error while running paraFoam!
hi all,
i'm new to open foam, i'm practicing on lid-driven cavity flow, while executing paraFoam, parafoam shows the following error, can any one tell me what is this? how can I resolve and proceed further? pls help me. and i can't able to view grid and post processing. vtkPVDReader (0xa6546b8): Could not read file information ERROR: In /builddir/build/BUILD/ParaView-3.4.0/VTK/Filtering/vtkExecutive.cxx, line 757 vtkCompositeDataPipeline (0xa062480): Algorithm vtkPVDReader(0xa6546b8) returned failure for request: vtkInformation (0x9f84480) Debug: Off Modified Time: 78270 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA_OBJECT ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 |
I'm new in OpenFOAM, too!
I have a similar problem with paraFoam, I resolved it typing: foamToVTK in the case directory. Then OpenFOAM make a new directory named: VTK. Now open paraview and you are able to see what do you want! I hope it is usefull. best regard MT |
thanks marco,
I hope the previous post was useful for you!
I find in another discussion (http://www.cfd-online.com/Forums/ope...-opensuse.html) this solution: Quote:
MT |
Hi All
I have compiled ParaView, but when i write command: >paraFoam in case directory.There is something error like this: >$HOME/OpenFoam/OpenFoam-1.5-dev/bin/paraFoam:103: paraview:not found I don't know how to fix the problem.... |
hi, i think this is some installation error, you can follow the previous post reply by zebu83 to resolve the issue. |
builParaView3.3-cvs got following error
When I tried to run buildParaView3.3-cvs after rmoving platforms directory, i got the following messages. /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtksqlite/vtk_sqlite3.c: In function âvtk_sqlite3VtabRollbackâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtksqlite/vtk_sqlite3.c:59919: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtksqlite/vtk_sqlite3.c: In function âvtk_sqlite3VtabCommitâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtksqlite/vtk_sqlite3.c:59928: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c: In function â_tiffReadProcâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c:58: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c: In function â_tiffWriteProcâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c:64: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c: In function â_tiffSeekProcâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c:70: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c: In function â_tiffCloseProcâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c:76: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c: In function â_tiffSizeProcâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c:88: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c: In function â_tiffMapProcâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c:101: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c: In function âvtk_TIFFFdOpenâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c:140: warning: cast to pointer from integer of different size unable to calculate alignment for long double In file included from /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkGraphicsFactory.cxx:65: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:37:74: error: X11/StringDefs.h: No such file or directory /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:38:73: error: X11/Intrinsic.h: No such file or directory In file included from /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkGraphicsFactory.cxx:65: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:45: error: variable or field âvtkXRenderWindowInteractorCallbackâ declared void /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:45: error: âWidgetâ was not declared in this scope /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:45: error: âXtPointerâ was not declared in this scope /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:45: error: âXEventâ was not declared in this scope /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:45: error: expected primary-expression before â,â token /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:45: error: âBooleanâ was not declared in this scope /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:45: error: expected primary-expression before â)â token /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:46: error: variable or field âvtkXRenderWindowInteractorTimerâ declared void /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:46: error: âXtPointerâ was not declared in this scope /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:46: error: âXtIntervalIdâ was not declared in this scope /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:46: error: expected primary-expression before â)â token /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:78: error: âXtAppContextâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:79: error: âXtAppContextâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:113: error: âWidgetâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:114: error: âWidgetâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:144: error: âWidgetâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:145: error: âWidgetâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:153: error: âWidgetâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:153: error: âXtPointerâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:154: error: âXEventâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:154: error: âBooleanâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:155: error: âXtPointerâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:155: error: âXtIntervalIdâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:162: error: âXtAppContextâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:165: error: ISO C++ forbids declaration of âDisplayâ with no type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:165: error: expected â;â before â*â token /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:166: error: âWindowâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:167: error: âAtomâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:168: error: âWidgetâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:172: error: âWidgetâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:183: error: âXtIntervalIdâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:185: error: âXtPointerâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:185: error: âXtIntervalIdâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:186: error: âWidgetâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:186: error: âXtPointerâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:186: error: âXEventâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:186: error: âBooleanâ has not been declared make[2]: *** [VTK/Rendering/CMakeFiles/vtkRendering.dir/vtkGraphicsFactory.o] Error 1 make[2]: *** Waiting for unfinished jobs.... make[1]: *** [VTK/Rendering/CMakeFiles/vtkRendering.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... make: *** [all] Error 2 [ 52%] [ 52%] Building CXX object Utilities/VTKClientServer/Graphics/CMakeFiles/vtkGraphicsCS.dir/vtkWindowedSincPolyDataFilterClientServer.o Building CXX object Utilities/VTKClientServer/Graphics/CMakeFiles/vtkGraphicsCS.dir/vtkGraphicsCSInit.o Linking CXX shared library ../../../bin/libvtkGraphicsCS.so [ 52%] Built target vtkGraphicsCS make: *** [all] Error 2 done please let me know, how can i avoid this and complete the installation? |
Apart from that I don't think your information is sufficient to diagnose the problem (not completely you fault because cmake hides the actual reason for the failure from you, but maybe it is in some logfile) |
Here below I displayed more error messages what I found: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtksqlite/vtk_sqlite3.c: In function âvtk_sqlite3VtabRollbackâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtksqlite/vtk_sqlite3.c:59919: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtksqlite/vtk_sqlite3.c: In function âvtk_sqlite3VtabCommitâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtksqlite/vtk_sqlite3.c:59928: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c: In function â_tiffReadProcâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c:58: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c: In function â_tiffWriteProcâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c:64: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c: In function â_tiffSeekProcâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c:70: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c: In function â_tiffCloseProcâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c:76: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c: In function â_tiffSizeProcâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c:88: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c: In function â_tiffMapProcâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c:101: warning: cast from pointer to integer of different size /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c: In function âvtk_TIFFFdOpenâ: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/vtktiff/tif_unix.c:140: warning: cast to pointer from integer of different size unable to calculate alignment for long double In file included from /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkGraphicsFactory.cxx:65: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:37:74: error: X11/StringDefs.h: No such file or directory /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:38:73: error: X11/Intrinsic.h: No such file or directory In file included from /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkGraphicsFactory.cxx:65: /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:45: error: variable or field âvtkXRenderWindowInteractorCallbackâ declared void /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:45: error: âWidgetâ was not declared in this scope /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:45: error: âXtPointerâ was not declared in this scope /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:45: error: âXEventâ was not declared in this scope /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:45: error: expected primary-expression before â,â token /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:45: error: âBooleanâ was not declared in this scope /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:45: error: expected primary-expression before â)â token /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:46: error: variable or field âvtkXRenderWindowInteractorTimerâ declared void /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:46: error: âXtPointerâ was not declared in this scope /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:46: error: âXtIntervalIdâ was not declared in this scope /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:46: error: expected primary-expression before â)â token /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:78: error: âXtAppContextâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:79: error: âXtAppContextâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:113: error: âWidgetâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:114: error: âWidgetâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:144: error: âWidgetâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:145: error: âWidgetâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:153: error: âWidgetâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:153: error: âXtPointerâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:154: error: âXEventâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:154: error: âBooleanâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:155: error: âXtPointerâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:155: error: âXtIntervalIdâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:162: error: âXtAppContextâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:165: error: ISO C++ forbids declaration of âDisplayâ with no type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:165: error: expected â;â before â*â token /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:166: error: âWindowâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:167: error: âAtomâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:168: error: âWidgetâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:172: error: âWidgetâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:183: error: âXtIntervalIdâ does not name a type /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:185: error: âXtPointerâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:185: error: âXtIntervalIdâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:186: error: âWidgetâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:186: error: âXtPointerâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:186: error: âXEventâ has not been declared /opt/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXRenderWindowInteractor.h:186: error: âBooleanâ has not been declared make[2]: *** [VTK/Rendering/CMakeFiles/vtkRendering.dir/vtkGraphicsFactory.o] Error 1 make[2]: *** Waiting for unfinished jobs.... make[1]: *** [VTK/Rendering/CMakeFiles/vtkRendering.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... make: *** [all] Error 2 |
Bernhard |
