-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   compiling new boundary (http://www.cfd-online.com/Forums/openfoam/69138-compiling-new-boundary.html)
mcgyver2k9 October 13, 2009 06:43
i'm new here and also quite new to openfoam and CFD in general.
what i want to do:
Simulate a steel pipe with hot air flow inside and air around it to figure out the thermal stress of this pipe.
how i tried:
I reduced it to a 2D Problem and want to simulate just the solid body. I'm not interested what happens to the air, so my plan was to use a boundary contition that calculates the heat flow on the solid surface by the temperature difference and the heattransfercoefficient. The temperature of the air can be a constant. I picked solidDisplacementFoam to solve the problem and it works fine with fixedValue or fixedGradient boundarys fo the temperature. I dit not find any boundary condition that exactly fits my problem, so i tried to modify fixedGradient which leads to...
the problem:
I tried to copy fixedGradient to a new folder, renamed anything in the files from fixedGradient to surfaceConvection and compile it. This dit not work. Then i tried to compile the original code with the same result.
here are the error messages:
surfaceConvectionFvPatchField.C:42: error: redefinition of 'Foam::surfaceConvectionFvPatchField<type>::surfac eConvectionFvPatchField(const Foam::fvPatch&, const FOAM::DimensionedField<Type, Foam::volMesh>&)'
surfaceConvectionFvPatchField.C:42: error: 'Foam::surfaceConvectionFvPatchField<type>::surfac eConvectionFvPatchField(const Foam::fvPatch&, const FOAM::DimensionedField<Type, Foam::volMesh>&)' previosly declared here
and this comes for every of these blocks (constructors if i transfered my java knowledge correcttly to c++)
Has anybody an idea what im doing wrong?
thanks for listening
Jörg
