September 1, 2009, 21:13 |
Size of control volume
John
Why do the results change drastically if I increase the size of the control volume (eg. the mesh around an airfoil)? The result should improve for a bigger control volume, however in my case the results diverge. Thanks. |
September 2, 2009, 01:28 |
Christof Benz
Hi John,
in most cases you obtain a better result as much as fine your mesh is. Not the other way. An exception from this rule is for example spray-simulation. Christof |
control volume size, mesh size, openfoam |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
