-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   SnappyHexMesh and sharp corners (http://www.cfd-online.com/Forums/openfoam/68101-snappyhexmesh-sharp-corners.html)
madad2005 September 7, 2009 05:07
I've meshed a box within a box using snappyHexMesh as a tester. However, it is failing to resolve the sharp edges and also doesn't grow any prism layers there. I've set resolveFeatureAngle to 10deg and there are a couple of refinement boxes around it.
Does anyone else have any good settings they can provide for meshing sharp corners?
phsieh2005 September 7, 2009 08:32
HI,
I believe that current snappyHexMesh does not support feature lines. Some people on this forum had mentioned that the feature lines may be supported in the future, but, I am not sure when it will happen.
pei
madad2005 September 7, 2009 09:26
Thanks, Pei. That will explain the issue.
