Pressure Inlet Velocity
Like Tree1Likes
  • 1 Post By prapanj
Old   June 19, 2009, 00:18
Default Pressure Inlet Velocity
Prapanch Nair
prapanj is on a distinguished road
I am trying to solve flow through a 'S' shaped pipe. Both the bends in the pipe are very close to the inlet and the outlet. The inner wall of the pipe has a lot of projections. I want to see what average flow velocity I would be getting after setting a pressure difference between inlet and outlet.
I had set a pressure value 15 Pa at the inlet and 0 Pa at the outlet. I used pressureInletVelocity BC at inlet and inletOutlet BC for outlet for the velocity. And for pressure, I used fixedValue BC at the inlet and outlet. After about 400 iterations ( steady state incompressible flow) I checked the field and found very high value for pressure within the field ( of the order of 10^30 ) . Could someone please point me the mistakes with my boundary condition or suggest me a solution?
Thanks,
Prapanj.
prapanj is offline   Reply With Quote
Old   June 19, 2009, 04:10
Julian Krick
Julian K. is on a distinguished road
I have experienced a similar effect. I'm simulating a convergent-divergent supersonic nozzle. I also set the pressure difference of 300mbar between inlet and outlet.
BCs for inlet: - pressure: 'totalPressure
- velocity: 'pressureInletVelocity'
BCs for outlet: - pressure: 'static pressure'
- velocity: 'zeroGradient'
I'm using the sonicFoam solver.
What happens is that at some point during the iteration process the velocity near the outlet increases drastically, furthermore, also at the outlet, value for pressure are either very high or negative.
I suppose this effect is evoked by the outlet boundary condition.
grid generation: ICEM CFD 13.0
solver: CFX 13.0
Julian K. is offline   Reply With Quote
Old   June 19, 2009, 05:23
Prapanch Nair
Julian,
Could you explain why you used totalPressure at Inlet? For viscous compressible flow, there will be a total pressure loss if there is a stationary shock in the CD nozzle. Have you used totalPressure at inlet before?
Prapanj.
Old   June 19, 2009, 05:41
Julian Krick
Actually my task is to compare the results of the OpenFoam simuatlion of the CD nozzle with results we got from calculation with a different solvers. In these calculations there was a total pressure defined at the inlet., so I did the same in order to be as synchron as possible.
Nevertheless, I also used the 'fixedValue' BC-type for the pressure at inlet and outlet and got the same effect of instability.
I didn't use the 'totalPressure' BC in any of my other simulations.
solver: CFX 13.0
Old   June 19, 2009, 06:00
Prapanch Nair
Hey,
When you say static pressure, do you mean fixedValue? If not, set a fixedValue for pressure at the outlet. Or, try this:
Use wave transmissive pressure . I hope you have the user guide for openfoam, which available for download (google for it). Page U-129, there is table. Look for pressureTransmissive, that lets you set a pInf for ambient pressure. You issue may be due to shock waves being reflected off the outlet. Have you tried visualizing your interim results?
Prapanj.
granzer likes this.
Old   June 19, 2009, 07:38
Post
Julian Krick
Yes, by static pressure I mean 'fixedValue' type of boundary condition for pressure - I hope my interpretation of 'fixedValue' for pressure is correct.
Thus, as mentioned, I already tried a 'fixedValue' BC for pressure at the outlet but came the same result -but thanks for the hint.
As you suggested, I looked at page U-129 for finding the definiton of the 'pressureTransmissive' BC. That sounds promising. However, when I was looking in the internet for a description on how to define 'pressureTransmissive' I found that this BC was substituted by the 'waveTransmissive' BC in OpenFOAM v.1.4: http://www.openfoamwiki.net/index.ph...dary_condition
Furthermore, I couldn't find 'pressureTransmissive' BC in the OF C++ Source Guide.
Anyway, I applied the 'waveTransmissive' BC to the outlet and it seems to work! However, the simulation is still running and I couldn't yet take a look at the results. But anyway, thank you very much prapanj ! Here is my /0/p file:
inlet
    type     totalPressure;
    p0        uniform 1.01325e+05;//:p_in
    U         U;
    phi       phi;
    rho       none;
    psi       none;
    gamma        1.4;
    value    uniform 1.01325e+05;
outlet
    type            waveTransmissive;
    value           uniform 71325;    //important for correct I/O
    field            p;                //the name of the field that we are working on
    gamma       1.4;              //the ratio of specific heats
    phi              phi;              //the name of the volumetric flux field (or if you use the mass flux phi, it will be divided by rho)
    rho             rho;              //the name of the density field
    psi             psi;              //the name of the field that is the deriv. of density with respect to pressure
    lInf             1;             //a measure of how far away the far-field condition should be
    fieldInf        71325;            //the far-field value to be applied to p
While I was searching the internet I found the following BCs, which could also be adequate for my problem:
- waveTranmissive
(- pressureTransmissive)
- freestream
- frestreamPressure
- supersonicFreestream
Unfortunately, I wasn't able to find an appropriate description of the last three BCs, listed above. Do you know, what they do?
solver: CFX 13.0
Old   June 19, 2009, 07:48
Prapanch Nair
Hey,
What version of OF do you use? Is it 1.4?
Well ther eis a later version 1.5 that is realease. And a even recent version 1.5.x released. However you will have to compile 1.5.x. The boundaries that are missing in your installation may be found in 1.5.x
Freestream as I understand is suitable for use in external compressible flow. Like, flow around aerofoil etc. And I haven't looked into the codes of those (Even if I look, I am not sure I can figure out).
Check the intermediate results and say if it works.
Prapanj. (Ps: are you from a German University? )
Old   June 19, 2009, 08:06
Julian Krick
I'm using OF 1.5.
The interim results look okay; simulations are still running and stable. Thanks!. I hope they won't blow up again. At the beginning of next week I can tell if it worked out.
Yes, I'm a Bachelor student at the university of Duisburg-Essen, located in Duisburg, Germany.
solver: CFX 13.0
Old   June 19, 2009, 08:08
Prapanch Nair
Np.
And do post if it worked .
Old   June 22, 2009, 05:40
Julian Krick
Today, I looked at the results of my calculations. They are stable ! The BC 'waveTransmissve' seems to stabilize the simulations. There is no drastic increase anymore in pressure or velocity. So far so good.
However, there is a different problem. For the simulation of my nozzle I need to have a pressure difference of 300mbar between the outlet and the inlet. At the inlet I have atmospheric pressure:
inlet
        type            totalPressure;
    U        U;
    phi        phi;
    rho        none;
    psi        none;
    gamma        1.4;
At the outlet I have 'atmospheric pressure' - 300mbar:
outlet
Now, the problem is that after some time, the pressure at the outlet will tend towards a value of 120mbar, which is far too low. With this pressure the instationary effects which I want to observe in the nozzle will not occur. Instead, the flow through the nozzle becomes stationary.
So, what can I do to establish a pressure of ~700mbar at the outlet using the 'waveTransmissive' BC? Maybe I have to change the value for 'lInf'. What measure does this variable have, anyway? Is it in m or mm or dimensionless?
By the way, can I use the 'waveTransmissive' BC for the inlet, as well? I encountered some shock waves, which traveled towards the inlet and unfortunately were reflected.
solver: CFX 13.0
Old   June 22, 2009, 23:57
Prapanch Nair
Hi Julian,
You have set 'rho' as none at the inlet. Can you change it to 'rho' as in " rho rho; " and try again. I don't know if this would help.
Prapanj.
Old   June 23, 2009, 11:15
statesman is on a distinguished road
Hey ive been following this discussion
I am trying to model barrell shocks in an axisymmetric model. Inlet air is M=1. The exit is a subsonic outlet.
I am using rhoSonicFoam [modified to read p , rho, T, U fields , so that the solver can accept derived BCs ] , Im using non-reflective BCs at the exit for rho, since for subsonic outlet , the eigenvalue correspding to rho is -ve. However i am not getting the inlet BCs correct .
I however am not getting the right combination of BC at inlet for p & rho.
I ll summarize the Bc i have tried :--
p
Inlet : totalPressure outlet : fixedValue [ static]
rho
inlet: fixedValue outlet : nonReflective.
U
inlet : 350 outlet : zeroGradient
T
Inlet : 250 outlet : zerogradient
kindly suggest me a better combination ....
statesman is offline   Reply With Quote
pipe, pressure difference, pressureinletvelocity
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
boundary condition velocity inlet dont have gauge pressure setting value? coolyihao FLOW-3D 0 March 17, 2009 10:17
Ansys Flotran: Velocity or Pressure BC? eu-ric thean CFX 2 December 28, 2005 12:06
Reversed flow in pressure inlet eric FLUENT 3 January 26, 2004 20:04
UDF paraboloid velocity inlet Ronak Shah FLUENT 0 June 4, 2003 09:44
