September 9, 2009, 06:51 |
Electromagnetic Solver for OpenFOAM
Hallo,
I plan to simulate electromagnetic wave propagation based on Maxwells equations. Can anybody tell me if there is a solver in OpenFOAM suitable for such problems? Best regards lkh |
September 16, 2009, 13:57 |
maybe
Electromagnetics of an electric rod and surrounding air (By Margarita Sass-Tisovskaya) http://www.tfd.chalmers.se/~hani/kur.../rodSlides.pdf http://www.tfd.chalmers.se/~hani/kur...08/rodFoam.tgz http://www.tfd.chalmers.se/~hani/kur...odFoamCase.tgz goes somehow in the direction you want to use OF for elvis |
March 30, 2016, 21:52 |
Krish
Rep Power: 10 |
Hi, I tried to run the rodFoam solver but ended up in the error as follows:
Create time Create mesh for time = 0 Reading transportProperties Reading field sigma Reading field ElPot Reading field A Calculating magnetic field B Calculate electrical current density Je #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam:ICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) at ??:? #4 Foam:ICPreconditioner:ICPreconditioner(Foam::l duMatrix::solver const&, Foam::dictionary const&) at ??:? #5 Foam::lduMatrix:reconditioner::addsymMatrixConst ructorToTable<Foam:ICPreconditioner>::New(Foam:: lduMatrix::solver const&, Foam::dictionary const&) at ??:? #6 Foam::lduMatrix:reconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) at ??:? #7 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #8 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #9 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #10 Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&) at ??:? #11 ? at ??:? #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 ? at ??:? Floating point exception (core dumped) Any help in this regard is much appreciated. |
February 23, 2019, 08:54 |
Juris Vencels
Sooner or later someone will read this thread about "modelling electromagnetics using OpenFOAM".
My advice - if you have simple electromagnetic problem (basic geometry, single region) then you can do it! If your problem is complex one (geometry, multi-regions) then try Elmer FEM + OpenFOAM : http://eof-library.com |
September 27, 2021, 22:44 |
ooo
Dzhordzhs thanks!
"Sooner or later" was about two and a half years later, but your advice was very helpful. Elmer plus OpenFoam was exactly what I needed for some capacitance design questions I've been working on. |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
Setting a B.C using UserFortran in 4.3 | tokai | CFX | 10 | July 17, 2001 16:25 |
Error during Solver | cfd guy | CFX | 4 | May 8, 2001 06:04 |
