beginner-hlp pls
hi guys i want to set a pressuer of 2 units in movingwall1 and 1 in movingwall .. am getting an error in this could you guys help me with it?:(
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { movingWall { type fixedValue; value uniform (1 0 0); } movingWall1 { type fixedValue; value uniform (2 0 0); } fixedWalls { type zeroGradient; } frontAndBack { type empty; } } // ************************************************** *********************** // |
However, why do you specify the pressure at a wall, since if you use the no-slip condition, you already specify the velocity, and the pressure should be set to zeroGradient. Best, |
@ alberto
Thanks for the reply. Actually I am modifying the cavity problem in the tutorial. I am keeping one face as inlet and the other as outlet. So I named one face of the face as movingwall and an opposite face as movingwall1. I then specified pressure difference as well as velocity difference is this right
You should specify velocity at the inlet, where p is set to zeroGradient, and pressure at the outlet, where velocity is set to zeroGradient. Keep in mind you consider incompressible flows.
@alberto
hi.. I understood what you said.. my question is how do i differentiate vectors and scalars when I type them in the editor
hope this is clear for pressure movingWall { type fixed; value 0; } is this correct? |
movingWall { type fixedValue; value uniform 0; } is the right syntax. This should be clear by all the examples you find in the tutorials. Best, |
