Running Tutorial: in file db/regIOobject/regIOobjectRead.C at line 62
Old   September 3, 2009, 10:49
Default Running Tutorial: in file db/regIOobject/regIOobjectRead.C at line 62
Sreepriya
sreepriyav is on a distinguished road
While I try to run any of the tutorial in openfoam, itgives the following error:
Create time
Cannot open file
file: /home/...constant/polymesh/system/controlDict at line 0
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 62.
FOAM exiting
Can someone suggest?
sreepriyav is offline   Reply With Quote
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
