-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Simulation of Computing Data Centre (http://www.cfd-online.com/Forums/openfoam/68852-simulation-computing-data-centre.html)
tcassey October 3, 2009 12:45
Hi, I am a relatively new user of openFoam and I am currently trying to use the software to create a simulation of air flow within a computing data centre.
Currently my data centre contains computing units and air conditioning units and ideally I would like to be able to calculate the temperature on the boundaries corresponding to the computing units air inlet regions. However, when using the bouyantSimpleFoam solver and specifying "type calculated;" within the T boundary condition file for the inlets I results in an error. Is there any way of calculating values for these boundary regions?
Thanks for you help in this matter,
Tom
tcassey October 5, 2009 08:06
Phrased another way is it possible to calculate the temperature on a boundary, and if so how?
richpaj October 7, 2009 00:00
What bcs would you propose for the enthalpy field h? In "thermo" the
boundary types for T are copied into those for h (cf. hThermo.C)
and the latter field requires suitable boundary conditions to enable a solution to be generated for the hEqn.
Regards,
Richard K.
tcassey October 7, 2009 05:19
Hi Richard,
Thanks for your reply, after some more stumbling around through the documentation and other sources I think using zeroGradient will achieve what I am after.
Regards,
Tom
anthropoy October 5, 2010 11:59
Hi Tom,
Did you have any success in modelling the data centre using OpenFoam? Were you able to set all the boundary conditions correctly?
Thanks,
Sam
