A sphere
Old   October 5, 2009, 17:12
Default A sphere
Samuele Z
samiam1000 is on a distinguished road
I am tryng to simulate the flow around a sphere... I think it is one of the simplest geometry in the world...
But I get an error when I try to mesh it with the snappyHexMesh command.
The error is reported below. Also, I attach both my geometry and the files I edited.
Could you help?
Thanks a lot,
Samuele
samiam@einstein:~/Desktop/sfera$ snappyHexMesh
|  \\    /   O peration     | Version:  1.6                                   |
Build  : 1.6-53b7f692aa41
Exec   : snappyHexMesh
Date   : Oct 05 2009
Time   : 23:05:16
Host   : einstein
PID    : 7949
Case   : /home/samiam/Desktop/sfera
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Read mesh in = 4 s
Overall mesh bounding box  : (-500 -500 -500) (500 500 500)
Relative tolerance         : 1e-06
Absolute matching distance : 0.00173205
Reading refinement surfaces.
Read refinement surfaces in = 0.01 s
Reading refinement shells.
Refinement level 4 for all cells inside refinementBox
Read refinement shells in = 0 s
Setting refinement level of surface to be consistent with shells.
Checked shell refinement in = 0 s
Determining initial surface intersections
Incorrect cellLevel or pointLevel size.
Number of cells in mesh:343000 does not equal size of cellLevel:155756
Number of points in mesh:357911 does not equal size of pointLevel:168084#0  Foam::error::printStack(Foam::Ostream&) in "/home/samiam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1  Foam::error::abort() in "/home/samiam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2  Foam::hexRef8::hexRef8(Foam::polyMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::refinementHistory const&) in "/home/samiam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libdynamicMesh.so"
#3  Foam::meshRefinement::meshRefinement(Foam::fvMesh&, double, bool, Foam::refinementSurfaces const&, Foam::shellSurfaces const&) in "/home/samiam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libautoMesh.so"
#4  main in "/home/samiam/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/snappyHexMesh"
#5  __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#6  _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
    From function hexRef8::hexRef8(const polyMesh&, const labelList&, const labelList&, const refinementHistory&)
    in file polyTopoChange/polyTopoChange/hexRef8.C at line 1912.
FOAM aborting
Aborted
samiam1000 is offline   Reply With Quote
Flow around a sphere and a circular cylinder Francis Main CFD Forum 0 September 29, 2008 05:16
CFX analysis of a sphere - drag too low Rob Findlay CFX 6 March 26, 2007 10:11
Code for diffusion on the surface of a sphere Vena Pearl Bongolan Main CFD Forum 0 July 14, 2006 17:59
CFX cylinder or sphere benchmark results Mel CFX 1 August 8, 2005 18:47
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
