-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Solid/liquid phase change (http://www.cfd-online.com/Forums/openfoam/64506-solid-liquid-phase-change.html)
fabian_roesler May 13, 2009 09:35
Dear Foamers
For a project I am trying to get a solid/liquid phase change simulation running in OF 1.5-dev. A paraffin with non isothermal phase change is molten in a 2D rectangular test case scenario. I started from interFoam solver by changing especially the gamma equation to my needs:
Gamma equation:
dimensionedScalar pi = mathematicalConstant::pi;
dimensionedScalar alpha = (Tl-Ts)/(scalar(2)*tan(scalar(0.49)*pi));
gamma = atan(scalar(1)/alpha*(T-(Tl+Ts)/scalar(2)))/pi+scalar(0.5);
Changig gamma from 0 (solid) to 1 (liquid) depending on the temperatures
Tl (upper phase change temperature) Ts (lower phase change temperature)
Momentum equation:
fvVectorMatrix UEqn
fvm::ddt(rho, U)
+ fvm::div(rhoPhi, U)
- fvm::laplacian(muf, U)
- (fvc::grad(U) & fvc::grad(muf))
UEqn.relax();
if (momentumPredictor)
solve
UEqn
fvc::reconstruct
- ghf*fvc::snGrad(rho)
- fvc::snGrad(pd)
) * mesh.magSf()
No changes at all, however no surface tension left
Energy equation:
volScalarField rhoCp("rhoCp", rho*cp);
surfaceScalarField rhoPhiCp("rhoPhiCp", rhoPhi*fvc::interpolate(cp));
fvScalarMatrix hEqn
fvm::ddt(rhoCp, T)
+ fvm::div(rhoPhiCp, T)
- fvm::laplacian(lambda, T)
solve
hEqn ==
- hs*fvc::ddt(rho, gamma) //Source term from Stefan condition
The source term derived from the Stefan condition takes care of the temperature gradient at the interface induced by the phase change.
Solver:
Like in interFoam, the solver works as follows:
  1. Solving gamma equation
  2. Solving coupled pressure and velocity equations
  3. NEW solving energy equation NEW
The solver is very unstable what, in my opinion is due to the couppling of gamma and energy. Please correct me when I am wrong. My questions are:
Is it really the coupling of gamma and energy, making the solver instable?
Is there a way to solve the coupled equations (relaxation)?
Thanks allot for your replies.
Best regards
Fabian
fabian_roesler May 18, 2009 09:51
Simulation stops
Hallo Foamers
I managed to get my model running. I substituted the gamma equation into the energy conservation equation and it worked. No I encountered another problem. The solver runs fine until a certain time, where all iteration numbers equal zero and the results do not change anymore. The solver continues running until endTime but nothing changes anymore. Here are the two time steps from the log file where the error occurred in between:
PBiCG: Solving for T, Initial residual = 1.00244e-05, Final residual = 8.71675e-11, No Iterations 1
Liquid phase volume fraction = 0.00105084 Min(gamma) = 0.000769482 Max(gamma) = 0.998571
PBiCG: Solving for Ux, Initial residual = 0.000224831, Final residual = 1.0262e-16, No Iterations 1
PBiCG: Solving for Uy, Initial residual = 0.000162936, Final residual = 7.40847e-17, No Iterations 1
PCG: Solving for pd, Initial residual = 0.000982493, Final residual = 1.25233e-05, No Iterations 2
PCG: Solving for pd, Initial residual = 1.25111e-05, Final residual = 4.69217e-07, No Iterations 23
PCG: Solving for pd, Initial residual = 4.69216e-07, Final residual = 7.52164e-08, No Iterations 25
PCG: Solving for pd, Initial residual = 7.55978e-08, Final residual = 7.55978e-08, No Iterations 0
time step continuity errors : sum local = 2.05188e-15, global = 1.44131e-30, cumulative = -4.99715e-30
ExecutionTime = 287.72 s ClockTime = 288 s
Courant Number mean: 2.76148e-12 max: 7.1681e-10 velocity magnitude: 2.51386e-11
deltaT = 0.00990099
Time = 11.7822
PBiCG: Solving for T, Initial residual = 9.99292e-06, Final residual = 9.99292e-06, No Iterations 0
PBiCG: Solving for Ux, Initial residual = 1.10625e-12, Final residual = 1.10625e-12, No Iterations 0
PBiCG: Solving for Uy, Initial residual = 6.0714e-13, Final residual = 6.0714e-13, No Iterations 0
PCG: Solving for pd, Initial residual = 7.55979e-08, Final residual = 7.55979e-08, No Iterations 0
time step continuity errors : sum local = 2.05188e-15, global = -4.11243e-31, cumulative = -5.40839e-30
ExecutionTime = 287.81 s ClockTime = 288 s
Courant Number mean: 2.76148e-12 max: 7.16811e-10 velocity magnitude: 2.51386e-11
deltaT = 0.00990099
Time = 11.7921
I think all residuals are OK and the Courant number is way to small to have an effect. Any ideas what could cause this problem? Thanks in advance for your replies.
Regards
Rachel June 2, 2009 12:00
Hi Fabian,
My guess is that the reducing the number of pd iterations might solve the issue. I guess its the non-orthogonal pressure corrections.
In case this does not work, consider reducing the residual to say e-10 or relTol parameters.
Regards
Rachel
fabian_roesler June 3, 2009 03:37
PISO in multiphase phase change problems
Hi Rachel
Thank you for your reply. You are right: It's the residual causing this problem. The initial residual
is allready below the one beeing requested by fvSolution. I set the residual to 1e-10 and the simulation runs without problems.
However I have still some problems with continuity. Like in the cavitation multiphase solvers, the PISO pressure equation has to be changed in a certain way. In interPhaseChange Foam for example, pEqn is changed from
fvScalarMatrix pdEqn
fvc::div(phi) - fvm::laplacian(rUAf, pd)
to
+ (vDotvP - vDotcP)*(rho*gh - pSat) + fvm::Sp(vDotvP - vDotcP, pd)
I have to have a closer look on the PISO scheme and the pressure equation to learn how to derive the equation suited to my model.
Does anybody have some tips on how to use PISO in phase change multiphase problems? Thanks allot in advance.
Regards
Fabian
haghajani June 4, 2009 10:53
substitution of equation into the energy conservation equation
Dear Fabian,
Would you please let me know, how do you substituted the gamma equation into the energy conservation equation. Please drop some lines, how this could solve the problem arose?
Thanks in advance,
Hamed
dakos June 5, 2009 06:18
Hi Fabian,
I'm also interested in solidification simulation, but i have some problems in defining gamma as a function of temperature.
Can you tell me how you did?
Dario
fabian_roesler June 5, 2009 06:45
Continuous gamma function
Hi Hamed, hi Dario
My gamma equation is in contrast to the literature a continuous function. The literature defines gamma as 0 in the solid phase, 1 in the liquid phase and linear in between. I am using a arcus tangent function.
The source term in the energy equation
can be written as
- hs*
rho*fvc::ddt(gamma)
+ gamma*fvc::ddt(rho)
the time derivative of gamma can be directly included here so the two coupled equations form one equation. The gamma field can be calculated after solving the energy equation, however this is not necessary for the solver any more.
Anybody can tell me more about the PISO scheme in multiphase solvers?
Regards Fabian
awacs May 27, 2010 10:11
Originally Posted by fabian_roesler (Post 218344)
Hi Hamed, hi Dario
can be written as
- hs*
rho*fvc::ddt(gamma)
Regards Fabian
Hi Fabian,
I am trying to simulate melt filling process in injcetion molding. The polymer melt solidifies and stops flowing at cavity wall due to the cooling effect of cold cavity. As a result, the melt/air and melt/solid interfaces need to be fixed in simulation. I have added the energy equation into interFoam. The non-newtonian viscosity is take into account, too. The problem is that how can I determine the varied melt/solid interface.
Please give me some tips. Thanks in advance.
Best regards,
Jitao
fabian_roesler May 28, 2010 08:45
Gamma function for injection molding
Hi Jitao
the phase change is taken into account by adding a source term to the energy conservation equation. Internal energy is no longer
cp*T
but
cp*T + gamma*hs
where gamma is the phase fraction and hs is the latent heat of fusion. The method is called the enthalpy method. It can be used when phase change occurs over a temperature range and without crystallisation effect.
Regards Fabian
farhagim September 1, 2010 18:01
Hi Fabian,
First of all Thank you for sharing your information. Second, I have some question regarding the solidification (Ice accretion ) with interFoam.
1- does your mesh update in each iteration?
2- have you managed to get good result?
3- can you explain it to how does it works, I mean I did not see any condition in your solid -liquid phase for temperature. I guess you involve the condition in your gamma, am I right??
Finally would you please give me some hint or any progress in your implementation?
Thanks
Mehran
Originally Posted by fabian_roesler (Post 260680)
Hi Jitao
cp*T
but
cp*T + gamma*hs
Regards Fabian
mamyjooooon December 24, 2012 07:37
hi
Have you succeeded in solidification in OpenFoam?
I am facing a similar problem and I want to model the aircraft in-fight ice accretion using openfoam or fluent
please help me about this problem
ThankS
