October 19, 2009, 11:36 |
Flow Over a Spillway
PEPIN Nicolas
Rep Power: 16 |
Hi everybody!
I'm a new user of OpenFOAM and I need some explanations... I want to model the flow over a spillway. I have the geometry of the spillway in .stl format. I managed to make a good refined mesh with blockMesh and then snappyHexMesh. Now I have to enter all the boundaries and it's quite difficult for me... I want to use interFoam (it seems that this solver is good for free surface flows, isn't it?). I explain to you what are the boundary conditions I know: * at the upstream of the spillway, the fluid depth is constant equal to 15m. * at the downstream of the spillway, the boundary is open (no condition) (fluid can pass through the boundary) * at the bottom, I want a viscous condition (velocity equal to 0) * the surface of the spillway has a Strickler coefficient of 70 (or roughness equal to 3 mm) How can I model all this? There are such a lot of derived types that I can't understand which one is the good one... Do you have an idea? Do you know if it exists a dictionary that explains all the types available? because the user guide is not very detailed about that... To finish has anyone simulated yet something like a flow over a spillway, or a dam? Thanks for your help! Best regards. |
October 21, 2009, 04:48 |
Håkan Nilsson
Rep Power: 18 |
Hi Nicolas,
Here you have a master thesis describing such a project done in Fluent: http://www.tfd.chalmers.se/~hani/pdf_files/Computational_Modeling_of_Flow_over_a_Spillway_fin al_version.pdf I am very interested in having the same simulation done in OpenFOAM, so you can contact me directly on hani(at)chalmers(dot)se, and I can give you the files. Then I can try to give you a hand on how to set up everything in OpenFOAM. When we are done, you should write a small tutorial on how to do such simulations in OpenFOAM, and post it in the OpenFOAM Wiki. What do you say? Best regards, Håkan. |
boundary conditions, constant depth, free surface flow, interfoam, spillway |
flow profile of spillway | DWARIKA NATH RATH | Phoenics | 2 | April 30, 2015 14:49 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
What is the difference between liquid reactive flow and gas reactive flow? | James | Main CFD Forum | 6 | May 15, 2009 12:14 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 05:57 |
