Incompatible dimensions for operation
Hi friends,
I tried to combine solvers settlingFoam and bubbleFoam, I could compile successfully, bu when I ran my solver, which gives error, which states, incompatible dimensions for operation [alpha[0 0 -1 0 0 0 0] ] + [alpha[1 -3 -1 0 0 0 0] ]#0 Foam::error::printStack(Foam::Ostream&) in "/home/baburao/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/baburao/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #2 void Foam::checkMethod<double>(Foam::fvMatrix<double> const&, Foam::fvMatrix<double> const&, char const*) in "/home/baburao/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/comsol" #3 Foam::tmp<Foam::fvMatrix<double> > Foam::operator+<double>(Foam::tmp<Foam::fvMatrix<d ouble> > const&, Foam::tmp<Foam::fvMatrix<double> > const&) in "/home/baburao/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/comsol" #4 main in "/home/baburao/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/comsol" #5 __libc_start_main in "/lib/libc.so.6" #6 _start at /build/buildd/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) in file /home/baburao/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude/fvMatrix.C at line 1184. FOAM aborting Can anyone help with this errorsince I am very new to OpenFoam and C++, Thanks in advance, Anticipating for your kind reply, Pramod |
I guess there is problem with "rho" could u write the alphaEqn
Sachin |
1 Attachment(s)
alphaEqn has been attached,
Thanks for your response Sachin Pramod |
You're obviously using the compressible formulation of 'phi', which includes the density, and that's why you have a dimensions mismatch.
Before 'sticking' codes together, make sure you know exactly what equations you are solving for. If you look at the difference between the alphaEqn in settlingFoam and bubbleFoam the reason it isn't working should be obvious. |
yes , as I mentioned since I dont know C++ upto the mark , I tried to stick with the solvers. Sorry to tell this, can anyone help me regarding this,
Thanks in advance, :mad: |
In bubbleFoam the flux is volumetric:
phia = fvc::interpolate(Ua) & mesh.Sf(); in settlingFoam phi is created with compressibeCreatePhi.H in createFields.H What is the purpose of combining these two codes? |
I am solving with incompressible fluids, I am open for any suggesstion Thank you |
Any suggestions are welcome, Thank you |
| All times are GMT -4. The time now is 21:13. |
