Adding self written mesh to runtimeselection
Old   June 12, 2007, 10:28
Default Hi all, I've got a problem wi
bfa
Björn Fabritius
bfa is on a distinguished road
Hi all,
I've got a problem with a mesh I've derived from topoChangerFvMesh. I used (or think have) the function
addToRuntimeSelectionTable(topoChangerFvMesh, myFvMesh, IOobject)
correctly. Compiling and linking into "$USER_LIB_BIN/libmyFvMesh.so" works just fine. Now I've put the following lines into dynamicMeshDict:
dynamicFvMeshLib "libmyFvMesh.so";
dynamicFvMesh myFvMesh;
When I run the case with icoDyMFoam I end up with the message
--> FOAM FATAL ERROR : Unknown dynamicFvMesh type myFvMesh
Is it possible, that the solver doesn't use $USER_LIB_BIN to search for libraries or is there a major brain-bug in my code (I thought about the problem being the derivation from topoChangerFvMesh which itself derives from dynamicFvMesh, but I thought autoptr would take care of that)??
Suggestions are welcome,
Bjoern
bfa is offline   Reply With Quote
Old   June 26, 2007, 08:18
Default Hi Bjoern! Same problem her
Thomas Jung
tehache is on a distinguished road
Hi Bjoern!
Same problem here ...
Did you find a solution in the mean time?
Regards,
Thomas
tehache is offline   Reply With Quote
Old   June 26, 2007, 09:02
Default Hello Thomas, I actually fo
bfa
Björn Fabritius
Hello Thomas,
I actually found my mistake.
In the dynamicMeshDict you have to enclose the library name in brackets like this:
dynamicFvMeshLibs ("libmyFvMesh.so");
It should work that way.
Regards,
Bjoern
adding a node in 2D mesh (gambit) Ralf Schmidt FLUENT 0 August 24, 2006 01:32
adding a note in 2D mesh (gambit) Ralf Schmidt Main CFD Forum 1 August 23, 2006 07:19
Problems importing written gambit .neu mesh file jemteo FLUENT 3 February 20, 2006 01:42
F(1) over-written error Olof Liungman Phoenics 5 October 27, 2005 13:52
Adding cells during mesh motion Serkan Cetin Siemens 1 December 23, 2002 03:22
