2D Channel Flow
Old   October 9, 2009, 15:18
Default 2D Channel Flow
Akira is on a distinguished road
Hallo, I'm trying to compute a 2D channel flow with "fixed Reynolds number" by using "simpleFoam". The Inlet should be exposed by a developed fluid flow.
Unfortunately the pressure distribution on the Inlet is incorrect. I was trying to use "directMapping" to obtain the profile. Obviously it doesn't work.
Can somebody give me a hint how to use the command or give an other suggestion? (Tutorial, links,....?)
Thanks for your help!!
Akira is offline   Reply With Quote
Old   October 9, 2009, 17:19
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
Please check the tutorial on $FOAM_TUTORIALS/incompressible/pisoFoam/les/pitzDailyDirectMapped for guidance on how to use the directMapped boundary condition.
Regards,
Jose Santos
santos is offline   Reply With Quote
wallHeatFlux for heated walls in laminar channel flow svens OpenFOAM Post-Processing 0 June 20, 2009 20:33
Channel flow set up Jung Main CFD Forum 2 November 21, 2007 06:51
The initial condition for turbulence channel flow Ma Jianfeng Main CFD Forum 1 April 20, 2005 03:50
Stabilizing turbulence equation in channel flow Biga Main CFD Forum 5 March 22, 2005 20:06
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
