-   OpenFOAM (
-   -   Multithreading with OpenFOAM (
dipling June 23, 2009 05:49
i studied the UserGuide.pdf and one (i think important topic) is to use the multithreading ability of OpenFOAM. In the guide it is described for the example interFoam. Can I use the commandline:
"mpirun -np 4 (i have 4 cores) dieselFoam (e.g.) - parallel" for every calculation? Of course before split the files with decomposePar...
thanks for answers and sorry for my poor english ;)
akidess June 23, 2009 13:41
Unless your grid is so small the communication overhead slows down the solution, I don't see a problem.
hellorishi June 25, 2009 11:56
or you could use a shorter command for running in parallel.
foamJob -p icoFoam
This is an alias for the mpirun command and it also stores a log file. You can follow the contents of log file by "tailf"
