How to use the Allrun Alltest scripts for the tutorials
Old   February 19, 2008, 16:06
Default Hello, I installed OpenFOAM 1.
Bernardo D Flores
david_flo1 is on a distinguished road
Hello, I installed OpenFOAM 1.4.1, it works and have tested tutorials using FoamX OK.
Tried running Alltest from the command and get the following result... what am I missing, can't find any info regarding this
bernardo@Monterey:~/OpenFOAM/bernardo-1.4.1/run/tutorials$ sudo ./Alltest
Modifying /home/bernardo/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/controlDict
Copying the tutorials
Modifying the controlDicts to run only one time step
.: 33: RunFunctions: not found
cat: FvSolution.temp: No such file or directory
Thanks
david_flo1 is offline   Reply With Quote
Old   February 21, 2008, 03:21
Default There should be a RunFunctions
Mattijs Janssens
mattijs is on a distinguished road
There should be a RunFunctions script in the directory. Check if it has been renamed as RunFunctions.org and move it back if so.
mattijs is offline   Reply With Quote
ICEM CFD Scripts Vinod Dhiman Main CFD Forum 2 February 17, 2010 10:56
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
need help on ICEMCFD and scripts file option khair CFX 0 December 25, 2007 14:25
Experimental Repository for UDFs, Journal Files and Scheme Scripts Jonas Larsson FLUENT 0 March 5, 2000 15:36
Gambit Journal File Scripts, Public Database Needed? Jonas Larsson Main CFD Forum 13 March 2, 1999 07:25
