GccDPOpt yes yes no
$WM_DIR /home/erik/OpenFOAM/OpenFOAM-1.5.x/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...M/OpenFOAM-1.5.x/lib/linux64GccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...nFOAM/erik-1.5.x/lib/linux64GccDPOpt yes yes no
$MPI_ARCH_PATH ...nmpi-1.2.6/platforms/linux64GccDPOpt yes yes yes
Third party software
Software Version Location
gcc 4.3.1 ...penFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc
gzip 1.3.12 /usr/bin/gzip
tar 1.20 /bin/tar
icoFoam
WARNING: Conflicting installations:
OpenFOAM settings : /home/erik/OpenFOAM/OpenFOAM-1.5.x/applications/bin/linux64GccDPOpt/icoFoam
current path :
CRITICAL ERROR
Checking networking...
Action Result Crit
Pinging_linux-vcw2 Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the OpenFOAM enviroment.
Base configuration ok.
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
where Im not sure about what the conflicting installation of icoFoam means:
icoFoam
current path :
CRITICAL ERROR
Any advise is very appreciated!
/Erik
Old   March 6, 2009, 05:52
Default Thanks for your tips. I finall
  #11
Erik Arlemark
Thanks for your tips. I finally chose to use the OpenFOAM 1.5 version and not 1.5.x from the git repository. Then, I transformed the data with the <foamtovtk> command followed by <paraview>. start command. Which works fine for my cases.
OpenFOAM 15 with ParaView 340 on OpenSuSE 110 zairja OpenFOAM Installation 7 February 10, 2009 08:31
Paraview problem on OpenSuse gizmo OpenFOAM Installation 13 December 14, 2008 03:09
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit coompressor OpenFOAM Installation 0 November 12, 2008 19:53
Installing OpenFOAM without Paraview quartzian OpenFOAM Installation 0 September 8, 2008 09:29
Understanding how openfoam works Billy (Billy) OpenFOAM Running, Solving & CFD 1 February 8, 2005 06:41
