-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   How to use the Allrun Alltest scripts for the tutorials (http://www.cfd-online.com/Forums/openfoam/60857-how-use-allrun-alltest-scripts-tutorials.html)
david_flo1 February 19, 2008 17:06
Hello, I installed OpenFOAM 1.
Hello, I installed OpenFOAM 1.4.1, it works and have tested tutorials using FoamX OK.
Tried running Alltest from the command and get the following result... what am I missing, can't find any info regarding this
bernardo@Monterey:~/OpenFOAM/bernardo-1.4.1/run/tutorials$ sudo ./Alltest
Modifying /home/bernardo/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/controlDict
Copying the tutorials
Modifying the controlDicts to run only one time step
.: 33: RunFunctions: not found
cat: FvSolution.temp: No such file or directory
Thanks
mattijs February 21, 2008 04:21
There should be a RunFunctions
There should be a RunFunctions script in the directory. Check if it has been renamed as RunFunctions.org and move it back if so.
