Specifying fluid density
Old   July 2, 2009, 01:51
Default Specifying fluid density
Sanjib Das Sharma
sanjibdsharma is on a distinguished road
I am new to OpenFoam. I am trying to solve a steady-state, turbulent flow case with water as the fluid. Although I can change the fluid viscosity in the transportProperties file, there is no option for changing the fluid density. As the transportProperties file and the simpleFoam case was developed for air, I suspect my results are wrong as I did not change the fluid density. How do I change the fluid density from the default value?
Thanks in advance,
Sanjib
sanjibdsharma is offline   Reply With Quote
Old   July 2, 2009, 02:54
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
For incompressible cases, there is no need for the fluid density.
OpenFOAM solvers just use the kinematic viscosity instead of dividing the dynamic viscosity by the fluid density. This saves a few operations and should thus improve the efficiency.
olesen is offline   Reply With Quote
Old   February 22, 2011, 08:55
Default and in compressible solvers?
Aldo Iannetti
aldo.iannetti is on a distinguished road
Hi, I'm curious about what happens in compressible solvers, I mean:
- In incompressible solvers the pressure solution is to be multiplied by density (constant) in order to give you the real forces on the body.
-does libforces.so give you the real forces without multiplying the pressur e field?
Thanks
Aldo
aldo.iannetti is offline   Reply With Quote
Which solver I should use when density of the fluid is not a constant dbxmcf OpenFOAM Running, Solving & CFD 0 March 25, 2007 04:26
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
Warning 097- AB Siemens 6 November 15, 2004 04:41
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
