Home > Forums > OpenFOAM
Laminar , steady state pipe flow
Old   April 3, 2013, 03:29
B T KANNAN
skyinventorbt is on a distinguished road
Dear Vishal,
We are assuming wedge as an approximation to simplify the domain.
Radius is R
{because R*0.999 is approximately equals R only right ??}
KANNAN
skyinventorbt is offline   Reply With Quote
Old   April 4, 2013, 00:15
Vishal Nandigana
nandiganavishal is on a distinguished road
Originally Posted by skyinventorbt View Post
Dear Vishal,
Radius is R
KANNAN
You are right :P... was just curious why it was thought about to construct the geometry in this manner . The geometry works fine. Thanks for your tips.
nandiganavishal is offline   Reply With Quote
Old   April 5, 2013, 14:16
Vishal Nandigana
Hi Kanan,
I am now modeling a concentric pipe geometry. I have difficulty in understanding which faces I should generate the mesh. I would like to give boundary conditions on both the surface of inner pipe and on the outer pipe. Here is the sample blockmesh dict file that I have generated.
// length of pore = 36 nm and diameter: 10.2nm , theta = 2 deg (consider this as outer pipe)
// length of DNA = 36 nm and diameter of DNA: 2.2nm , theta = 2 deg (consider this as inner pipe)
//r_DNA*cos(theta/2) = 1.1*cos(0.0349/2 radians) = 1.0998
// r_DNA*sin(theta/2) = 1.1*sin(0.0349/2 radians) = 0.0192
//r_pore*cos(theta/2) = 5.1*cos(0.0349/2 radians) = 5.0992
//r_pore*sin(theta/2) = 5.1*sin(0.0349/2 radians) = 0.0890
vertices
(0 0 0) // vertex 0
(36 0 0) // vertex 1
(36 1.0998 -0.0192) // vertex 2 (L,r_DNA*cos(theta/2),-r_DNA*sin(theta/2))
(0 1.0998 -0.0192) // vertex 3 (0,rcos(theta/2),-rsin(theta/2))
(36 5.0992 -0.0890) // vertex 4 (L,r_pore*cos(theta/2),-r_pore*sin(theta/2))
(0 5.0992 -0.0890) // vertex 5 (0,r_pore*cos(theta/2),-r_pore*sin(theta/2))
(0 0 0.0192) // vertex 6 (0, 0,r_DNA*sin(theta/2))
(36 0 0.0192) // vertex 7 (L, 0,r_DNA*sin(theta/2))
(36 1.0998 0.0192) // vertex 8 (0, r_DNA*cos(theta/2),r_DNA*sin(theta/2))
(0 1.0998 0.0192) // vertex 9 (L, r_DNA*cos(theta/2),r_DNA*sin(theta/2))
(0 0 0.0890) // vertex 10 (0, 0,r_pore*sin(theta/2))
(36 0 0.0890) // vertex 11 (L, 0,r_pore*sin(theta/2))
(36 5.0992 0.0890) // vertex 12 (L,r_pore*cos(theta/2),r_pore*sin(theta/2))
(0 5.0992 0.0890) // vertex 13 (0,r_pore*cos(theta/2),r_pore*sin(theta/2))
Please let me know if the vertices are correct. If so, how to generate the mesh for the same.
Thanks
Regards
Vishal
Old   February 23, 2015, 11:30
Naresh Yathuru
Naresh yathuru is on a distinguished road
hi thanks every one for posting the reply. i have a question i would like to simulate a steady state simulate in ico foam so i changed to
ddtScheme
type steadystate;
Then i got this error
FOAM Warning :
From function gaussConvectionScheme
in file finiteVolume/convectionSchemes/gaussConvectionScheme/gaussConvectionScheme.H at line 123
Reading "/home/yathuru/task1steady/system/fvSchemes.divSchemes.div(phi,U)" at line 31
Unbounded 'Gauss' div scheme used in steady-state solver, use 'bounded Gauss' to ensure boundedness.
To remove this warning switch off 'boundedGauss' in "/opt/OpenFOAM-2.3.0/etc/controlDict".
can some one help me.. i m lost.
Naresh yathuru is offline   Reply With Quote
Old   February 23, 2015, 11:59
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
icoFoam is a transient solver. If you need steady state, simpleFoam is probably what you need.
Regards,
Jose
santos is offline   Reply With Quote
Old   February 25, 2015, 06:57
Tushar Chourushi
Tushar@cfd is on a distinguished road
ddtScheme
type steadystate;
FOAM Warning :
Dear Naresh,
It's just a warning I guess you can run your case with that.
OR, you can remove the warning as follows:
divSchemes
... bounded Gauss upwind;
Best Regards!
Tushar@cfd is offline   Reply With Quote
Old   March 2, 2015, 05:03
Naresh Yathuru
Thank you so much for your reply santos and tushar. I knew i can do it in simple foam but just out of curiosity i wanted to try it in ico foam. I ran the simulation in simple foam its working well then i changed the case to turbulent simulation its is also working well now. however i have some issues with the convergence. i will try to figure it out. if not i will get back again .
Old   March 2, 2015, 06:42
Tushar Chourushi
Thank you so much for your reply santos and tushar. I knew i can do it in simple foam but just out of curiosity i wanted to try it in ico foam... .
Dear Naresh,
Please refer my previous post again. I said that you can run your icofoam solver using the steady state command. Anyways I am writing these again:
ddtScheme
type steadystate;
divSchemes
div(phi,U) bounded Gauss upwind;
Best Luck!
Old   March 2, 2015, 11:17
Naresh Yathuru
Thanks once again Tushar. I m afraid if i can post this question here.
could you please give me some tips for which solver to use for this case below:
Geometry : a room with a box inside. the room has a inlet and outlet.
I want to simulate the flow through this room with some velocity and temperature at the inlet, the roof is maintained at a low temperature (20 C) and the box inside is maintained at a temperature (35C).
could you please suggest a solver.
Old   March 3, 2015, 00:11
Tushar Chourushi
Dear Naresh,
I will prefer you to go for "BuoyantBoussinesqPisoFoam", this will do the job. Wish you Good Luck for your work.
Best Regards!
Old   March 3, 2015, 03:12
Naresh Yathuru
Thank you once again for your continuous support. U have no idea how much this tipp mean to me. thanks.
Old   March 3, 2015, 03:42
Tushar Chourushi
Welcome
Best Luck!
Thread Tools
Trackbacks are On
SimpleFoam unable to reach steady state francois OpenFOAM Running, Solving & CFD 8 November 19, 2009 14:33
plz help,urgent, vof model steady state Garima Chaudhary FLUENT 2 May 30, 2007 04:38
steady state, laminar vof_model Garima Chaudhary FLUENT 0 May 24, 2007 03:11
Flow laminar and stationary of water in a pipe manuel OpenFOAM Running, Solving & CFD 6 March 24, 2007 19:23
buoyancy driven flow in steady state in CFX4.3 raymondyin CFX 11 May 7, 2001 06:15
