Compilation of Paraview3.3-cvs with python support |
May 12, 2009, 01:48 |
Sumeet Kumar
Rep Power: 17 |
Hi Foamers,
I want to use python scripts supported paraFoam. For this I enabled the switch "Paraview_enable_python" in Cmakelists.txt file. I have QT 4.3.1, Python 2.6.1 in Opensuse 10.3. I am using the buildParaview3.3--cvs script for recompilation as suggested in the README file. However the script is not able to build it and it stops upon 8% completion I am getting following errors:- [ 7%] Building CXX object VTK/Common/CMakeFiles/vtkCommon.dir/vtkMultiThreader.o Linking CXX shared library ../../bin/libQtTesting.so [ 7%] Building CXX object VTK/Common/CMakeFiles/vtkCommon.dir/vtkMutexLock.o /usr/bin/ld: /usr/local/lib/python2.6/config/libpython2.6.a(exceptions.o): relocation R_X86_64_32 against `_Py_NoneStruct' can not be used when making a shared object; recompile with -fPIC /usr/local/lib/python2.6/config/libpython2.6.a: could not read symbols: Bad value collect2: ld returned 1 exit status make[2]: *** [bin/libQtTesting.so] Error 1 make[1]: *** [Qt/Testing/CMakeFiles/QtTesting.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... [ 7%] Building CXX object VTK/Common/CM .. .. .. .. [ 8%] Building CXX object VTK/Common/CMakeFiles/vtkCommon.dir/vtkCommonInstantiator.o Linking CXX shared library ../../bin/libvtkCommon.so [ 8%] Built target vtkCommon make: *** [all] Error 2 done Afterwards I installed QT 4.3.5, but I received the same build error messages from paraview script. Regards Sumeet |
May 12, 2009, 04:27 |
Josef F. Buergler
Rep Power: 17 |
Did You install python-devel? You could use
# zypper install python-devel or if You use "smart" package manager # smart install python-devel |
May 12, 2009, 06:17 |
Hi Again
Sumeet Kumar
Rep Power: 17 |
Hi Again,
The python-devel package installation was missing. I have installed it but this did not solve the problem. I am still receiving the same build error messages Regards, Sumeet |
May 13, 2009, 01:33 |
Josef F. Buergler
Rep Power: 17 |
Hi Sumeet
Isn't there any indication somewhere in the output of the command "buildParaview3.3-cvs" which could shed some light on the possible cause of the error? Do You use "compilerInstall=System" in the file etc/settings.sh? Make sure to "rm -rf ParaView3.3-cvs/platforms" before the command "buildParaview3.3-cvs". |
May 14, 2009, 04:43 |
Sumeet Kumar
Rep Power: 17 |
Hey I was able to solve the problem. I dlded paraview 3.4 and compiled by making changes in buildPara.. script and now it works well by modifyingthe paraview3 bashrc file. I had to compile PV3FoamReader too.
May 29, 2009, 11:18 |
Paraview in OpenFOAM1.5-dev !!
#6 | |
Nicolas Lussier Clément
Rep Power: 17 |
I try ton compile the OpenFOAM1.5-dev and it went well but now I cant use paraview. I ave Openfoam1.5 with paraview install and build correctly with :
rm -rf $OFDIR/ThirdParty/ParaView3.3-cvs/platforms cd $OFDIR/ThirdParty/ buildParaView3.3-cvs but if I do the same with the OpenFOAM1.5-dev I get : /home/niko/OpenFOAM/OpenFOAM-1.5-dev/bin/buildParaView3.3-cvs: line 59: initialiseVariables: command not found /home/niko/OpenFOAM/OpenFOAM-1.5-dev/bin/buildParaView3.3-cvs: line 65: buildParaView: command not found /home/niko/OpenFOAM/OpenFOAM-1.5-dev/bin/tools/buildParaViewFunctions: line 356: cd: /home/niko/OpenFOAM/ThirdParty/ParaView-3.3-cvs/platforms/linuxGcc: Aucun fichier ou répertoire de ce type I use compilerInstall=OpenFOAM in etc/settings.sh and install QT 4.3.5 > qmake --version QMake version 2.01a Using Qt version 4.3.5 in /usr/local/Trolltech/Qt-4.3.5/lib I on Debian/Lenny5.0 can some one help ! crazysumi You said Quote:
June 1, 2009, 06:51 |
Hi Nicholas
Sumeet Kumar
Rep Power: 17 |
Hey,
At the beginning of the script buildParaview3.3-cvs. it executes the following line . $WM_PROJECT_DIR/bin/tools/buildParaViewFunctions check for the availability of the file "buildParaViewFunctions" in the above path. Or change the path in the script as required. Regards Sumeet |
June 3, 2009, 09:00 |
Rep Power: 17 |
Thanks the problem was that to function where missing inbuildParaViewFunctions
initialiseVariables and buildParaView I don't know why but I just copied it from the 1.5 sources and it worked with both 3.3-dev and 3.4 Now I wander if I can get paraFoam worck with Qt4.4 Right now I at the Workshop and it is great. Regards Nicolas Lussier Last edited by nlc; June 3, 2009 at 20:36. |
June 13, 2009, 15:23 |
#9 |
Thanks Nicolas and Sumeet,
I copied initialiseVariables and buildParaView functions from the OF-1.5 source to the OF-1.5-dev and it seems to fix the problem.. Seems that the buildParaViewFunctions script in OF-1.5-dev is corrupt... I also had to export QT_QMAKE_EXECUTABLE=/usr/local/Trolltech/Qt-4.3.5/bin/qmake before running buildParaView3.3-cvs -Louis |
June 23, 2009, 18:20 |
#10 | |
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
-pUl| References: [1] http://74.125.155.132/search?q=cache...&ct=clnk&gl=ca |
October 12, 2009, 13:01 |
builParaView3.3-cvs got following error
#11 |
Nirmal
Rep Power: 16 |
When I tried to run buildParaView3.3-cvs after rmoving platforms directory, i got the following messages. [ 52%] [ 52%] Building CXX object Utilities/VTKClientServer/Graphics/CMakeFiles/vtkGraphicsCS.dir/vtkWindowedSincPolyDataFilterClientServer.o Building CXX object Utilities/VTKClientServer/Graphics/CMakeFiles/vtkGraphicsCS.dir/vtkGraphicsCSInit.o Linking CXX shared library ../../../bin/libvtkGraphicsCS.so [ 52%] Built target vtkGraphicsCS make: *** [all] Error 2 done please let me know, how can i avoid this and complete the installation? |
Display Modes | |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
