Issue regarding creation of Partition file
I am facing an issue while creating partition file and it is in the form , as cited below: | ERROR #002100011 has occurred in subroutine cVolSec. | | Message: | | A negative SECTOR volume has been detected. Execution will proceed | | but this is a possible cause of robustness problems. | | The location of the first negative volume is reported below. | | Volume : -0.5023E-12 | | Location : ( 0.16063E+00, 0.14575E+00, -0.13637E+00) | | This warning may be made fatal by setting the expert parameter | | 'negative volume option = 1'. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #002100012 has occurred in subroutine cVolSec. | | Message: | | A negative ELEMENT volume has been detected. This is a fatal | | error and execution will be terminated. The location of the first | | negative volume is reported below. | | Volume : -0.5306E-11 | | Location : ( 0.31089E+00, 0.28364E+00, -0.50454E-01) | +--------------------------------------------------------------------+ While creating Metis type partition I used 72 processors under PVM Distributed parallel. Checked each domain separately ,there is no such error produced as mentioned in the file. Mesh size is 37.4 million. I use 16GB RAM m/c. 'negative volume option = 1'- If such option can be used for multi domain ,please let me know. Please suggest. Regards, Jwala. |
