No matching function multiplying tensors for BC
Old   March 19, 2008, 10:43
Default Hi All, Im trying to rewrit
Erik Arlemark
Erik is on a distinguished road
Hi All,
Im trying to rewrite a boundary condition used in OpenFOAM 1.2 so that it compiles in OpenFOAM 1.4.1. I get stuck with the following error message:
erik@amigo:~/OpenFOAM/erik-1.4.1/applications/solvers/incompressible/lambdaMicroIcoFoam/BC s> wclean libso
erik@amigo:~/OpenFOAM/erik-1.4.1/applications/solvers/incompressible/lambdaMicroIcoFoam/BC s> wmake libso
/home/erik/OpenFOAM/OpenFOAM-1.4.1/wmake/wmakeLnInclude: linking include files to /home/erik/OpenFOAM/erik-1.4.1/applications/solvers/incompressible/lambdaMicroIc oFoam/BCs/lnInclude
Making dependency list for source file maxwellSlipU/maxwellSlipUFvPatchVectorField.C
Making dependency list for source file mixedFixedValueSlip/mixedFixedValueSlipFvPatchFields.C
SOURCE=maxwellSlipU/maxwellSlipUFvPatchVectorField.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/transportModels -IlnInclude -I. -I/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/maxwellSlipUFvPatchVectorField.o
SOURCE=mixedFixedValueSlip/mixedFixedValueSlipFvPatchFields.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/transportModels -IlnInclude -I. -I/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/mixedFixedValueSlipFvPatchFields.o
/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/transformField.C: In function 'Foam::tmp<foam::field<type> > Foam::transformFieldMask(const Foam::tmp<foam::field<type2> >&) [with Type1 = Foam::Tensor<double>, Type2 = Foam::SymmTensor<double>]':
mixedFixedValueSlip/mixedFixedValueSlipFvPatchField.C:189: instantiated from 'Foam::tmp<foam::field<type> > Foam::mixedFixedValueSlipFvPatchField<type>::snGra dTransformDiag() const [with Type = Foam::Tensor<double>]'
mixedFixedValueSlip/mixedFixedValueSlipFvPatchFields.C:43: instantiated from here
/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/transformField.C:163: error: no matching function for call to 'Foam::tmp<foam::field<foam::tensor<double> > >::tmp(Foam::Field<foam::symmtensor<double> >*)'
/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/tmpI.H:55: note: candidates are: Foam::tmp<t>::tmp(const Foam::tmp<t>&) [with T = Foam::Field<foam::tensor<double> >]
/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/tmpI.H:46: note: Foam::tmp<t>::tmp(const T&) [with T = Foam::Field<foam::tensor<double> >]
/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/tmpI.H:37: note: Foam::tmp<t>::tmp(T*) [with T = Foam::Field<foam::tensor<double> >]
/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/transformField.C: In function 'Foam::tmp<foam::field<type> > Foam::transformFieldMask(const Foam::tmp<foam::field<type2> >&) [with Type1 = Foam::SphericalTensor<double>, Type2 = Foam::SymmTensor<double>]':
mixedFixedValueSlip/mixedFixedValueSlipFvPatchField.C:189: instantiated from 'Foam::tmp<foam::field<type> > Foam::mixedFixedValueSlipFvPatchField<type>::snGra dTransformDiag() const [with Type = Foam::SphericalTensor<double>]'
/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/transformField.C:163: error: no matching function for call to 'Foam::tmp<foam::field<foam::sphericaltensor<doubl e> > >::tmp(Foam::Field<foam::symmtensor<double> >*)'
/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/tmpI.H:55: note: candidates are: Foam::tmp<t>::tmp(const Foam::tmp<t>&) [with T = Foam::Field<foam::sphericaltensor<double> >]
/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/tmpI.H:46: note: Foam::tmp<t>::tmp(const T&) [with T = Foam::Field<foam::sphericaltensor<double> >]
/home/erik/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/tmpI.H:37: note: Foam::tmp<t>::tmp(T*) [with T = Foam::Field<foam::sphericaltensor<double> >]
make: *** [Make/linux64GccDPOpt/mixedFixedValueSlipFvPatchFields.o] Error 1
The lines of complaint concerning mixedFixedValueSlipFvPatchFields.C is listed here:
template<class>
tmp<field<type> > mixedFixedValueSlipFvPatchField<type>::snGradTrans formDiag() const
vectorField nHat = this->patch().nf();
vectorField diag(nHat.size());
diag.replace(vector::X, mag(nHat.component(vector::X)));
diag.replace(vector::Y, mag(nHat.component(vector::Y)));
diag.replace(vector::Z, mag(nHat.component(vector::Z)));
return
->THIS LINE
valueFraction_*pTraits<type>::one
+ (1.0 - valueFraction_)*transformFieldMask<type>(pow<vecto r,>::rank>(diag)); <-THIS LINE
Can someone please give me a hint what the error message refers to? To me it seems like there is a problem multiplying tensor<double> with a symmetric tensor<double>.
Many Thanks
Erik
Erik is offline   Reply With Quote
Old   March 19, 2008, 10:54
Default Yes, that would give you a fou
Hrvoje Jasak
Yes, that would give you a fourth-rank tensor, which is not instantiated.
Hrv
Hrvoje Jasak
Old   March 19, 2008, 19:06
Default Nope - this line: mixedFixedVa
Hrvoje Jasak
Nope - this line: mixedFixedValueSlip/mixedFixedValueSlipFvPatchField.C:189
I take it this is something you wrote yourself as well because I cannot find it in SVN...
Hrv
Hrvoje Jasak
Old   March 20, 2008, 13:05
Default Yes your right, the BC (maxwel
Erik Arlemark
Yes your right, the BC (maxwellSlipUFvPatchVectorField using mixedFixedValueSlipFvPatchField) does not belong the the SVN. It was given to me.
I managed to compile my BC now, but I am interested if it still does what I want it to.
The BC I want to implement seems to be quite similar to partialSlip which is why I changed one of my included files of mixedFixedValueSlipFvPatchField.H from "transformField.H" to "symmTransformField.H", as for partialSlip.H.
Is it possible from just this information to say why I dont get the same tensor multiplication error by using the symmTransformField.H file?
Many Thanks
Erik
tensors cofactors maka OpenFOAM Running, Solving & CFD 3 November 30, 2008 07:32
tensors cofactors maka OpenFOAM Bugs 5 November 17, 2008 08:31
Surface interpolation scheme with tensors as weighting factors jutta OpenFOAM Running, Solving & CFD 1 August 27, 2007 11:00
Surface interpolation of tensors andebjor OpenFOAM Pre-Processing 2 August 23, 2007 03:08
Radiation bc problems multiplying fields tehache OpenFOAM Running, Solving & CFD 4 February 6, 2007 02:37
