Size of control volume
Old   September 1, 2009, 21:13
Default Size of control volume
John
nomad is on a distinguished road
Why do the results change drastically if I increase the size of the control volume (eg. the mesh around an airfoil)?
The result should improve for a bigger control volume, however in my case the results diverge.
Thanks.
nomad is offline   Reply With Quote
Old   September 2, 2009, 01:28
Christof Benz
chbenz is on a distinguished road
Hi John,
in most cases you obtain a better result as much as fine your mesh is. Not the other way. An exception from this rule is for example spray-simulation.
Christof
chbenz is offline   Reply With Quote
control volume size, mesh size, openfoam
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
