OpenFOAM 1.7 - openSUSE 11.3 - gcc 4.5.0
Old   June 27, 2010, 00:54
Default OpenFOAM 1.7 - openSUSE 11.3 - gcc 4.5.0
Alberto Passalacqua
I've been trying to compile OpenFOAM 1.7 on openSUSE 11.3 - 64 bit (RC1, since the stable is not out yet) for testing purposes. This distributions comes with gcc 4.5.0.
The compile process fails always due to the same error:
linux64GccDPOpt/options:6: *** Missing separator. Stop.
wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created
OpenFOAM 1.7 compiles without problems on openSUSE 11.2.
Any suggestion or similar experience?
Thanks
Alberto Passalacqua
Old   June 27, 2010, 02:16
Martin
MartinB will become famous soon enough
Hi Alberto,
although I only compiled OpenFOAM 1.6.x on OpenSUSE 11.3RC, I think it's the same solution here:
One has to add a parameter "-P" to the g++ compiler. I have done this by editing the "~/OpenFOAM/OpenFOAM-1.6.x/wmake/rules/linux64Gcc/general" file, I think. The GFLAGS settings become:
GFLAGS = -D$(WM_ARCH) -DWM_$(WM_PRECISION_OPTION) -P
Well, I had to remove the OpenSUSE 11.3RC again because of trouble with the graphics driver.
Martin
MartinB is offline   Reply With Quote
Old   June 27, 2010, 02:28
Alberto Passalacqua
Thanks, I'll try and let you know.
What driver problem? I just fixed one (which will be corrected in the final release too).
Alberto Passalacqua
Old   June 27, 2010, 02:41
Martin
About the driver problem: I were not able to install the proprietary NVIDIA driver, and the open nouveou driver was too slow and too buggy to display anything useful in Paraview.
More hints about a solution can be found here:
http://forums.opensuse.org/get-help-...ia-driver.html
But I were running out of time to get it done... and OpenSUSE 11.2 works fine...
Martin
Old   June 27, 2010, 03:10
Alberto Passalacqua
Your solution works perfectly. Thank you.
Just a clarification: the -P option has to be added to
~/OpenFOAM/OpenFOAM-1.7.0/wmake/rules/General/general
About the nVidia driver, yes, in my case adding "nomodeset" to grub (permanently in /boot/grub/menu.lst at the end of the kernel line) fixed the problem, and I had the weekend to work on it :-)
I'm testing 11.3 because of some nice hardware support feature it has and for the updated KDE, and with your help, also OpenFOAM works on it :-)
Alberto Passalacqua
Old   June 28, 2010, 03:19
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
I would say this is a bug and needs to be fixed, this problem has been around for a while.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   June 28, 2010, 03:30
Alberto Passalacqua
Technically we are talking about unsupported platforms, but yes, I agree. I'll report it in the bug forum.
Alberto Passalacqua
Old   June 28, 2010, 11:17
Mattijs Janssens
mattijs is on a distinguished road
We've added -traditional-cpp to the cpp rules for all linux platforms. If you re-get the packs it should be in there. Please let us know if it doesn't work.
Thanks,
Mattijs
mattijs is offline   Reply With Quote
Old   June 28, 2010, 12:37
Alberto Passalacqua
It fixes the problem on openSUSE 11.3 RC1.
Thanks.
Alberto Passalacqua
Old   June 29, 2010, 06:20
Cheers, the installation runs smoothly on Fedora 12 and 13.
Old   July 28, 2010, 06:14
Default -P option
  #11
Jacques
jackpap is on a distinguished road
What is this -P option for. Do you think it would disrupt compilation with other versions of gcc ? Is there not a way of putting this option in the linux64gcc folder?
jackpap is offline   Reply With Quote
Old   July 28, 2010, 06:41
Mattijs Janssens
The -P option should have the same effect as the -traditional-cpp flag.
Old   July 28, 2010, 11:59
Alberto Passalacqua
Hi, you do not -P anymore, since the compile options have been modified in OF 1.7.x and made available via the git repository.
Best,
Alberto Passalacqua
Openfoam installation on OpenSuse 11.1 Bufacchi OpenFOAM Installation 1 June 15, 2010 19:55
OpenFOAM Live USB based on openSUSE 11.1 created with SUSE Studio alberto OpenFOAM 40 May 23, 2010 16:15
Critical errors during OpenFoam installation in OpenSuse 11.0 amscosta OpenFOAM 5 May 1, 2009 14:06
OpenFOAM 1.5 installation on OpenSUSE 11.0 bigphil OpenFOAM Installation 16 April 29, 2009 06:28
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
