motorBike error in snappyHexMesh in OF 1.6
motorBike tutorial case gives errors in running snappyHexMesh in my OpenFoam 1.6: Determining initial surface intersections ----------------------------------------- #0 Foam::error::printStack(Foam::Ostream&) in "/work/ady/fsalvado/COMPILED_OPENFOAM/1.6//OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/work/ady/fsalvado/COMPILED_OPENFOAM/1.6//OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 __restore_rt at sigaction.c:0 #3 Foam::primitiveMesh::cellEdges(int, Foam::DynamicList<int, 0u, 2u, 1u>&) const in "/work/ady/fsalvado/COMPILED_OPENFOAM/1.6//OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::hexRef8::getLevel0EdgeLength() const in "/work/ady/fsalvado/COMPILED_OPENFOAM/1.6//OpenFOAM-1.6/lib/linux64GccDPOpt/libdynamicMesh.so" #5 Foam::hexRef8::hexRef8(Foam::polyMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::refinementHistory const&) in "/work/ady/fsalvado/COMPILED_OPENFOAM/1.6//OpenFOAM-1.6/lib/linux64GccDPOpt/libdynamicMesh.so" #6 Foam::meshRefinement::meshRefinement(Foam::fvMesh& , double, bool, Foam::refinementSurfaces const&, Foam::shellSurfaces const&) in "/work/ady/fsalvado/COMPILED_OPENFOAM/1.6//OpenFOAM-1.6/lib/linux64GccDPOpt/libautoMesh.so" #7 main in "/work/ady/fsalvado/COMPILED_OPENFOAM/1.6/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/snappyHexMesh" #8 __libc_start_main in "/lib64/libc.so.6" #9 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/work/ady/fsalvado/COMPILED_OPENFOAM/1.6/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/snappyHexMesh" Any suggestion? I have got also problems with foamToVTK (maybe linked to previous problems): Cannot find 'value' entry on patch lowerWall of field k in file "/work/ady/fsalvado/COMPILED_OPENFOAM/1.6/RUN/incompressible/simpleFoam/motorBike/0/k" which is required to set the values of the generic patch field. (Actual type kqRWallFunction) Please add the 'value' entry to the write function of the user-defined boundary-condition or link the boundary-condition into libfoamUtil.so file: /work/ady/fsalvado/COMPILED_OPENFOAM/1.6/RUN/incompressible/simpleFoam/motorBike/0/turbulentBoundaryField::lowerWall from line 22 to line 22. From function genericFvPatchField<Type>::genericFvPatchField(con st fvPatch&, const Field<Type>&, const dictionary&) in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 72. FOAM exiting thanks, Francesco |
maybe I understand something
I believe that the problem is that after running snappyHexMesh, I copy the subdir PolyMesh of the last directory created by snappyHexMesh (named 3 for me) to the constant/polyMesh dir. But, if I erase the directories created by snappyHexMesh -- except the 0 directory containing the initial conditions -- the run fails. Why?
fr. |
franzisko
Hi Franzisko,
I had the same problem. I think there was bug in the definition of the omega wall function. Omega seems to use kqRWallFunction instead of omegaWallFunction. It is fixed in 1.6.x. Ulrich |
Dear all
I've the same problem with my 1.6 version. I'm trying to parallelize the case and I try both: blockMesh-snappyHexMesh-decomposePar (only 2 nodes) and blockMesh-decomposePar-snappyHesMesk with the same errors in the log,decompodePar... 1.- missed headers in the files placed on the /0 folder (already fixed), like: FoamFile { version 2.0; format ascii; class IOobject; location "0"; object frontBackUpperPatches; } 2.- Cannot find 'value' entry on patch lowerWall of field k in file "/home/OpenFOAM/OpenFOAM/juanma-1.6/tutorials/incompressible/simpleFoam/motorBike/0/k" which is required to set the values of the generic patch field. (Actual type kqRWallFunction) Please add the 'value' entry to the write function of the user-defined boundary-condition or link the boundary-condition into libfoamUtil.so 3.- file: /home/OpenFOAM/OpenFOAM/juanma-1.6/tutorials/incompressible/simpleFoam/motorBike/0/turbulentBoundaryField::lowerWall from line 30 to line 30. From function genericFvPatchField<Type>::genericFvPatchField(con st fvPatch&, const Field<Type>&, const dictionary&) in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 72. FOAM exiting Note that are the same errors franzisko found Any suggestion to fix the problem? thanks in advance Juanma |
OF - 1.6 parallel execution of snappyHexMesh
Try this ! :)
blockMesh decomposePar foamJob -p -s snappyHexMesh reconstructParMesh -mergeTol 1e-06 -time 1 reconstructParMesh -mergeTol 1e-06 -time 2 reconstructParMesh -mergeTol 1e-06 -time 3 checkMesh If it complains about the absence of triSurface in the constant directory of the processor.....just copy the triSurface from the case/constant to the processor/constant directory and it should work fine...........:) Regards, Amol |
at the moment I'm investigating other errors in the standard 1.6 case respectively differences between the 1.6 and the 1.6.x version of the case. Have a look here: http://www.cfd-online.com/Forums/ope...k-out-box.html BUT I have to admit, that my 1.6 version ran properly at first run without complaining about the missing value entries... (despite of the wrong results resp. not reaching convergence). Cheers Wolle |
