August 13, 2009, 06:35 |
directMapped BC in parallel
Johann Turnow
Rep Power: 17 |
Hi all togehter,
I was setting up an LES with the directMapped BC in parallel with the new svn checkout of version OF-1.5-dev. On a single processor the BC works well but while starting it in parallel mode (more than 2 cores) it keeps stopping before solving the momentum equation. Even the Tutorial pitzDailyDirectMapped does not work on 4 cores. Also the debug modus shows no problems. so can anyone give me a hint, where to start solving this problem? thanks, Johann |
Script to Run Parallel Jobs in Rocks Cluster | asaha | OpenFOAM Running, Solving & CFD | 12 | July 4, 2012 22:51 |
HP MPI warning...Distributed parallel processing | Peter | CFX | 10 | May 14, 2011 06:17 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Parallel Plate Rheometer vs Cone & Plate | beginner | Main CFD Forum | 0 | March 19, 2003 11:49 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
