-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   StitchMesh (http://www.cfd-online.com/Forums/openfoam/68460-stitchmesh.html)
pramodopen4foam September 21, 2009 08:03
StitchMesh
Hi friends,
I have imported meshes from fluent to OpenFoam, I have merged my meshes I am not able to stitch meshes, I have gone through quite a few number of threads but did not get correct idea can anyone please help me regarding this,
http://www.cfd-online.com/Forums/ope...1-5-1-6-a.html
In the above link there are some correction patches , but even after compiling these corrected patches I am able to see 2 diffrent meshes,
so can anyone help me,
Will be easy If I send the mesh files,
Thanks in advance,
gschaider September 21, 2009 16:37
Originally Posted by pramodopen4foam (Post 230005)
Hi friends,
Thanks in advance,
What do you mean with "see 2 different meshes" and what does stitchMesh say? BTW: you're sure that you looked at the stitchedMesh (which is not in the constant-directory but in the next timestep).
Bernhard
pramodopen4foam September 22, 2009 03:56
Bernhard
Firstly thanks Bernhard, I meant I am able to see diffrent domain in post processing, I basically meant the flow is not possible through merged mesh, its not passing the interface of 2 meshes, so i assumed stitching is not done in correct way,
and I could not understand the stitching of meshes after studying pleanty of post,
I also saw in all time steps in post processing but also the mesh was same.
It only merges but stitching is Difficult.
gschaider September 22, 2009 12:23
The ultimate Test is checkMesh. If it says that the mesh consists of two regions then it is so. Again: without the error message (or other message) that stitchMesh gives you (and the command line) nobody here can help you
Bernhard
CYMa February 18, 2010 08:07
Hallo, Pramod
May you show me how to compile these
these corrected patches in Change in triangle::intersection breaks stitchMesh in 1.5 and 1.6 ?
I really can not find where i should locate these patches.
Thank you very much!!!
