Hi OpenFOAM
I add a code to
Hi OpenFOAM
I add a code to channelOodles Solver for generating arbitrary points in every iteration in the solution domain . When the points number is below than 92,the code works OK.But when the points number is upper than 92(for ex:100 or 1000 points),after some iteration the run fails. n=85 YYY[n]= 0.230973cellRandom1 9017 n=86 YYY[n]= 0.171737cellRandom1 140439 n=87 YYY[n]= 0.2166cellRandom1 51072 n=88 YYY[n]= 0.1761cellRandom1 32538 n=89 YYY[n]= 0.240889cellRandom1 75073 n=90 YYY[n]= 0.205857cellRandom1 50671 n=91 YYY[n]= 0.241429cellRandom1 14997 n=92 YYY[n]= 0.243897cellRandom1 135296 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) Foam::sigSegv::sigSegvHandler(int) [0xffffe420] channelOodles [0x8060d6c] __libc_start_main __gxx_personality_v0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) Foam::sigSegv::sigSegvHandler(int) [0xffffe420] channelOodles [0x8060d15] __libc_start_main __gxx_personality_v0 >>You can see the part of the written code: Random perturbation(1234567); int loopRandX; int loopRandZ; for(int n=1;n<=bubbleNumber.value();n++) { Info<< "n="<< n ; loopRandX =rand() % 10000 + 1; Info<< " loopRandX= "<<loopRandX ; XXX[n] = (loopRandX*deltaX)/10001 + xFirst.value(); Info<< " XXX[n]= "<< XXX[n] ; YYY[n]= ((perturbation.GaussNormal()+1)/2)*deltaY +yFirst.value(); Info<< " YYY[n]= "<< YYY[n] ; loopRandZ =rand() % 1000 + 5; Info<< " loopRandZ= "<<loopRandZ ; ZZZ[n] = (loopRandZ*deltaZ)/1005 + zFirst.value(); Info<< " ZZZ[n]= "<< ZZZ[n]<< endl ; position[n] = XXX[n] * vector(1,0,0) + YYY[n] * vector(0,1,0) + ZZZ[n] * vector(0,0,1) ; label cellRandom1 = mesh.findCell(position[n]); cellRandom[cellRandom1] = mesh.C()[cellRandom1]; Info<< "cellRandom1 "<< cellRandom1 << endl; } Ideas are welcom. With Best Regards Marhamat |
