Home > Forums > OpenFOAM
SimpleFoam Boundary Conditions
Old   September 3, 2009, 06:00
Default SimpleFoam Boundary Conditions
Johannes38 is on a distinguished road
Hi
I have a question about the boundary conditions in simpleFoam. I want to modify the pitzDaily Tutorial with other boundary conditions.
I want a static low pressure at the outlet. My p file looks like this:
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform -5000;
upperWall
type zeroGradient;
lowerWall
type zeroGradient;
frontAndBack
type empty;
And I donīt want to have a fixed magnitude. My solution would be a velocity profile. My U file looks like this:
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
upperWall
type fixedValue;
value uniform (0 0 0);
lowerWall
type fixedValue;
frontAndBack
type empty;
The Problem is that I have not a right solution. I think the U file is not correct.
Thanks for your help
Johannes
Johannes38 is offline   Reply With Quote
Old   September 4, 2009, 04:22
Thomas Baumann is on a distinguished road
simpleFoam solves incompressible. For this kind of simulation normally you set for the inlet condition:
pressure: zerogradient
velocity: fixedValues (Ux Uy Uz)
and for outlet condition:
pressure: fixedValue
velocity: zeroGradient
Regards Thomas
Thomas Baumann is offline   Reply With Quote
Old   September 4, 2009, 07:38
Oscar
Zowie is on a distinguished road
I wouldn't use zeroGradient for both velocity and pressure at the inlet... one of them should have a value. If not, the problem is not well described.
By the way, do you really need to use negative pressures?
Zowie is offline   Reply With Quote
Old   September 7, 2009, 17:29
Steve Hansel
hansel is on a distinguished road
You haven't set enough conditions. The problem as you described it could simply be solved by making the pressure -5000 everywhere and having no flow. Or it could pick just about any flow and calculate the pressure to meet it.
You need to define a pressure or velocity somewhere else, probably the inlet.
hansel is offline   Reply With Quote
Thread Tools
Trackbacks are On
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 13:58
Problems with boundary conditions for a lowRekOmegaSST turbulence model cfdmarkus OpenFOAM Running, Solving & CFD 16 November 14, 2011 05:44
Pressure boundary conditions Lionel S. Main CFD Forum 1 August 24, 2007 18:03
SimpleFoam boundary conditions changed in OF 14 adorean OpenFOAM Running, Solving & CFD 5 June 22, 2007 07:50
SimpleFoam boundary conditions hani OpenFOAM Running, Solving & CFD 2 January 10, 2007 03:44
