Salome mesh with NETGEN 1D-2D-3D for OF
Old   June 11, 2010, 12:58
Default Salome mesh with NETGEN 1D-2D-3D for OF
Christoph
kriz is on a distinguished road
Hi!
I am not sure if this is the right place to post, but maybe someone using Salome for meshing can help?
I am currently lacking any commercial mesher, so I am using Salome. The current problem is very, very simple: I have a rectangular room with a small rectangle cut out of the room - it should be a room with a radiator (see attachment).
When I mesh this geometry with NETGEN 1D2D3D it will not refine the mesh at the edges of the radiator, only at the very end of it - Looking at the attachment, you see a slice through the mesh - You can see a finer mesh where the radiator sits, but only at the end of it. Looking at the mesh you can see that the mesh does not refine in direction to the radiator surface.
Is there a possibility to mesh it with a decent refinement at the edges and at the radiator surface, w/o buying a commercial mesher?
kriz is offline   Reply With Quote
Old   June 11, 2010, 15:37
Oliver Gloth
ogloth is on a distinguished road
Yes there is (attention: advertising own stuff ). Using enGrid and Blender you can easily create the geometry, mesh it, and export it to OpenFOAM. The attached picture shows a similar geometry to yours; the walls have prismatic layers which might be useful if you want to resolve the temperature boundary layer. enGrid uses NETGEN for the tetra meshing and its own algorithms for surface meshing and prismatic boundary layers. It is open-source (GPL) and can be found here:
http://engits.eu/engrid
Regards,
Oliver
ogloth is offline   Reply With Quote
Old   June 12, 2010, 07:53
FG_HSRM is on a distinguished road
Hi kriz,
why you are not using snappyHexMesh for meshing and using Salome just for the *.stls? You will have Hexaeder and you can do refinements in special areas.
Regards
Fritz
FG_HSRM is offline   Reply With Quote
Old   June 13, 2010, 08:18
Christoph
Good question. I just started giving snappyHexMesh a try. Thanks for the hint. Is there a good tutorial for it? I found this one: http://www.hydroniumion.de/allgemein...mesh-tutorial/
Is there a possibility to define edges/surfaces in Salome (e.g. with groups) that will be refined by snappyHexMesh? Or do I always have to specify the regions to be refined by coordinates in the snappyHexMeshDict? This would be very cumbersome for more complex geometries.
Old   June 14, 2010, 06:17
Hello!
It looks good to me. There also some tutorials in OpenFoam.
Yes, there are some way to do that. Just take a look in the userguide to get a first impression, what you can do.
Do you already know, how to export the patches?
regards
Fritz
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[Other] vtk mesh or Abaqus mesh to OpenFOAM bigphil OpenFOAM Meshing & Mesh Conversion 27 November 23, 2015 17:31
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
