-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Foam fatal error (http://www.cfd-online.com/Forums/openfoam/65462-foam-fatal-error.html)
weninb June 15, 2009 22:45
Foam fatal error
I am having issues with mesh conversions. I am running openfoam-1.4 which came with caelinux-1.4.1.
Currently, I am using Salome 3.2.9 to mesh/define boundarys. I use the NETGEn 1D-2D-3D algorith when meshing. Then I create groups for walls, inlets, outlets,.... Finally I use the "Export to UNV file" option to create a mesh file Openfoam will accept.
I run the cae console and type "ideasUnvToFoam $FOAM_RUN FUMEHOOD fumehood.unv"
Where FUMEHOOD is the case and fumehood.unv is the mesh exported from SALOME.
I get the following fatal error:
"FOAM FATAL ERROR : Trying to specify a boundary face 3(42 35 7529) on the face on cell 5139 which is either an internal face or already belongs to some other patch. This is face 39704 of patch 2 named WALL.#0..............."
I have meshed many different models and some work, but most do not. Is my problem generating the groups? or is it an openfoam problem?
I have looked online for and found some discussion, but i was not able to find an obvious solution.
Please, any help would be great. I been working quite a few weekds on this.
Thank you,
Brian
