Compilation of Paraview3.3-cvs with python support
Old   May 12, 2009, 01:48
Default Compilation of Paraview3.3-cvs with python support
Sumeet Kumar
crazysumi is on a distinguished road
Hi Foamers,
I want to use python scripts supported paraFoam. For this I enabled the switch "Paraview_enable_python" in Cmakelists.txt file.
I have QT 4.3.1, Python 2.6.1 in Opensuse 10.3.
I am using the buildParaview3.3--cvs script for recompilation as suggested in the README file. However the script is not able to build it and it stops upon 8% completion
I am getting following errors:-
[ 7%] Building CXX object VTK/Common/CMakeFiles/vtkCommon.dir/vtkMultiThreader.o
Linking CXX shared library ../../bin/libQtTesting.so
[ 7%] Building CXX object VTK/Common/CMakeFiles/vtkCommon.dir/vtkMutexLock.o
/usr/bin/ld: /usr/local/lib/python2.6/config/libpython2.6.a(exceptions.o): relocation R_X86_64_32 against `_Py_NoneStruct' can not be used when making a shared object; recompile with -fPIC
/usr/local/lib/python2.6/config/libpython2.6.a: could not read symbols: Bad value
collect2: ld returned 1 exit status
make[2]: *** [bin/libQtTesting.so] Error 1
make[1]: *** [Qt/Testing/CMakeFiles/QtTesting.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 8%] Building CXX object VTK/Common/CMakeFiles/vtkCommon.dir/vtkCommonInstantiator.o
Linking CXX shared library ../../bin/libvtkCommon.so
[ 8%] Built target vtkCommon
make: *** [all] Error 2
done
Afterwards I installed QT 4.3.5, but I received the same build error messages from paraview script.
Regards
Sumeet
crazysumi is offline   Reply With Quote
Old   May 12, 2009, 04:27
jfb
Josef F. Buergler
jfb is on a distinguished road
Did You install python-devel? You could use
# zypper install python-devel
or if You use "smart" package manager
# smart install python-devel
jfb is offline   Reply With Quote
Old   May 12, 2009, 06:17
Default Hi Again
Sumeet Kumar
Hi Again,
The python-devel package installation was missing. I have installed it but this did not solve the problem. I am still receiving the same build error messages
Regards,
Sumeet
Old   May 13, 2009, 01:33
jfb
Josef F. Buergler
Hi Sumeet
Isn't there any indication somewhere in the output of the command "buildParaview3.3-cvs" which could shed some light on the possible cause of the error? Do You use "compilerInstall=System" in the file etc/settings.sh? Make sure to "rm -rf ParaView3.3-cvs/platforms" before the command "buildParaview3.3-cvs".
Old   May 14, 2009, 04:43
Sumeet Kumar
Hey I was able to solve the problem. I dlded paraview 3.4 and compiled by making changes in buildPara.. script and now it works well by modifyingthe paraview3 bashrc file. I had to compile PV3FoamReader too.
Old   May 29, 2009, 11:18
Red face Paraview in OpenFOAM1.5-dev !!
nlc
nlc's Avatar
Nicolas Lussier Clément
nlc is on a distinguished road
I try ton compile the OpenFOAM1.5-dev and it went well but now I cant use paraview. I ave Openfoam1.5 with paraview install and build correctly with :
rm -rf $OFDIR/ThirdParty/ParaView3.3-cvs/platforms
cd $OFDIR/ThirdParty/
buildParaView3.3-cvs
but if I do the same with the OpenFOAM1.5-dev I get :
/home/niko/OpenFOAM/OpenFOAM-1.5-dev/bin/buildParaView3.3-cvs: line 59: initialiseVariables: command not found
/home/niko/OpenFOAM/OpenFOAM-1.5-dev/bin/buildParaView3.3-cvs: line 65: buildParaView: command not found
/home/niko/OpenFOAM/OpenFOAM-1.5-dev/bin/tools/buildParaViewFunctions: line 356: cd: /home/niko/OpenFOAM/ThirdParty/ParaView-3.3-cvs/platforms/linuxGcc: Aucun fichier ou répertoire de ce type
I use compilerInstall=OpenFOAM in etc/settings.sh
and install QT 4.3.5
> qmake --version
QMake version 2.01a
Using Qt version 4.3.5 in /usr/local/Trolltech/Qt-4.3.5/lib
I on Debian/Lenny5.0
can some one help !
How did you did that I have tried unsuccessfully to do the same !!
nlc is offline   Reply With Quote
Old   June 1, 2009, 06:51
Default Hi Nicholas
Sumeet Kumar
Hey,
At the beginning of the script buildParaview3.3-cvs. it executes the following line
. $WM_PROJECT_DIR/bin/tools/buildParaViewFunctions
check for the availability of the file "buildParaViewFunctions" in the above path. Or change the path in the script as required.
Regards
Sumeet
Old   June 3, 2009, 09:00
nlc
nlc's Avatar
Thanks the problem was that to function where missing inbuildParaViewFunctions
initialiseVariables and buildParaView
I don't know why but I just copied it from the 1.5 sources and it worked with both 3.3-dev and 3.4
Now I wander if I can get paraFoam worck with Qt4.4
Right now I at the Workshop and it is great.
Regards
Nicolas Lussier
Old   June 13, 2009, 15:23
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
Thanks Nicolas and Sumeet,
I copied initialiseVariables and buildParaView functions from the OF-1.5 source to the OF-1.5-dev and it seems to fix the problem.. Seems that the buildParaViewFunctions script in OF-1.5-dev is corrupt... I also had to export QT_QMAKE_EXECUTABLE=/usr/local/Trolltech/Qt-4.3.5/bin/qmake before running buildParaView3.3-cvs
-Louis
louisgag is offline   Reply With Quote
Old   June 23, 2009, 18:20
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
-Louis
Actually nothing appears to be corrupt. As explained elsewhere[1], we need to adjust the QT version check in CMakeLists.txt before we build paraview. This also avoids errors that come with -lpqComponents reported missing.
-pUl|
References:
[1] http://74.125.155.132/search?q=cache...&ct=clnk&gl=ca
msrinath80 is offline   Reply With Quote
Old   October 12, 2009, 13:01
Default builParaView3.3-cvs got following error
  #11
Nirmal
nirmalrishi is on a distinguished road
When I tried to run buildParaView3.3-cvs after rmoving platforms directory, i got the following messages.
[ 52%] [ 52%] Building CXX object Utilities/VTKClientServer/Graphics/CMakeFiles/vtkGraphicsCS.dir/vtkWindowedSincPolyDataFilterClientServer.o
Building CXX object Utilities/VTKClientServer/Graphics/CMakeFiles/vtkGraphicsCS.dir/vtkGraphicsCSInit.o
Linking CXX shared library ../../../bin/libvtkGraphicsCS.so
[ 52%] Built target vtkGraphicsCS
done
please let me know, how can i avoid this and complete the installation?
nirmalrishi is offline   Reply With Quote
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
