August 11, 2007, 12:32 |
Hello everyone,
A good day
Philippose Rajan
Rep Power: 25 |
Hello everyone,
A good day :-)! I was wondering.... How does one make a post-processing utility "parallel aware" ? As in... if I have a case which I ran in parallel, with say... 2 or more processors, how do I do post-processing on the data without having to do a "reconstructPar" on the case first? I know, that for example, during a parallel simulation, if I need to perform a summation on a patch distributed across multiple processors, I can use the "gSum" command instead of the normal "sum" command... this works fine, and makes things really simple. On the other hand, this does not seem to be working in the case of a post-processing utility... it does not realise that the case was run in parallel. One lead I have, is the "calcMassFlow" utility available on the OpenFOAM wiki... here, the file "buildGlobalBoundaryList.H" seems to do exactly what I want.... but... it seems to be overly complicated for something which should be simple to achieve or?? Is there any simple way of detecting if a case was run in parallel, and extracting data across processors? Something like the "gSum" alternative to "sum" ?? Hoping something does exist :-)! Have a nice weekend! Philippose |
August 12, 2007, 17:12 |
Hello again,
Ok.... I have
Philippose Rajan
Rep Power: 25 |
Hello again,
Ok.... I have finally come up with a utility that is "parallel aware" :-)! Basically, I used ideas from the "reconstructParMesh" utility, to look for and handle multiple processor directories, without actually reconstructing the distributed mesh and data into one mesh again. As a demonstration of the concept, I integrated it into a utility which calculates the forces due to pressure, on a given set of patches. The utility now works transparently, with both... serial, and parallel cases. If it finds any processor directories within the case directory, it uses the time / field data within these directories to calculate the forces on the patches, and if there are no processor directories, it carries on happily with the normal dataset available within the case directory. If anyone else has such a requirement, I would be happy to provide you with the code for the utility. (I would ofcourse, be delighted if someone would take the code and suggest improvements and point out bugs :-)! ) I am toying with the idea of doing something like this for the paraFoam libraries (vtkFoam) in OpenFOAM, but I think that will be a "longer" term project. Philippose |
August 12, 2007, 17:33 |
Just small comment.
Paraview
Rep Power: 18 |
Just small comment.
Paraview in parallel would be a great idea(!). In my case using that tool right now is a bit pointless... Actually, I cannot produce any of the movies without any quirks, it takes a long time to create them, and requires weird thing like not using some of the applications in the background, other way it brakes. For initial view I still stick to Paravie, but for any other postprocessing, data read, etc., I stick to TecPlot. Regards and thanks for a good work Krystian |
February 18, 2011, 07:15 |
Solver parallell aware !
Anders Rynell
Hi philippose !
I am really interested in how you have implemented the processing in your utility. I am about to re write a solver which at "runtime" gives me some parameters regardless if the domain is split into several domains or not. I will be very glad if you provide me the code for that utility Best regards ! /anders |
October 18, 2011, 16:31 |
Marco A. Turcios
Rep Power: 28 |
I would also appreciate a copy of this code, or perhaps have it posted to the wiki.
October 20, 2011, 09:41 |
Kyle Mooney
Rep Power: 17 |
Paraview should be able to detect and actively reconstruct the mesh & fields for viewing.
Under the "Object Inspector" panel there is a "case type" drop down menu. Change that to "Decomposed Case" and hit the Apply button. That should load the decomposed processor# meshes and fields instead of the fields and meshes present in the main case directory. |
Proposal for an extension for the timeoptions of Utilities | gschaider | OpenFOAM Bugs | 5 | August 26, 2008 19:13 |
Problem with foam utilities in foamx | alan_fergus | OpenFOAM Bugs | 2 | January 15, 2008 06:38 |
New Utilities | coops | OpenFOAM Post-Processing | 1 | July 4, 2007 04:21 |
Utilities to download for research/programmers | For those who favor open-source | Main CFD Forum | 0 | September 21, 2006 16:03 |
Running utilities for a given time step | melanie | OpenFOAM Running, Solving & CFD | 2 | March 10, 2006 07:28 |
