Home > Forums > OpenFOAM
Help linking icoFoam and ODE solvers
Old   October 18, 2007, 06:13
Default Hi, What would be the best
Senthil Kabilan
skabilan is on a distinguished road
What would be the best way to link icoFoam and a ODE solver? Basically what i want is: the ODE solver solves a set of equations and supplies the pressure at the outlets to icoFoam. Which then computes on the mesh. This should repeat after every time step (transient simulation).
Thanks in advance for all your help!
Warm Regards,
Senthil
skabilan is offline   Reply With Quote
Old   February 19, 2008, 17:48
Default Hi, did you manage to do that?
Bernardo D Flores
david_flo1 is on a distinguished road
I am looking the same problem here. Got any suggestions?
Cheers
david_flo1 is offline   Reply With Quote
Old   February 23, 2008, 01:24
Default Hi, I was able to integrate
Senthil Kabilan
I was able to integrate the ODE solver in OF with icoFoam. Take a look at the /OpenFOAM-1.4.1/applications/test/ODETest. You can use the same driver with your ODE set to solve the equations.
Senthil
Old   February 25, 2008, 13:15
Default Forgive my persistence but alt
Bernardo D Flores
Forgive my persistence but although after checking the ODE I kinda understand how it works, how to use available specific ODE solvers, yet it is not clear to me how to use its results for input on each time step on a FOAM fv solver.
I am a FOAM newbbie here, any more specific details, please, or an example if you don't mind.
Regards
Old   February 25, 2008, 14:02
Default Hi Bernardo, Take a look at
Senthil Kabilan
Hi Bernardo,
Take a look at the timeVaryingUniformFixedValue patch in the directory /OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/fields/fvPatchFields/derived/
This patch is used for transient simulation.The patch reads the pressure value from a file (user specified) after every time step. You can insert the ODE solver in the patch and can supply the outlet condition to OF after every time step.
Senthil
Old   February 26, 2008, 11:18
Default Ok, I'll try it then. Maybe bo
Bernardo D Flores
Ok, I'll try it then. Maybe bother you later along the way with some other question :D
thanks Senthil
Bernardo
Old   January 6, 2009, 06:33
Default Hello All, A new question,
Mark Couwenberg
markc is on a distinguished road
Hello All,
A new question, basically a C++ question, with respect to implementing a ode solver. Starting from ODETest.C the following question:
the derivatives are given in the member function derivatives, which is inherited from ODE.H.
In ODETest the DE's are like:
dydx[0] = -y[1];
dydx[1] = y[0] - (1.0/x)*y[1];
dydx[2] = y[1] - (2.0/x)*y[2];
dydx[3] = y[2] - (3.0/x)*y[3];
But now I want to add some extra parameters which are constants in the DE's. E.g. the above may look like:
dydx[1] = y[0] - (constant_1 / x)*y[1];
(just an example).
However I am not able to bring in constants like this because the ODETest class is inherited from ODE.H and there those variables are not declared.
A possible workaround is to put the constants in the y vector and threat some components of the y vector as constants. However I do not think this is a nice way.
Any hints how to perform this task? I am currently studying C++ but any help about this question would be appreciated.
Thanks in advance,
Mark
markc is offline   Reply With Quote
Thread Tools
Trackbacks are On
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
linking several faces Christian F. FLUENT 1 June 6, 2008 06:29
Linking two meshes Geoffroy Chaussonnet FLUENT 3 April 6, 2007 04:59
Linking fortran and c vasanth Main CFD Forum 3 January 29, 2005 13:38
linking the script Mavinakere FLUENT 0 September 12, 2002 11:57
