-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   gammaEqn.H in the interPhaseChangeFoam solver (http://www.cfd-online.com/Forums/openfoam/65885-gammaeqn-h-interphasechangefoam-solver.html)
isabel June 29, 2009 13:33
In gammaEqn.H in the interPhaseChangeFoam we can see this line:
MULES::implicitSolve(oneField(), gamma, phi, phiGamma, Sp, Su, 1, 0);
I know that:
gamma: is the actual value of gamma to be solved
phi: is the normal convective flux
phiGamma: U*gamma + gamma*(1-gamma)*U
1, 0 : max and min gamma values
But I don't unserstand what Sp and Su are. I think that Sp is a source term to solve the equation:
d(gamma)/dt + div(phigamma) = Sp
Am I all right?
What is Su term?
sandy July 7, 2009 05:01
I know that:
Am I all right?
What is Su term?
Hi, I think, your expression about the gamma equation is right.
In fact, to this equation,
Source term = vDotvAlphal * gamma + (1 - gamma) * vDotcAlphal = (vDotvAlphal - vDotcAlphal) * gamma + vDotcAlphal.
So, Sp = (vDotvAlphal - vDotcAlphal) * gamma , and it will be solved implicitly.
Su = vDotcAlphal, and it is an explicit term in this equation.
But, why Su also includes the term divU*gamma in gammaEqu.H ? If the MULES::implicitSolver was chose, this term should be deleted, right?
Because in MULESTemplates.C, phiPsi = phiGamma = phi*gamma + gamma*(1-gamma)*phi, the term div(phi*gamma) [=divU*gamma ??] has been actually included as follows:
fvScalarMatrix psiConvectionDiffusion
fvm::ddt(rho, psi)
+ fv::gaussConvectionScheme<scalar>(mesh, phi, UDs).fvmDiv(phi, psi)
- fvm::Sp(Sp, psi)
- Su
surfaceScalarField phiBD = psiConvectionDiffusion.flux();
surfaceScalarField& phiCorr = phiPsi;
phiCorr -= phiBD;
solve
psiConvectionDiffusion + fvc::div(lambda*phiCorr),
MULEScontrols.lookup("solver")
Am I right?
Thanks.
isabel July 7, 2009 13:41
http://www.cfd-online.com/Forums/ope...tml#post221814
