[swak4Foam] installing funkySetFields utility for OpenFOAM 1.4.1 |
June 26, 2009, 10:48 |
ozie
Hello everybody,
I`am new to OpenFOAM. I just tired to compile funkysetField utility. And i had the error message below; funkySetFields.C:43:26: error: timeSelector.H: Aucun fichier ou répertoire de ce type funkySetFields.C: In function ‘int main(int, char**)’: funkySetFields.C:193: error: ‘Foam::timeSelector’ has not been declared funkySetFields.C:220: error: ‘Foam::timeSelector’ has not been declared make: *** [Make/linuxGccDPOpt/funkySetFields.o] Erreur 1 So I checked funkySetFields.C. And I noticed that timeSelector.H is needed to run this program. Indeed, this file doesn`t exist among the funkySetFields files therby causing errors... Does anyone could tell me how to find timeSelector.H, or maybe am I doing something wrong when compiling funkySetField? oguz, |
June 29, 2009, 05:02 |
Solution to install funkySetFiel
Brugiere Olivier
Hi all
If you want install funkySetFiel, follow this step : - go to http://openfoamwiki.net/index.php/Co...funkySetFields - read the step seven and use the "svn checkout" command to have the funkySetFields - check if you have bison with bison -V - then go in the FunkySetFields/funkySetFields - ./insertGenerated.sh - wmake And normaly funkySetFields was completly instal. Olivier |
June 29, 2009, 12:03 |
#3 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Bernhard |
June 29, 2009, 12:07 |
isabel
When I try to execute FunkySetField I have this error:
bash: funkySetFields: command not found Does anybody know why? |
June 29, 2009, 12:21 |
#5 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
September 8, 2011, 08:40 |
executing in openfoam 1.7.x
Hi bernard
I download it in a folder swake4foam in the home directory. what should I do to run funkysetField? ( I'm new to linux and openfoam) Is funkysetField able to set free surface flow in pipe? |
September 8, 2011, 09:44 |
#7 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
If you're using a supported version and only posted in an inappropriate thread: the information you need about compiling is just at the top of the README funkySetFields allows you to set arbitrary initial conditions for your problems (see examples on the funkySetFields-page on the OpenFOAM-Wiki) Bernhard |
September 8, 2011, 10:06 |
FSF application for free surface flow
Thanks bernard
I use openfoam 1.7.x. I could successfully run funkesetfield for dambreak. But I don't know how to make it for free surface flow for a problem like pitzdaily(discussed in this thread). |
September 8, 2011, 11:16 |
#9 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Bernhard |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
[swak4Foam] installing funkySetFields | prapanj | OpenFOAM Community Contributions | 65 | October 8, 2015 17:46 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! | zfaraday | OpenFOAM Post-Processing | 0 | February 5, 2015 16:47 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
