interFoam pressure conservation
Old   August 26, 2009, 23:15
Default interFoam pressure conservation
Andrew Baglin
AndrewB is on a distinguished road
Hi All,
I am trying to run some free surface cases using interFoam where I have 1 atm of pressure in the air and 2 atm of pressure in the water. The geometry is small enough such that the pressure difference should be accounted for by the surface tension of the water.
At present I am setting the two pressures in the initial conditions, however after the first timestep, the patched pressure has disappeard and all i have is the hydrostatic pressure from the water.
Am I missing something or is interFoam not capable of dealing with a discontinuous pressure.
Thanks
Andrew
AndrewB is offline   Reply With Quote
Pressure Condition sidd Siemens 0 April 2, 2007 09:31
measured pressure in the discharge pipe jumps Jan Main CFD Forum 1 October 30, 2006 07:54
Setting pressure and velocity in inlet Asghari FLUENT 5 September 22, 2006 13:23
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Pressure Boundary Problems Chris Siemens 2 June 21, 2005 08:20
