I am trying to simulate a comp
I am trying to simulate a complex system. For some elements of the system I can use lump approach and it is good enough. However, for some elements I need to use simple CFD calculations.
I use Dymola in windows environment. Is it possible to build a model in OF and call it in windows environment. For example create a DLL or extract code and compile under windows. Thank you in advance |
It is possible to (cross) comp
It is possible to (cross) compile OpenFOAM for Windows, but not easy. For details try: http://www.symscape.com/openfoam-1-5-x-on-windows
For an associated discussion try: http://www.cfd-online.com/OpenFOAM_D...tml?1233360483 Hope this helps. |
