Switching to OpenFOAM Merits and capabilities
Old   December 11, 2007, 22:17
Default Dear group, I've been using
Andrew C. Ward
s195404 is on a distinguished road
Dear group,
I've been using FIDAP at The University of Queensland for quite a while, for the following scenario:
* 3D, turbulent, compressible flow around a building
* building has a heat source (fire) in it that is releasing chemicals and results in a buoyant plume
* there are other buildings around it influencing the flow
* I use custom boundary conditions at the inlet and at the fire (functional forms)
Without going into all the gruesome details, changes with the University's computer systems have made using FIDAP increasingly frustrating (32-bit vs 64-bit OS, connecting to different versions of the license server, trying to run FIDAP on Windows, etc).
I've happily stumbled across OpenFOAM (and Gmsh) and wonder if anyone has been using them to model bluff body or atmospheric flows. I would really value your comments on the possibility of using OpenFOAM for this problem. My particular concerns are with meshing (I'm quite adept at creating meshes in FIDAP's point-and-click interface) and with the boundary conditions (FIDAP uses FORTRAN to implement user-defined boundary conditions).
Thanks so much for your advice!
Regards,
Andrew Ward
s195404 is offline   Reply With Quote
Merits and Demerits of symmetric and asymmetric re Mukkarum Husain Main CFD Forum 0 January 7, 2009 08:46
Cleaning up PATH and LD_LIBRARY_PATH when switching between different versions of OpenFOAM mbeaudoin OpenFOAM Bugs 1 March 12, 2008 04:29
Examples of the ODE capabilities in OpenFOAM philippose OpenFOAM Running, Solving & CFD 3 February 19, 2008 16:59
Fluid Structure Interaction and OpenFOAM capabilities paka OpenFOAM Running, Solving & CFD 1 June 6, 2007 13:56
Capabilities christianhf OpenFOAM 0 February 28, 2007 09:02
