June 16, 2010, 12:09 |
buoyantPisoFoam - engrid Boundary Layers
Rep Power: 16 |
hi everyone!
I am simulating a room and have produced a model including a prismatic BL with Salome and Engrid. I simulated with buoyantPisoFoam before without major issues but with my current model the simulation stops after a few timesteps and obviously there is a jump in the residuals. My question is - could it be due to the grid that I created with Engrid? I think it might be due to the fact that I have massive cells in the model (1.5m length) and tiny ones (0.05m) which might somehow not fit together.. Have you got suggestions what I could do? I already set the k and epsilon values to Gauss linear limited 0.7 and tried to turn turbulence off - but no effect. Basically the solver is crashing because the adaptive timestepping (Co nr. 0.7) is getting too narrow. My initial conditions are equal for the entire room apart from the fact that T is 30K lower in one part (initialised with funkySetFields) than in the other... I attached a screenshot that shows BL part of the grid and the solver error I am experiencing. Thanks and have a nice day , Chris |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
[ICEM] Problem with boundary layers for cylinder in channel | nik | ANSYS Meshing & Geometry | 0 | October 27, 2009 06:01 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
test cases for 2D boundary layers | roxana | Main CFD Forum | 0 | April 13, 2002 09:25 |
Boundary Layers on 2D shapes | Bruce Bartie | Main CFD Forum | 1 | September 3, 1998 12:22 |
